problems starting eclipse M6 [message #129226] |
Mon, 22 December 2003 15:54  |
Hi.
I installed a fresh copy of eclipse 3.0M6 in a windows XP PRO environment.
However when I tried to run eclipse, I got a blank screen. Inspecting the
..log file, I found the following:
!SESSION Dec 22, 2003
18:45:56.798 ---------------------------------------------
java.version=1.4.2_01
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 4 13 Dec 22, 2003 18:45:56.828
!MESSAGE Unable to locate application extension:
org.eclipse.ui.ide.workbench
!STACK 0
java.lang.RuntimeException: Unable to locate application extension:
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:205)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Am I doing something wrong?
Thanks.
[]Jose Vilmar Estacio de Souza
+55 21 2556-7903
21 9325-8042
Re: problems starting eclipse M6 [message #134602 is a reply to message #129226] |
Wed, 14 January 2004 08:36  |
Originally posted by: heger.geomi.com
i have the exact same problem when i try to start up for the first time, i
get this:
!SESSION Jan 14, 2004
14:14:25.68 ----------------------------------------------
java.version=1.4.1_02
!ENTRY org.eclipse.core.runtime 4 13 Jan 14, 2004 14:14:25.68
org.eclipse.update.core.reconciler
!STACK 0
at
java:205)
at
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
well.. that concludes M6 testing for now :)
FUDForum. Page generated in 0.03017 seconds
