Home » Eclipse Projects » e(fx)clipse » MPart lifecycle class(How to use the lifecycle class of an MPart?)
MPart lifecycle class [message #1288322] Tue, 08 April 2014 09:10 Go to next message
I'm trying to use the lifecycle support for MParts as described here.
What I don't quite understand is how this differs from using the @PostConstruct and @PreDestroy annotations. And I don't have a good idea of what a lifecycle class could look like. Is there an example of such a class somewhere?
Uwe
Re: MPart lifecycle class [message #1288357 is a reply to message #1288322] Tue, 08 April 2014 09:46 Go to previous messageGo to next message
If you return false from the LF-handler you veto the closing of the
part/perspective/window
You can find an example in the testcases e.g. you are not able to close
the first tab at all. We'll probably revamp the lifecycle support in 1.0
to be model based now that the platform has chose to go a different
route we proposed.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=398837 on our proposal
and how the platform will most likely implement it using in/out data on
the event-bus - crazy I know!
Tom
On 08.04.14 15:10, Uwe San wrote:
> http://wiki.eclipse.org/Efxclipse/Runtime/e4#Lifecycle.
> class somewhere?
> Uwe
Re: MPart lifecycle class [message #1288405 is a reply to message #1288322] Tue, 08 April 2014 10:34 Go to previous messageGo to next message
Thanks for pointing me at the test case.
What approach would you recommend for loading resources into an MPart after this MPart was rendered? The org.eclipse.fx.ui.lifecycle.annotations package does not seem to provide any annotations for that, and @PostConstruct does not really seem to fit either.
Re: MPart lifecycle class [message #1288413 is a reply to message #1288405] Tue, 08 April 2014 10:38 Go to previous messageGo to next message
What do you mean with resources? I need to know more about your use case.
Tom
> either.
Re: MPart lifecycle class [message #1289252 is a reply to message #1288322] Wed, 09 April 2014 02:58 Go to previous messageGo to next message
I meant resource loading operations that can potentially consume a longer amount of time like querying a database or accessing files over a network. A use case could be a table view that is rendered on screen before its content was fully loaded.
Re: MPart lifecycle class [message #1290505 is a reply to message #1289252] Thu, 10 April 2014 03:14 Go to previous messageGo to next message
We currently don't have support for doing things async and report
progress so this is something you need to init in your post-construct
manually.
Eclipse-Core has a Job-API and JavaFX itself also has some Threading-API
so you most likely will use one of the the 2.
Having an e4 service - including e.g. a ProgressView /
Progress-Reporting e.g. in the Bottom-Trim - would make up a nice
contribution ;-)
Tom
Re: MPart lifecycle class [message #1290519 is a reply to message #1290505] Thu, 10 April 2014 03:29 Go to previous message
Thomas Schindl wrote on Thu, 10 April 2014 03:14
contribution Wink
That's good to know. Wink
Previous Topic:How do configure ANT PDE build for plugin which consumes e(fx)clipse runtime
Next Topic:e(fx)clipse nightly are based on Luna
Current Time: Sat Jul 19 21:04:47 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
