Home » Archived » Visual Editor (VE) » Extend VE and custom constructors
Extend VE and custom constructors [message #130682] Fri, 08 September 2006 05:44
Originally posted by: peter.vermeulen.maniagroup.com
I'm trying to extend the VE with some custom widgets that are all
subclassed from existing SWT widgets.
For example, I have a class MyButton that extends the SWT Button component.
Everything seems to work fine, but I still struggle with the following:
If I add a MyButton in the VE, it uses the default constructor:
MyButton(Composite parent, int style).
I would like to have a new constructor MyButton(Composite parent, int
style, String name) where name should be the name of the MyButton instance
that will be created.
e.g. VE should generate something like this: okButton = new Button(this,
SWT.NONE, "okButton");
I was able to modify the code that is generated when a property is changed
in VE (using an override file and decoder classes), but can not find how
to change the constructor.
Thank you very much for your help,
Peter Vermeulen,
Belgium
Previous Topic:can I build the source to .exe file
Next Topic:Extend VE and custom constructors
Current Time: Sat Jul 19 14:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
