OSGI BundleActivator cannot be resolved [message #128946] |
Sat, 20 December 2003 15:07  |
Originally posted by: schmerl+gef.cs.cmu.edu
Moving to M6, my plugin no longer compiles. The plugin.java file is flagged
with the following error:
The type org.osgi.framework.BundleActivator cannot be resolved. it is
indirectly referenced from required .class file.
I have the OSGI jars selected in my target plaform. What more do I need to
do?
Any help would be greatly appreciated.
Bradley.
Re: OSGI BundleActivator cannot be resolved [message #130297 is a reply to message #130216] |
Mon, 29 December 2003 01:11  |
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:bsmpuh$ne4$1@eclipse.org...
> "Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
> news:bslega$nkj$1@eclipse.org...
> > I could be wrong but I believe this is only a problem for those of us
> > following along with the 3.0M* versions - somebody converting directly
> from
> > 2.1.x shouldn't have to do that manually.
> I'm not sure what you mean here. On our end, we are keeping our plugins
> compatoble with Eclipse 2.0, 2.1 and 3.0 simultaneously.
That's a nice trick; I remember a posting you made about that a while back.
I see that you're going to be presenting something on this at EclipseCon
(www.eclipsecon.org) and I'm looking forward to it.
However, I expect most plug-in developers (esp. non-commercial ones) will
still target only one major version of Eclipse. When you bring a 2.1 plug-in
into 3.0 there's a wizard to convert it, making it incompatible with 2.1.
One of the things this wizard should do is insert any new necessary
dependencies. Since I converted my plug-ins early in the 3.0M* cycle, I
didn't get the benefit of that (even M6 doesn't completely do it). But
somebody converting directly from 2.1.x production to the production 3.0
hopefully won't have the problems.
Ed
FUDForum. Page generated in 0.06042 seconds
