Home » Eclipse Projects » Remote Application Platform (RAP) » Table.indexOf not optimized like in SWT
Table.indexOf not optimized like in SWT [message #131085] Mon, 04 May 2009 10:06 Go to next message
I noticed that Table.indexOf in SWT looks like this:
public int indexOf (TableItem item) {
checkWidget ();
if (item == null) error (SWT.ERROR_NULL_ARGUMENT);
int count = (int)OS.SendMessage (handle, OS.LVM_GETITEMCOUNT, 0, 0);
if (1 <= lastIndexOf && lastIndexOf < count - 1) {
if (items [lastIndexOf] == item) return lastIndexOf;
if (items [lastIndexOf + 1] == item) return ++lastIndexOf;
if (items [lastIndexOf - 1] == item) return --lastIndexOf;
if (lastIndexOf < count / 2) {
for (int i=0; i<count; i++) {
if (items [i] == item) return lastIndexOf = i;
} else {
for (int i=count - 1; i>=0; --i) {
return -1;
While in RWT looks like:
public int indexOf( final TableItem item ) {
checkWidget();
if( item == null ) {
SWT.error( SWT.ERROR_NULL_ARGUMENT );
int result = -1;
for( int i = 0; result == -1 && i < itemCount; i++ ) {
if( items[ i ] == item ) {
result = i;
return result;
In RWT when a list contains 10000 items, the indexOf scroll all over the
10000 items to find the index boosting the CPU at 100%.
Is it possible to optimize the Table.indexOf method like in SWT?
Enrico
Re: Table.indexOf not optimized like in SWT [message #131124 is a reply to message #131085] Mon, 04 May 2009 10:29 Go to previous messageGo to next message
Hi Enrico,
it is already optimized in CVS HEAD :-). See this bug:
273433: [Table] render phase becomes slow when having many Items
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273433
Best,
Ivan
Enrico Zanaga wrote:
> checkWidget ();
> } else {
> return -1;
> checkWidget();
> int result = -1;
> result = i;
> return result;
> the 10000 items to find the index boosting the CPU at 100%.
> Enrico
Re: Table.indexOf not optimized like in SWT [message #131227 is a reply to message #131124] Mon, 04 May 2009 13:23 Go to previous messageGo to next message
Hi Ivan,
I've downloaded the version from CVS HEAD, but now the server sends all
the 10000 items of the list to the client.
Now the browser consumes 100% CPU.
In the M6 only the visible rows were send to the client, why not in CSV
HEAD?
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> Best,
> Ivan
>> Hi,
>> checkWidget ();
>> } else {
>> return -1;
>> checkWidget();
>> int result = -1;
>> result = i;
>> return result;
>> Thanks,
>> Enrico
Re: Table.indexOf not optimized like in SWT [message #131241 is a reply to message #131227] Mon, 04 May 2009 14:25 Go to previous messageGo to next message
Enrico,
I did y quick check, but I cannot reproduce what you describe.
Please note that you need to specify the VIRTUAL flag in order to
not have sent all the times to the client.
Please file a bugzilla if you can reproduce the problem.
HTH
Rüdiger
> Hi Ivan,
> HEAD?
> Enrico
>> Hi Enrico,
>> Best,
>> Ivan
>>> Hi,
>>> checkWidget ();
>>> } else {
>>> return -1;
>>> checkWidget();
>>> int result = -1;
>>> result = i;
>>> return result;
>>> Thanks,
>>> Enrico
Re: Table.indexOf not optimized like in SWT [message #131254 is a reply to message #131227] Mon, 04 May 2009 14:31 Go to previous message
Hi Enrico,
are you using a virtual table? Can you post a simple snippet that
demonstrate this behavior?
Best,
Ivan
> Hi Ivan,
> all the 10000 items of the list to the client.
> CSV HEAD?
> Enrico
>> Hi Enrico,
>> Best,
>> Ivan
>>> Hi,
>>> checkWidget ();
>>> } else {
>>> return -1;
>>> checkWidget();
>>> int result = -1;
>>> result = i;
>>> return result;
>>> Thanks,
>>> Enrico
Previous Topic:Singlesourcing Branding (Splashscreen)
Next Topic:Work with RAP
Current Time: Sun Jul 20 08:15:26 EDT 2025
Powered by FUDForum. Page generated in 1.10462 seconds
