Home » Eclipse Projects » GEF » Retargeted connections problem
Retargeted connections problem [message #129284] |
Wed, 28 April 2004 01:24  |
Originally posted by: cwhite.ic.net
I have a diagram where when a specific edit part refreshes, existing
connections are targeted to new child edit parts and some old edit parts
that were targets of the same connections are deleted. When the children are
refreshed the connections are properly stiched to the new edit parts.
However, the old edit parts are then deleted (in the refreshChildren method)
and the connection target is set to null.
So the connections end up no target. Is there a way to avoid this behavior?
Re: Retargeted connections problem [message #129662 is a reply to message #129438] |
Thu, 29 April 2004 06:43   |
Thank you for the response.
In this particular case, the diagram is reacting to resource changes in the
workspace. So I have to handle everything in the refresh of the diagram. The
user is not executing commands to modify the model.
Is there any chance you could modify AbstractEditPart.removeNotify() to see
if the edit part is the source/target of the connection before nulling this
property? This would solve this problem and seems like a reasonable change.
Should I create a bug report?
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c6p27q$2ga$1@eclipse.org...
> Hmm, it looks like all the ties between the connection and the old target
> are not being severed when the connection is re-targeted. I was not able
to
> reproduce this problem in the logic example. Re-targetting an existing
> connection (manually), and then deleting the old target works just fine
> there. You might want to check to see what you're doing differently from
> the logic example. The ConnectionCommand in the logic example detaches
the
> old target first (thus severing all ties) in its execute() method. Make
> sure you are doing the same.
> "Chris White" <cwhite@ic.net> wrote in message
> news:c6on47$l2c$1@eclipse.org...
> > I thought I should give a better explanation of this problem.
> > Say I have an diagram edit part that has two children with a connection
> > between them.
> > [X]----C--->[Y]
> > So now the model changes and X now connects to Z instead of Y (Y is
gone):
> > The model behind the connection part is the same model object.
> > [X]----C--->[Z]
> > When the diagram is refreshed the new edit part for Z is created and the
C
> > connection edit part has its target set to Z. The refreshChildren method
> > then removes the unneeded edit part for Y. As part of the removal it
sets
> > the target of C to null. So the connection ends up pointing to nowhere.
> > There is probably something I should be doing to avoid this problem but
I
> > don't know what it is. For now, I have had to override removeNotify to
get
> > around the problem. Basically, the edit part only sets the source or
> target
> > of the connection to null if it is the current source or target.
> > public void removeNotify()
> > List conns;
> > conns = getSourceConnections();
> > while (conns.size() > 0) {
> > ConnectionEditPart cep = (ConnectionEditPart)conns.get(0);
> > if (cep.getSource() == this) {
> > cep.setSource(null);
> > } else {
> > fireRemovingSourceConnection(cep,
> > getSourceConnections().indexOf(cep));
> > primRemoveSourceConnection(cep);
> > conns = getTargetConnections();
> > if (cep.getTarget() == this) {
> > cep.setTarget(null);
> > } else {
> > fireRemovingTargetConnection(cep,
> > getTargetConnections().indexOf(cep));
> > primRemoveTargetConnection(cep);
> > super.removeNotify();
> > news:c6nci8$tno$1@eclipse.org...
parts
children
> > are
> > method)
> > behavior?
Re: Retargeted connections problem [message #129759 is a reply to message #129348] |
Thu, 29 April 2004 11:49   |
The problem is that you are refreshing (reconciling) the children, but you
are not reconciling the connections properly. At some point in your
execution and model notification, you have said that Z is the target of C,
at the same time that Y is the target of Z. Connections are managed by
their nodes in GEF. So we currently require that a node release its link to
a connection before another node assumes the same link (whether source or
target). Most models should work the same way. If you have modeled the
connections similarly (multiplicity of 1), then a connection can only have a
single target. When it's target is set to something new, it should go to
its old target an unhook itself. This is the way EMF bidirectional
reference work. And their notification, even if it is batched, will come in
the correct order which reflects the changes made in the model.
What are the specifics of your model and how it notifies to editparts?
During this resource change, why don't you just reload the entire diagram?
> between them.
> [X]----C--->[Y]
> So now the model changes and X now connects to Z instead of Y (Y is gone):
> [X]----C--->[Z]
> When the diagram is refreshed the new edit part for Z is created and the C
> then removes the unneeded edit part for Y. As part of the removal it sets
> There is probably something I should be doing to avoid this problem but I
> don't know what it is. For now, I have had to override removeNotify to get
target
> List conns;
> } else {
> } else {
> are
> method)
> behavior?
Re: Retargeted connections problem [message #129817 is a reply to message #129759] |
Thu, 29 April 2004 14:20   |
Randy,
Here is what's happening in our application:
We open our diagam/editor and set its contents based on the state of a
number of resources. At this point Y is a target of C.
The user then makes a modification to some resources (e.g. changes the
target of C so that it points to Z and deletes Y). All of these changes can
happen outside our editor. Our editor is notified of the change and attempts
the refresh. The refreshChildren method detects the new model object Z and
gets its connections. It also knows that the old edit part has to be
deleted. So at this point, both the model and the edit parts/connections are
correct. The only thing left is the cleanup of the deleted edit parts.
But as you pointed out, the old edit part still exists and still knows about
its source and target connections. When it cleans up the old edit part it
sets the target of the connection to null.
It seems reasonable to me that the edit part should not set the source/targt
to null if the source/target are not the edit part.
We do reload the entire diagram. We listen for
IResourceChangeEvent.POST_AUTO_BUILD event then reload the diagram. Since
the model for the connection is often the same model object, this edit part
is not recreated.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c6r7qs$dq1$1@eclipse.org...
to
a
in
> > between them.
> > [X]----C--->[Y]
gone):
> > [X]----C--->[Z]
C
sets
I
get
> target
> > List conns;
> > } else {
> > } else {
parts
children
> > are
> > method)
> > behavior?
Re: Retargeted connections problem [message #129830 is a reply to message #129759] |
Thu, 29 April 2004 14:31   |
Randy,
I just realized your post suggests another solution. It sounds like you are
suggesting that I override AbstractConnectionEditPart.setTarget(...) so that
it unhooks from the current target of the connection. I am assuming that I
would do this by calling primRemoveSourceConnection().
Is this what you were suggesting?
to
a
in
> > between them.
> > [X]----C--->[Y]
gone):
> > [X]----C--->[Z]
C
sets
I
get
> target
> > List conns;
> > } else {
> > } else {
parts
children
> > are
> > method)
> > behavior?
Re: Retargeted connections problem [message #129944 is a reply to message #129817] |
Thu, 29 April 2004 18:17   |
news:c6rd84$ko7$1@eclipse.org...
> Randy,
can
attempts
are
> correct.
I would argue that the connections are not correct. Y should have called
refreshTargetEditParts prior to Z's becoming the target of the connection.
Even though Y is going to be deleted, you haven't deleted it yet, so it is
still the target. A similar scenario is reparenting. The old editpart in
the old parent must be deleted before the new editpart (for the same model
object) is created in the new parent. Otherwise, connection will break
there too.
about
source/targt
Possibly, or AbstractConnectionEditPart.setTarget(EditPart) could throw an
exception if you are overwriting the existing target, which should have
removed itself.
part
> is not recreated.
you
C,
link
> to
or
have
> a
to
come
> in
diagram?
connection
> > > between them.
> > > [X]----C--->[Y]
> gone):
> > > [X]----C--->[Z]
the
> C
method
> sets
nowhere.
but
> I
> get
> > target
> > > List conns;
> > > } else {
> > > } else {
> parts
> children
> > > are
parts.
> > > method)
> > > behavior?
Re: Retargeted connections problem [message #129956 is a reply to message #129830] |
Thu, 29 April 2004 18:18   |
You need to be careful or you connection will be activated twice, and you
will have listener leaks.
news:c6rdrt$lgf$1@eclipse.org...
> Randy,
are
that
you
C,
link
> to
or
have
> a
to
come
> in
diagram?
connection
> > > between them.
> > > [X]----C--->[Y]
> gone):
> > > [X]----C--->[Z]
the
> C
method
> sets
nowhere.
but
> I
> get
> > target
> > > List conns;
> > > } else {
> > > } else {
> parts
> children
> > > are
parts.
> > > method)
> > > behavior?
Re: Retargeted connections problem [message #132489 is a reply to message #129944] |
Mon, 17 May 2004 18:13   |
One more try here and then I will give up.
I have run into this problem again with another model.
In this model, the links are managed by a parent model object. The child
model objects don't know about the links. We are using edit parts to make
the connection by asking the parent model object for the appropriate
connections.
When we retarget a connection, we simply change the model link to reflect
the correct connection. Of course, we run to a problem when GEF removes the
connection edit part from the old source/target.
Again, this would all work fine if the connection edit part did not set its
source/target to null if the source/target is not the edit part that is
removing the connection.
Going into begging mode: Please, oh please, can you make this change?
news:c6ruh1$8nv$1@eclipse.org...
> > Randy,
> can
> attempts
and
> are
> > correct.
> there too.
> about
it
> source/targt
> removed itself.
Since
> part
> > is not recreated.
> you
of
> C,
by
> link
> > to
> or
the
> have
> > a
> to
> come
> > in
> diagram?
> connection
> > > > between them.
> > > > [X]----C--->[Y]
> > gone):
> > > > [X]----C--->[Z]
> the
> > C
> method
> > sets
> nowhere.
> but
> > I
to
> > get
> > > target
> > > > List conns;
> > > > } else {
> > > > } else {
existing
> > parts
> > children
> > > > are
> parts.
refreshChildren
> > > > method)
> > > > behavior?
Re: Retargeted connections problem [message #132821 is a reply to message #132489] |
Tue, 18 May 2004 18:18   |
We have made this change for you, but one more try and I will give up too.
The notification is happening out of order, even in this new case you
present. Some parent object holds all connections, which have a source and
target property. When you overwrite one of these properties, you should
first notify the old node that it is no longer the source of the connection,
and it will call refresh..., then notify the new node.
A similar scenario is adding a figure to a new parent. Even though you do
not first remove the figure from its previous parent, there is no time at
which you can find the figure in both old and new parent's children Arrays.
I believe the notification is also consistent.
news:c8b9li$75e$1@eclipse.org...
> connections.
the
its
> > > Randy,
changes
> > can
> > attempts
> and
parts/connections
> > are
> > > correct.
called
connection.
is
in
model
> > there too.
> > about
> it
> > source/targt
an
> > removed itself.
> Since
> > part
> > > is not recreated.
but
> > you
> of
> > C,
> by
> > link
> > > to
source
> > or
> the
only
> > have
> > > a
go
> > to
> > come
> > > in
editparts?
> > diagram?
> > connection
> > > > > between them.
> > > > > [X]----C--->[Y]
is
> > > gone):
> > > > > [X]----C--->[Z]
and
> > the
> > > C
> > method
it
> > > sets
> > nowhere.
problem
> > but
> > > I
removeNotify
> to
> > > get
or
> > > > target
> > > > > List conns;
> > > > > } else {
> > > > > } else {
> existing
edit
> > > parts
> > > children
> > > > > are
> > parts.
> refreshChildren
> > > > > method)
this
> > > > > behavior?
Re: Retargeted connections problem [message #133225 is a reply to message #132821] |
Thu, 20 May 2004 09:13   |
Randy,
Thank you very much for taking a shot at this.
I want to make sure that I understand the issues. I am still very green at
using GEF.
I am about to display the depth of my ignorance. When you say that I should
notify the old node that it is no longer the source of the connection, what
method are you suggesting I call on the old node/edit part to do this? I
have been relying on getModel(X)Connections to provide the correct set of
node connections but of course this is the source of the whole problem. I
think that once I understand how to do this I should be able to keep the
edit part containment and connection endpoints consistent.
The rest of this post describes some of the workarounds that I am using. I
am assuming that the changes you are making are similiar. Let me know if I
am missing the target.
I have made two changes in my edit part hieracrchy for various editors that
provide a termporary fix:
1) Overrrode removeSourceConnection and removeTargetConnection to check
ownership of the source/target. Sample below
protected void removeSourceConnection(ConnectionEditPart connection) {
fireRemovingSourceConnection(connection,
getSourceConnections().indexOf(connection));
if (connection.getSource() == this) // make sure we own the connection
source
connection.deactivate();
connection.setSource(null);
primRemoveSourceConnection(connection);
2) Overrrode removeNotify to perform the same check.
List conns;
if (cep.getSource() == this) // make sure we own the connection
source
else
These changes may be redundant. I made them in two separate diagram editors.
By making these changes, I no longer had connection that ended up with null
sources and targets. I obviosuly had to clone and tweak the entire super
class method implementation (not a good long term solution).
I think I and beginning to understand some of what you have been pointing
out. You are saying that at no time should an edit part or figure be
contained by more than one parent. Because of the nature of my use cases
this is difficult to acheive. It seems like you have the framework in place
to relax this restriction. The refreshChildren method seems to do a good job
of cleaning up an edits part's chidlren. The code just needs to allow
connection end points and the parent to be taken over by other edit parts.
I'm sure I'm under-estimating the effort required to allow this behavior.
I guessI have been thinking of the GEF edit part containment like a tree
viewer content provider. Even if my model does not support parented
behavior, I can use the content provider to make it appear like it does. I
can also rely on a complete refresh to correctly recalculate the tree
content.
news:c8e1lc$k4e$1@eclipse.org...
and
connection,
Arrays.
make
> > connections.
reflect
> the
> its
> > > > Randy,
a
the
> changes
> > > can
> > > attempts
Z
> > and
> parts/connections
> > > are
> > > > correct.
> called
> connection.
it
> is
editpart
> in
> model
break
> > > there too.
knows
> > > about
part
> > it
> > > source/targt
throw
> an
have
> > > removed itself.
> > Since
edit
> > > part
> > > > is not recreated.
> but
> > > you
your
target
> > of
> > > C,
managed
> > by
its
> > > link
> > > > to
> source
> > > or
modeled
> > the
> only
> > > have
> > > > a
should
> go
> > > to
bidirectional
will
> > > come
> > > > in
> editparts?
> > > diagram?
> > > connection
> > > > > > between them.
> > > > > > [X]----C--->[Y]
> is
> > > > gone):
> > > > > > [X]----C--->[Z]
> and
> > > the
> > > > C
refreshChildren
> > > method
removal
> it
> > > > sets
> > > nowhere.
> problem
> > > but
> > > > I
> removeNotify
> > to
> > > > get
source
> or
> > > > > target
> > > > > > List conns;
> > > > > > } else {
> > > > > > } else {
> > existing
> edit
> > > > parts
the
> > > > children
> > > > > > are
> > > parts.
> > refreshChildren
> > > > > > method)
> this
> > > > > > behavior?
Re: Retargeted connections problem [message #135430 is a reply to message #133225] |
Tue, 01 June 2004 15:40  |
> using GEF.
should
what
notification probably requires your own "listener" api. If you have a
single "domain" notifier, then you can reroute notification to editparts,
again you may need them to expose additional methods so you can route the
type of change to the editpart.
But, once your editpart gets the method call, it can call
refreshSourceConnections(), or it call call directly
removeSourceConnection(), and addSourceConnection(). These other 2 methods
are more direct and faster. but the point was that the old source editpart
do this first, followed by the new source. The triggers are specific to
your application
Current Time: Sun Jul 20 05:52:16 EDT 2025
Powered by FUDForum. Page generated in 0.12463 seconds
