Home » Eclipse Projects » Remote Application Platform (RAP) » ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out
ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128588] Mon, 20 April 2009 04:44 Go to next message
why are these actions commented out? I want to retarget these actions to by
used by my view!
Markus
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128614 is a reply to message #128588] Mon, 20 April 2009 04:54 Go to previous messageGo to next message
Hi Markus,
these were completely commented out as the default implementation can't
be supported at the moment.
CUT,COPY and PASTE are using the clipboard which is not yet available in
RWT and may never be available due to browser restrictions.
ABOUT is based on the whole Equinox product story which is not yet ready
to be used on the server-side. We're investigating this at the moment.
PRINT doesn't make much sense at the moment as we only have the Display
implementation of device. I'm not sure if it makes sense to support this
in the same way as RCP does or if it's even possible to have an
alternative implementation behind the scenes.
But I see your point that you want to retarget the action with your own
implementation. This is a valid apporach and should be discussed
further. Do you want to open a feature request?
Just for your information: We will not be able to do this for 1.2 as we
already have API freeze.
Cheers
Benny
Markus Krüger wrote:
> used by my view!
> Regards,
> Markus
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128652 is a reply to message #128614] Mon, 20 April 2009 05:15 Go to previous messageGo to next message
Thanks for the fast answer.
I know that the default behavior will not work, but retarget should be
possible.
I added a feature request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=272867
For the meantime, is it possible, to just comment the code in, or would this
lead to errors?
This way I could retarget these actions.
Ragards,
Markus
"Benjamin Muskalla" <bmuskalla@eclipsesource.com> schrieb im Newsbeitrag
news:gshd8i$k11$1@build.eclipse.org...
> Hi Markus,
> these were completely commented out as the default implementation can't be
> implementation. This is a valid apporach and should be discussed further.
> Cheers
> Benny
> Markus Kr
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128666 is a reply to message #128588] Mon, 20 April 2009 05:22 Go to previous messageGo to next message
> used by my view!
RAP does not provide API that it does not support. These actions are not
yet available in RAP.
Ralf
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128745 is a reply to message #128666] Mon, 20 April 2009 06:16 Go to previous messageGo to next message
What would be an appropriate workaround?
"Ralf Sternberg" <rsternberg@eclipsesource.com> schrieb im Newsbeitrag
news:gshetf$uj4$1@build.eclipse.org...
> Markus Kr
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128943 is a reply to message #128745] Mon, 20 April 2009 11:19 Go to previous message
Markus,
I assume, you want to single-source the code with RCP. In this case,
have a look at the general single-sourcing practices here:
http://www.eclipse.org/rap/singlesourcing.php
If single-sourcing is not an issue for you, why not just create your
own actions?
HTH
Rüdiger
>>> by
>>> used by my view!
>> Ralf
Previous Topic:Eclipse Apogee (Nuxeo) and RAP
Next Topic:External UIThread access
Current Time: Sat Jul 19 19:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.04129 seconds
