Home » Modeling » Papyrus » Writing OCL constraints in a profile
Writing OCL constraints in a profile [message #1281343] |
Mon, 31 March 2014 14:55  |
Dear all,
I'm trying to create a profile in Papyrus and I would like to add
several constraints, i.e., limiting the range in an integer value.
To do so I need to get access to the value of the properties of my profiles.
If I write in the OCL Interactive view in the console it works:
self.getValue(getAppliedStereotype('Profile::Requirement'), 'id') = 4
Nevertheless, if I create an class and then I apply the stereotype and I
right-click to show the context menu and I click in Validation->Validate
Model I get the following error:
Description Resource Path Location Type
An exception occurred while delegating evaluation of the 'Constraint1'
invariant on 'Requirement -> <<Requirement>> <Class> Class1':
org.eclipse.ocl.common.internal.delegate.OCLDelegateException: Errors in
'self.getValue(getAppliedStereotype('Profile::Requirement'), 'id') = 4
1: Unresolved Operation
'Profile::Requirement::getValue(getAppliedStereotype('Profile::Requirement'),
'id')' model2.uml /PruebasOCL_Luna Unknown EMF Problem
Could please someone help me to find a workaround?
Kind regards,
Víctor
Re: Writing OCL constraints in a profile [message #1281359 is a reply to message #1281343] |
Mon, 31 March 2014 15:34   |
Support for OCL has been steadily improving (and it's not perfect in
Luna M6).
What version are you using?
You should not need to use the Java API. Rather
self.extension_Requirement.id = 4
will avoid loss of types.
Ed Willink
On 31/03/2014 19:55, "V. López" wrote:
> Dear all,
> profiles.
> I right-click to show the context menu and I click in
> Validation->Validate Model I get the following error:
> in 'self.getValue(getAppliedStereotype('Profile::Requirement'), 'id') = 4
> Kind regards,
> Víctor
Re: Writing OCL constraints in a profile [message #1281453 is a reply to message #1281359] |
Mon, 31 March 2014 18:57   |
Dear Ed,
First, thanks for your quick answer.
I'm using Eclipe Luna M6 and Papyrus 1.0.0v201403121345. Is there a
better combination of tools for OCL support? Should I install something
else?
Writing "self.extension_Requirement.id = 4" doesn't work in the Xtext
OCL console. Moreover, it isn't recognized properly in the editor of the
constraint, extension_Requirement doesn't show in the autocomplete feature.
I have attached a tiny project with a single stereotype and a single
class where this issue appears, in case it helps.
Víctor
El 31/03/2014 21:34, Ed Willink escribió:
> Hi
> Luna M6).
> Regards
> Ed Willink
>> Dear all,
>> profiles.
>> Kind regards,
>> Víctor
Attachment: Test_OCL.zip
(Size: 6.41KB, Downloaded 128 times)
Re: Writing OCL constraints in a profile [message #1282446 is a reply to message #1281453] |
Wed, 02 April 2014 06:11  |
This looks rather related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=431638 where I've
discovered that the UML support is getting very confused as to whether
it is working in the OMG-UML/Eclipse-UML namespace. The console support
seems to have a further confusion by converting to the Pivot model
prematurely.
I hope to have this fixed soon.
Ed Willink
On 31/03/2014 23:57, "V. López" wrote:
> Dear Ed,
> something else?
> the constraint, extension_Requirement doesn't show in the autocomplete
> feature.
> Regards,
> Víctor
>> Hi
>> Luna M6).
>> Regards
>> Ed Willink
>>> Dear all,
>>> profiles.
>>> 'id') = 4
>>> Kind regards,
>>> Víctor
Current Time: Sun Jul 20 14:07:29 EDT 2025
Powered by FUDForum. Page generated in 0.06567 seconds
