Home » Eclipse Projects » Remote Application Platform (RAP) » Theme xml files
Theme xml files [message #130190] Sun, 26 April 2009 05:34 Go to next message
Originally posted by: peterka.jiri.gmail.com
Hi all,
for theming purposes there should be <widget>.theme.xml for each widget
for example Button.theme.xml file describing theme-able properties for
Button widget. Unfortunately I can't find these files.
Could you please provide exact location where these files can be found?
Jiri
Re: Theme xml files [message #130215 is a reply to message #130190] Sun, 26 April 2009 07:32 Go to previous messageGo to next message
Hi Jiri,
they are located in org.eclipse.rap.rwt plugin -
org.eclipse.rap.rwt\src\org\eclipse\swt\internal\widgets\but tonkit\Button.theme.xml
for example.
Best,
Ivan
Jiri Peterka wrote:
> Hi all,
> widget for example Button.theme.xml file describing theme-able
> properties for Button widget. Unfortunately I can't find these files.
> Thanks
> Jiri
Re: Theme xml files [message #130244 is a reply to message #130215] Sun, 26 April 2009 11:06 Go to previous message
Hi Ivan,
thanks for the location.
Jiri
Ivan Furnadjiev wrote:
> Hi Jiri,
> for example.
> Best,
> Ivan
> Jiri Peterka wrote:
>> Hi all,
>> Thanks
>> Jiri
Previous Topic:How can I get multiple LCAs to work?
Next Topic:How to set object reference to servlet from RAP
Current Time: Sat Jul 19 14:46:51 EDT 2025
Powered by FUDForum. Page generated in 0.04632 seconds
