Home » Eclipse Projects » Remote Application Platform (RAP) » Table.indexOf not optimized like in SWT
Table.indexOf not optimized like in SWT [message #131085] |
Mon, 04 May 2009 10:06  |
I noticed that Table.indexOf in SWT looks like this:
public int indexOf (TableItem item) {
checkWidget ();
if (item == null) error (SWT.ERROR_NULL_ARGUMENT);
int count = (int)OS.SendMessage (handle, OS.LVM_GETITEMCOUNT, 0, 0);
if (1 <= lastIndexOf && lastIndexOf < count - 1) {
if (items [lastIndexOf] == item) return lastIndexOf;
if (items [lastIndexOf + 1] == item) return ++lastIndexOf;
if (items [lastIndexOf - 1] == item) return --lastIndexOf;
if (lastIndexOf < count / 2) {
for (int i=0; i<count; i++) {
if (items [i] == item) return lastIndexOf = i;
} else {
for (int i=count - 1; i>=0; --i) {
return -1;
While in RWT looks like:
public int indexOf( final TableItem item ) {
checkWidget();
if( item == null ) {
SWT.error( SWT.ERROR_NULL_ARGUMENT );
int result = -1;
for( int i = 0; result == -1 && i < itemCount; i++ ) {
if( items[ i ] == item ) {
result = i;
return result;
In RWT when a list contains 10000 items, the indexOf scroll all over the
10000 items to find the index boosting the CPU at 100%.
Is it possible to optimize the Table.indexOf method like in SWT?
Enrico
Re: Table.indexOf not optimized like in SWT [message #131227 is a reply to message #131124] |
Mon, 04 May 2009 13:23   |
Hi Ivan,
I've downloaded the version from CVS HEAD, but now the server sends all
the 10000 items of the list to the client.
Now the browser consumes 100% CPU.
In the M6 only the visible rows were send to the client, why not in CSV
HEAD?
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> it is already optimized in CVS HEAD :-). See this bug:
> 273433: [Table] render phase becomes slow when having many Items
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=273433
> Best,
> Ivan
> Enrico Zanaga wrote:
>> Hi,
>> checkWidget ();
>> } else {
>> return -1;
>> checkWidget();
>> int result = -1;
>> result = i;
>> return result;
>> the 10000 items to find the index boosting the CPU at 100%.
>> Thanks,
>> Enrico
Re: Table.indexOf not optimized like in SWT [message #131241 is a reply to message #131227] |
Mon, 04 May 2009 14:25   |
Enrico,
I did y quick check, but I cannot reproduce what you describe.
Please note that you need to specify the VIRTUAL flag in order to
not have sent all the times to the client.
Please file a bugzilla if you can reproduce the problem.
HTH
Rüdiger
> Hi Ivan,
> HEAD?
> Enrico
>> Hi Enrico,
>> Best,
>> Ivan
>>> Hi,
>>> checkWidget ();
>>> } else {
>>> return -1;
>>> checkWidget();
>>> int result = -1;
>>> result = i;
>>> return result;
>>> Thanks,
>>> Enrico
Re: Table.indexOf not optimized like in SWT [message #131254 is a reply to message #131227] |
Mon, 04 May 2009 14:31  |
Hi Enrico,
are you using a virtual table? Can you post a simple snippet that
demonstrate this behavior?
Best,
Ivan
> Hi Ivan,
> all the 10000 items of the list to the client.
> CSV HEAD?
> Enrico
>> Hi Enrico,
>> Best,
>> Ivan
>>> Hi,
>>> checkWidget ();
>>> } else {
>>> return -1;
>>> checkWidget();
>>> int result = -1;
>>> result = i;
>>> return result;
>>> Thanks,
>>> Enrico
Current Time: Sat Jul 19 13:00:12 EDT 2025
Powered by FUDForum. Page generated in 0.07121 seconds
