Home » Archived » Visual Editor (VE) » buf or feature? empty window
buf or feature? empty window [message #131128] Wed, 20 September 2006 14:06 Go to next message
hello all,
try the following with sdk 3.3M1:
- create an empty java project
- create a visual class, choose swt shell and let it create a main method
- put a composite on the shell in the java beans view
-> the shell window visually changes its' position (why that?)
this only happens if u add the composite in the bean view
- put a label in the composite
- start the little app with alt+shift+x j
-> an empty shell shows up (where is my label?)
is this caused by wrong use?
cu,
michael
Re: buf or feature? empty window [message #131224 is a reply to message #131128] Thu, 21 September 2006 10:19 Go to previous messageGo to next message
Could you please append the generated code?
Re: buf or feature? empty window [message #131312 is a reply to message #131224] Fri, 22 September 2006 03:02 Go to previous messageGo to next message
Originally posted by: michael.dev.NO_SPAM.gmx.de
Hello Rich,
thanks for your answer. One more idea I have for ve. Normally I work wth
ve and code in separate tabs instead of a split pane. I think this is even
a better default, because in my opinion a split pane neither gives you
enough space for visual editing nor for code. The idea is, if you double
click on an event in the java beans view it should switch to the source
tab and jump to the code position of the according event. In a preference
you could even define an option to jump to the code section and the source
tab when an event is added (this should be really an option not a general
behaviour).
Here you are (I removed the comments but everything
else is pure class wizard & ve generated):
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Label;
public class MissingLabelSample {
private Shell sShell = null;
private Composite composite = null;
private Label label = null;
private void createComposite() {
composite = new Composite(sShell, SWT.NONE);
composite.setLayout(new GridLayout());
label = new Label(composite, SWT.NONE);
label.setText("Run the app and you won't see me");
Display display = Display.getDefault();
MissingLabelSample thisClass = new MissingLabelSample();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
createComposite();
sShell.setSize(new Point(300, 200));
sShell.setLayout(new GridLayout());
Re: buf or feature? empty window [message #131336 is a reply to message #131312] Fri, 22 September 2006 04:42 Go to previous messageGo to next message
Here it is again... better formatted
composite = new Composite(sShell, SWT.NONE); composite.setLayout(new
GridLayout()); label = new Label(composite, SWT.NONE);
Display display = Display.getDefault(); MissingLabelSample thisClass =
new MissingLabelSample(); thisClass.createSShell();
display.sleep();
display.dispose();
createComposite();
Re: buf or feature? empty window [message #131367 is a reply to message #131312] Fri, 22 September 2006 10:42 Go to previous messageGo to next message
Two windows are already available. There is a VE option on the
Window->Preferences->Java->Visual Editor to switch to using a tab pane
with two windows instead of a split pane.
Re: buf or feature? empty window [message #131378 is a reply to message #131336] Fri, 22 September 2006 10:48 Go to previous messageGo to next message
I don't know how it happened, but switch the order of the setLayout and
setSize in the createShell() method.
Re: buf or feature? empty window [message #131414 is a reply to message #131367] Mon, 25 September 2006 02:45 Go to previous messageGo to next message
I know that thank you. I was just thinking it is a better default setting.
Re: buf or feature? empty window [message #131426 is a reply to message #131414] Mon, 25 September 2006 11:08 Go to previous messageGo to next message
It depends on who you talk to. :-) In the beginning we had the two panes
as the default. We were asked over and over to make the split pane the
default, so we did.
Re: buf or feature? empty window [message #131452 is a reply to message #131426] Tue, 26 September 2006 08:04 Go to previous message
> default, so we did.
Ok, convinced.. :)
Re: buf or feature? empty window [message #614641 is a reply to message #131128] Thu, 21 September 2006 10:19 Go to previous message
Re: buf or feature? empty window [message #614648 is a reply to message #131224] Fri, 22 September 2006 03:02 Go to previous message
Hello Rich,
behaviour).
display.sleep();
display.dispose();
createComposite();
Re: buf or feature? empty window [message #614650 is a reply to message #131312] Fri, 22 September 2006 04:42 Go to previous message
display.sleep();
display.dispose();
createComposite();
Re: buf or feature? empty window [message #614653 is a reply to message #131312] Fri, 22 September 2006 10:42 Go to previous message
Re: buf or feature? empty window [message #614654 is a reply to message #131336] Fri, 22 September 2006 10:48 Go to previous message
Re: buf or feature? empty window [message #614657 is a reply to message #131367] Mon, 25 September 2006 02:45 Go to previous message
Re: buf or feature? empty window [message #614658 is a reply to message #131414] Mon, 25 September 2006 11:08 Go to previous message
default, so we did.
Re: buf or feature? empty window [message #614660 is a reply to message #131426] Tue, 26 September 2006 08:04 Go to previous message
> default, so we did.
Ok, convinced.. :)
Previous Topic:verticalIndent missing for GridData (SWT)
Next Topic:VE failed to parse public final static Dimention() const of base class
Current Time: Sat Jul 19 10:50:47 EDT 2025
Powered by FUDForum. Page generated in 0.13020 seconds
