Home » Newcomers » Newcomers » Eclipse writes to Dropbox folder(Eclipse tries to store 2 files in the Dropbox folder)
Eclipse writes to Dropbox folder [message #1302314] Fri, 18 April 2014 13:06 Go to next message
Search for "Dropbox" on this forum didn't show anything.
During first run, Eclipse Standard 4.3.2 creates 2 files in the dopbox folder.
"...\Dropbox\shellext\l\53514c92"
and
"...\Dropbox\shellext\l\535001e2"
(I'm not sure if it's safe to post their contents here so I won't for now.)
Anyone knows purpose of this?
Re: Eclipse writes to Dropbox folder [message #1302561 is a reply to message #1302314] Fri, 18 April 2014 16:29 Go to previous messageGo to next message
What makes you say that Eclipse is creating those files? Eclipse itself doesn't know anything about Dropbox. Perhaps you have installed a third-party plugin that might be doing that?
Re: Eclipse writes to Dropbox folder [message #1302634 is a reply to message #1302561] Fri, 18 April 2014 17:27 Go to previous messageGo to next message
Before running eclipse, i have set the %APPDATA% to a custom location.
Described files appear in that custom location, available only to eclipse.
No plugins, clean fresh install.
I probably should have mention it straight away, but now I realised opening a project from dropbox folder. However this still does not explain what's happening:
set APPDATA=...\eclipse\data
eclipse.exe
* open project from ...\UserFolder\Dropbox\Folder\Folder\Project1\ *
* new files appear in ...\eclipse\data\Dropbox\shellext\l *
I'm just trying to understand this behavior.
Thanks for reply,
[Updated on: Fri, 18 April 2014 17:28] by Moderator
Re: Eclipse writes to Dropbox folder [message #1303579 is a reply to message #1302634] Sat, 19 April 2014 06:26 Go to previous messageGo to next message
On 18-4-2014 23:27, alex alexander wrote:
> Quote:
> Quote:
> eclipse.exe
> I'm just trying to understand why this is happening.
> Thanks for reply,
This is not a problem created by Eclips
'Dropbox' creates files in %appdata%Dropbox .....
If i do this:
set APPDATA=c:\temp
"c:\Program Files (x86)\Notepad++\notepad++.exe"
c:\users\luuk\dropbox\test.txt
than i also see a folder c:\temp\Dropbox being created.... ;)
Re: Eclipse writes to Dropbox folder [message #1303617 is a reply to message #1303579] Sat, 19 April 2014 06:58 Go to previous message
Thank you Luuk!
Previous Topic:Eclipse GUI too small on ultrabook
Next Topic:error 404
Current Time: Sun Jul 20 07:19:04 EDT 2025
Powered by FUDForum. Page generated in 0.08660 seconds
