Home » Newcomers » Newcomers » Eclipse Class.forname() function(How to use class.forname() for a class having parameterized constructor)
Eclipse Class.forname() function [message #1281968] Tue, 01 April 2014 13:11 Go to next message
I have used class.forname() function for creating objects dynamically in eclipse. But for paramaterized constructor i had to class.getconstructor function() for which i need to know the datatypes of constructors.
So, i want to know the way of getting datatypes directly in constructor and use them in class.forname() and class.getconstructor().
This is code which i hv used:
public class ClassOne {
public static void main(String[] args) throws ClassNotFoundException, NoSuchMethodException, InstantiationException, IllegalAccessException, IllegalArgumentException, InvocationTargetException {
int param1 = 20;
String className = "ClassTwo";
Class cl = Class.forName(className);
Constructor con = cl.getConstructor(int.class);
Object xyz = con.newInstance(param1);
System.out.println(((ClassBase)xyz).getA());
Re: Eclipse Class.forname() function [message #1282142 is a reply to message #1281968] Tue, 01 April 2014 19:12 Go to previous message
> function() for which i need to know the datatypes of constructors. So, i
> int param1 = 20;
Siddharth
This is pretty just a Java reflection question, isn't it? It's got
nothing to do with Eclipse. You might try javaranch.com, jguru.com or
stackoverflow.com. This forum isn't for what you do with Eclipse, but
how you use Eclipse and trouble using it.
Cheers.
Previous Topic:Apache ODE in eclipse throws sql exception after start
Next Topic:Re: HelloWorld/src
Current Time: Sat Jul 19 15:30:46 EDT 2025
Powered by FUDForum. Page generated in 0.09528 seconds
