Home » Modeling » Papyrus » Missing Composition edge in UML Class Diagram palette (The composition edge is missing from the palette for a UML Class Diagram)
icon5.gif  Missing Composition edge in UML Class Diagram palette [message #1071253] Fri, 19 July 2013 12:45 Go to next message
I'm completely new to Papyrus and I'm trying to create a UML class diagram where 2 classes have a composition relationship between them.
However, the Composition/aggregation/ are completely missing from the palette?
The only way I can get the composition edge is by creating a SysML diagram.
Those are basic UML relationships, I'm quite surprised they're not that easily available...
Does anyone know if there's a way to add the Composition & Aggregation edges in the Palette, for a UML Class diagram?
Thanks!
Re: Missing Composition edge in UML Class Diagram palette [message #1072182 is a reply to message #1071253] Mon, 22 July 2013 04:50 Go to previous messageGo to next message
You need to draw a standard Association, then change one end to either "Composite" or "Shared", from the properties view.
You could also customize your Palette (Right click on the palette > Customize), and create a new tool for composite associations. For example:
- Create a new palette
- Add an association to the palette
- Add a new "Aspect action", select "Set association ends properties"
- Set the aggregation of an end to "Composite"
Camille
Re: Missing Composition edge in UML Class Diagram palette [message #1312843 is a reply to message #1072182] Thu, 24 April 2014 10:36 Go to previous message
salut
j'ai un projet qui a comme contenue l'ajout d'une extension pour certain diagrammes uml bon j'ai besoin d'ajouter dans la palette des iconnes et des figures qui repond a mon besoin , j'utilise UMLDesigner sil vous plais j'attend votre réponse et merci d'avance.
Previous Topic:Add Registered Libraries/profiles/etc Programatically
Next Topic:validation warning in an IBD (bug or wrong use?)
Current Time: Sun Jul 20 18:01:42 EDT 2025
Powered by FUDForum. Page generated in 0.53624 seconds
