JVE log [message #129276] |
Fri, 28 July 2006 16:00  |
Are there any log, trace files that VE parses those composites. The
reason I looked for the log/trace is because my composite doesn't show up
in VE, and if I hover the mouse over it, it shows this warning message :
xxxx : java.lang.RuntimeException(null)
where xxx is the attribute that I am trying to set on my composite.
Thanks.
Re: JVE log [message #129350 is a reply to message #129299] |
Sun, 30 July 2006 16:07   |
Thanks Rich,
The log didn't show those exceptions, however, I was able to figure out
why there was the java.lang.RuntimeException(null).
There's still one exception when hover the mouse over my composite in VE.
It gives ClassNotFoundException. Here is an example of generated code
when drop from Palette.
private void createMyComposite()
myComposite = new MyComposite(this,SWT.NONE);
myComposite.setMyProperty(new MyProperty(2)); // @jve
VE complains that MyProperty class is not found. I have tried to extend
"org.eclipse.jem.proxy.contributors" to add my jars to VE JRE's classpath,
but no luck. Because of this exception, my composite doesn't render in VE
at all.
However, if I modified the code something like this, close and edit the
file again, it magically displays in VE.
try
catch ( Exception e )
Re: JVE log [message #129362 is a reply to message #129350] |
Mon, 31 July 2006 14:17  |
I got it to work by specify the whole qualified classname, ie:
myComposite.setMyProperty(new myPackage.myProperty(2));
Thanks.
Hung Lam wrote:
> Thanks Rich,
> VE. It gives ClassNotFoundException. Here is an example of generated
> code when drop from Palette.
> extend "org.eclipse.jem.proxy.contributors" to add my jars to VE JRE's
> classpath, but no luck. Because of this exception, my composite doesn't
> render in VE at all.
> try
Re: JVE log [message #613616 is a reply to message #129276] |
Fri, 28 July 2006 17:25  |
Try the workspaces .metadata/.log file.
> up in VE, and if I hover the mouse over it, it shows this warning message :
> Thanks.
Rich Kulp
Re: JVE log [message #613632 is a reply to message #129299] |
Thanks Rich,
at all.
try
Re: JVE log [message #613638 is a reply to message #129350] |
Thanks.
Hung Lam wrote:
> Thanks Rich,
> try
FUDForum. Page generated in 0.04164 seconds
