Home » Eclipse Projects » Eclipse 4 » How do i define and use my own renderer?
How do i define and use my own renderer? [message #502716] Wed, 09 December 2009 09:28 Go to next message
i'm trying to define my own renderer for the indiviual elements of the workbench model.
I looked into the org.eclipse.e4.ui.workbench.renderers.swt package and played a bit with the existing renderers. Like changing the CTabFolder created in the StackRenderer or including the ribbon toolbar (from Hexapixel) in the WBWRenderer and that worked fine. So i thought to change the renderer i can implement my own by extending the SWTPartRenderer and define this one as default.
But how to i define that my own renderer should be used for a specific workbench model element. I saw that a model element has a Factory- & Widget-feature but i don't know how to use it. The same with the org.eclipse.e4.workbench.rendererfactory extension point.
Is this the right way at all or is there a better solution?
Thanks in advance for your help.
Jens Keller
Re: How do i define and use my own renderer? [message #503172 is a reply to message #502716] Fri, 11 December 2009 04:30 Go to previous messageGo to next message
I found a way. I'm sure that in future versions of e4 it will be a bit easier to do this
but this feature looks very promising. So first you need the following:
- Eclipse 3.6M3
- e4M2 as target platform
from the cvs (both 20091126-1500):
- org.eclipse.e4.ui.workbench.renderers.swt
- org.eclipse.e4.ui.workbench.swt
Add both plugins to your runtime config.
- org.eclipse.e4.ui.workbench.swt.factories.IRendererFactory
- org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer
- org.eclipse.e4.ui.workbench.swt.internal.PartRenderingEngine
First you need a renderer.You can define one for every element type in the workbench model.
For this you extend the SWTPartRenderer. You can use a default renderer in
org.eclipse.e4.ui.workbench.renderers.swt as a blueprint (maybe just change the CTabFolder in the StackRenderer).
To define which renderer should be used you must implement a IRendererFactory. Again you can use the default
one in org.eclipse.e4.workbench.ui.renderers.swt as blueprint. To define which IRendererFactory Eclipse should
use you must implement the org.eclipse.e4.workbench.rendererfactory extension point. This ext. point is not
fully implemented yet so you don't get a context menu to help you. After you added the ext.point got to
the xml-view and complete the definition as following (which i only guessed ad the moment):
<extension
id="sample.rendererfactory"
point="org.eclipse.e4.workbench.rendererfactory">
<rendererfactory
name="SampleRendererFactory"
class="de.sample.renderer.SampleWorkbenchRendererFactory">
</rendererfactory>
</extension>
The last step is to make sure Eclipse uses your IRendererFactory. Go to org.eclipse.e4.ui.workbench.swt.internal.PartRenderingEngine
(in the cvs plugin) and comment the code in line 186 & 187 (at the moment this code makes sure that no other renderer is used than the default one):
if (!curFactoryId.equals(id))
continue;
Now you should be able to explore the future possibilities of implementing your own renderers and new ways of designing
the UI. For a starting point you can include the swt rippon toolbar which you can find at http://hexapixel.com/projects/ribbon.
Re: How do i define and use my own renderer? [message #505894 is a reply to message #503172] Tue, 05 January 2010 09:12 Go to previous messageGo to next message
I have created a bug and make some modification to change the default value
of curFactoryId for subclasses:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298848
Best regards
Yves YANG
"Jens Keller" <mai00bfi@googlemail.com> wrote in message
news:hft3f9$k0h$1@build.eclipse.org...
>easier to do this but this feature looks very promising. So first you need
>the following:
> - Eclipse 3.6M3
> workbench model. For this you extend the SWTPartRenderer. You can use a
> default renderer in org.eclipse.e4.ui.workbench.renderers.swt as a
> blueprint (maybe just change the CTabFolder in the StackRenderer). To
> IRendererFactory. Again you can use the default one in
> IRendererFactory Eclipse should use you must implement the
> is not fully implemented yet so you don't get a context menu to help you.
> After you added the ext.point got to the xml-view and complete the
> <extension
> <rendererfactory
> </rendererfactory>
> </extension>
> org.eclipse.e4.ui.workbench.swt.internal.PartRenderingEngine (in the cvs
> continue;
> your own renderers and new ways of designing the UI. For a starting point
Re: How do i define and use my own renderer? [message #506168 is a reply to message #505894] Wed, 06 January 2010 07:44 Go to previous messageGo to next message
Thanks for your help.
Jens Keller
Re: How do i define and use my own renderer? [message #506174 is a reply to message #506168] Wed, 06 January 2010 07:52 Go to previous messageGo to next message
BTW there are (not up-to-date) renderer implementations available from
my personal repository [1].
Tom
[1] https://svn.tomsondev.com/svn/ufacekit/desktop/org.ufacekit. ui.e4.renderer/
Am 06.01.10 13:44, schrieb Jens Keller:
> Jens Keller
Re: How do i define and use my own renderer? [message #506398 is a reply to message #506174] Thu, 07 January 2010 06:51 Go to previous messageGo to next message
Thanks for your example-renderers. I also used the nice swt-ribbon by Emil Crumhorn as a basis for my first renderer.
Jens Keller
Re: How do i define and use my own renderer? [message #566985 is a reply to message #503172] Tue, 05 January 2010 09:12 Go to previous messageGo to next message
Best regards
Yves YANG
>the following:
> - Eclipse 3.6M3
> <extension
> <rendererfactory
> </rendererfactory>
> </extension>
> continue;
Re: How do i define and use my own renderer? [message #567122 is a reply to message #505894] Wed, 06 January 2010 07:44 Go to previous messageGo to next message
Jens Keller
Re: How do i define and use my own renderer? [message #567146 is a reply to message #567122] Wed, 06 January 2010 07:52 Go to previous messageGo to next message
Tom
> Jens Keller
Re: How do i define and use my own renderer? [message #567239 is a reply to message #506174] Thu, 07 January 2010 06:51 Go to previous messageGo to next message
Jens Keller
Re: How do i define and use my own renderer? [message #842609 is a reply to message #506174] Thu, 12 April 2012 09:04 Go to previous messageGo to next message
hi tom,
could you please provide credentials for your svn repository
thanks
Re: How do i define and use my own renderer? [message #842615 is a reply to message #842609] Thu, 12 April 2012 09:08 Go to previous messageGo to next message
I'm missing the context a bit from your post because you didn't quote
the original post.
Tom
Am 12.04.12 15:05, schrieb ishara gunathilake:
> hi tom,
> thanks
Re: How do i define and use my own renderer? [message #842631 is a reply to message #842615] Thu, 12 April 2012 09:28 Go to previous messageGo to next message
Tom
[1] svn.tomsondev.com/svn/ufacekit/desktop/org.ufacekit. ui.e4.renderer/
this is the original post.I just want credentials for above repository to try out custom renderer.
thanks.
Re: How do i define and use my own renderer? [message #842639 is a reply to message #842615] Thu, 12 April 2012 09:28 Go to previous messageGo to next message
> Tom
thanks.
Re: How do i define and use my own renderer? [message #842664 is a reply to message #842639] Thu, 12 April 2012 09:58 Go to previous messageGo to next message
What do you mean with credentials? The repo is available publicly
and the header state that the code is provided under EPL so I really
don't get what you mean.
Please also note that this code is fairly old and you should start with
an implementation from the current codebase and replace stuff.
Tom
Am 12.04.12 15:28, schrieb ishara gunathilake:
> Quote:
>> Tom
> thanks.
Re: How do i define and use my own renderer? [message #847937 is a reply to message #842664] Tue, 17 April 2012 16:04 Go to previous messageGo to next message
My Eclipse 4 Renderer tutorial might also help.
Re: How do i define and use my own renderer? [message #1298843 is a reply to message #847937] Wed, 16 April 2014 10:46 Go to previous messageGo to next message
Hi Lars,
I tried to follow your tutorial for registering my own renderer, but it is not called.
Is the extension point "org.eclipse.core.runtime.products" the correct entry point to use just my own StackRender in the eclipse IDE ?
Alain Rapaz
Re: How do i define and use my own renderer? [message #1299952 is a reply to message #1298843] Thu, 17 April 2014 04:13 Go to previous messageGo to next message
You need to replace the rendererfactory used.
Tom
On 16.04.14 16:46, Missing name Mising name wrote:
> Hi Lars,
> is not called.
> Alain Rapaz
Re: How do i define and use my own renderer? [message #1300323 is a reply to message #1299952] Thu, 17 April 2014 09:48 Go to previous messageGo to next message
Thanks Tom,
But what extension point should I use to do that ?
I tried "org.eclipse.e4.workbench.rendererfactory" but it seems not valid anymore...
I use eclipse 4.3.2
Alain Rapaz
Re: How do i define and use my own renderer? [message #1300408 is a reply to message #1300323] Thu, 17 April 2014 10:53 Go to previous messageGo to next message
There's not extension point for that but in your use the
property-element of the product-extension point
<property name="rendererFactoryUri" value="bundleclass://.....">
Tom
On 17.04.14 15:48, Missing name Mising name wrote:
> Thanks Tom,
> valid anymore...
> I use eclipse 4.3.2
> Alain Rapaz
Re: How do i define and use my own renderer? [message #1300452 is a reply to message #1300408] Thu, 17 April 2014 11:30 Go to previous messageGo to next message
this is what I tried, but my renderer is not used...
<extension
point="org.eclipse.core.runtime.products"
id="wrappedTabs">
<product
application="org.eclipse.e4.ui.workbench.swt.E4Application"
name="wrappedTabs">
<property
value="bundleclass://WrappedTabs/wrappedTabs.WrappedRendererFactory">
</property>
</product>
</extension>
This is not for an RCP application, I just want to customize the IDE to replace the widget for the editors tabs to show them multiline.
In 3.x of eclipse, I used the "presentation examples" of Lars Vogel (I think) and I would like to implement it on E4.
Alain
Re: How do i define and use my own renderer? [message #1300577 is a reply to message #1300452] Thu, 17 April 2014 13:28 Go to previous messageGo to next message
But the IDE is not booted with this product! If you want to customize
the IDE you can use the same key with as a Programm argument:
-os ..... -rendererFactoryUri
Tom
> <extension
> id="wrappedTabs">
> <product
> name="wrappedTabs">
> <property
> </property>
> </product>
> </extension>
> Alain
Re: How do i define and use my own renderer? [message #1308637 is a reply to message #1300577] Tue, 22 April 2014 03:13 Go to previous messageGo to next message
Hi Tom,
Thanks, it is working with the switch in the command line to start eclipse.
But, I think it should be implemented as an extension point, to be in the philosophy of plug-in to extend the functionality of eclipse.
Alain
Re: How do i define and use my own renderer? [message #1311431 is a reply to message #1308637] Wed, 23 April 2014 16:09 Go to previous message
There's a far simpler way if you're over-riding at a very low level;
There's a key CUSTOM_RENDERER_URI...if you add this to any element's 'persistentData' map with the 'value' being the URI of the renderer you want to use....
Previous Topic:Behavior Differences Between @Active and @Named
Next Topic:TextElement foreground color = background color
Current Time: Sat Jul 19 12:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.06796 seconds
