Problems getting TPTP to work [message #128319] |
Fri, 11 April 2008 06:51  |
Originally posted by: MacAdam.eden.invalid
In the search for the causes of a memory leak I wanted to try out TPTP.
I downloaded the runtime for TPTPT-4.4.1, and installed the zipfile to
the parent directory of eclipse (trust me, these files are correctly
placed in D:\eclipse\features and D:\eclipse\plugins).
Next I tried to launch the sample application using the 'launch
profiling' button.
1. I had no 'Profile' choice, but choose 'Open Profile Dialog ...'.
2. In the window that opened, I entered the data for the sample
application in the Main tab. In the Monitor tab I selected 'Memory
Analysis' at 'Java Profiling - JRE 1.5 or newer).
After pressing the 'Profile' button I got a warning window with reason:
"One of the selected launch delegates has failed.
Reason:"
(Note, no reason given!)
This warning had the following details:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10002. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.execution.exceptions.AgentControll erUnavailableException:
Error: Unable to connect to the Agent Controller.Connection refused: connect
at
org.eclipse.tptp.platform.execution.client.core.internal.Nod eImpl.connect(NodeImpl.java:128)
at
org.eclipse.tptp.platform.execution.util.internal.AgentContr ollerFactory$EstablishConnection.run(AgentControllerFactory. java:126)
So what do I need to do to be able to use TPTP?
(And I saw the AgentControllerUnavailableException. But I can not see
what I need to do to get the AgentController to work, beside following
the instructions, and finding out that setConfig.bat can not find JAXP,
which by the way is part of JDK 1.6).
Abel
FUDForum. Page generated in 0.07346 seconds
