Home » Eclipse Projects » Gemini » Can't find NamespaceHandler
Can't find NamespaceHandler [message #1312741] Thu, 24 April 2014 09:22 Go to next message
Recently, I get the following error:
2014-04-24 13:02:42,629 | ERROR | ExtenderThread-1 | ExtenderConfiguration            | 69 - org.eclipse.gemini.blueprint.extender - 2.0.0.M02 | Application context refresh failed (OsgiBundleXmlApplicationContext(bundle=com.example.mybundle, config=osgibundle:/META-INF/spring/*.xml))
org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [http://www.springframework.org/schema/osgi-compendium]
Offending resource: URL [bundle://80.0:0/META-INF/spring/jdbc-osgi-context.xml]
        at org.springframework.beans.factory.parsing.FailFastProblemReporter.error(FailFastProblemReporter.java:68)
        at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:85)
        at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:80)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.error(BeanDefinitionParserDelegate.java:318)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1435)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1428)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:195)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:139)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:108)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:493)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:390)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:174)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:209)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:180)
        at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:170)
        at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:140)
        at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
        at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:537)
        at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$800(AbstractDelegatedExecutionApplicationContext.java:60)[14:org.eclipse.gemini.blueprint.core:2.0.0.M02]
        at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$3.run(AbstractDelegatedExecutionApplicationContext.java:242)
        at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
        at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.startRefresh(AbstractDelegatedExecutionApplicationContext.java:220)[14:org.eclipse.gemini.blueprint.core:2.0.0.M02]
        at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:224)[69:org.eclipse.gemini.blueprint.extender:2.0.0.M02]
        at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:177)[69:org.eclipse.gemini.blueprint.extender:2.0.0.M02]
        at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:157)[14:org.eclipse.gemini.blueprint.core:2.0.0.M02]
        at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:205)[69:org.eclipse.gemini.blueprint.extender:2.0.0.M02]
        at java.lang.Thread.run(Thread.java:744)[:1.7.0_51]
I can see the files spring.handlers and spring.schemas in the Gemini Blueprint Core JAR.
The namespace declaration I use:
<beans:beans xmlns="http://www.eclipse.org/gemini/blueprint/schema/blueprint"
	xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:beans="http://www.springframework.org/schema/beans"
	xmlns:context="http://www.springframework.org/schema/context"
	xmlns:osgix="http://www.springframework.org/schema/osgi-compendium"
	xsi:schemaLocation="http://www.eclipse.org/gemini/blueprint/schema/blueprint http://www.eclipse.org/gemini/blueprint/schema/blueprint/gemini-blueprint.xsd
		http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-3.2.xsd
		http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context-3.2.xsd
		http://www.springframework.org/schema/osgi-compendium http://www.springframework.org/schema/osgi-compendium/spring-osgi-compendium.xsd">
I'm sure I'm doing something wrong but I can't see what.
Mickael
Re: Can't find NamespaceHandler [message #1322789 is a reply to message #1312741] Tue, 29 April 2014 21:32 Go to previous message
Are you getting this exception only when using Blueprint specific configuration?
What if you use spring-dm config vs. blueprint do you still get namespace resolution error, i.e.
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:osgi="http://www.springframework.org/schema/osgi"
       xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
                      http://www.springframework.org/schema/osgi http://www.springframework.org/schema/osgi/spring-osgi.xsd
Dmitry
Previous Topic:issues reading classpath resources using Spring and Karaf
Next Topic:Gemini basic
Current Time: Sun Jul 20 04:10:47 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
