Home » Archived » Visual Editor (VE) » VE problem after eclipse updates
VE problem after eclipse updates [message #128070] Sun, 09 July 2006 06:45 Go to next message
Originally posted by: charles.abela.gmail.com
first i hope that I am posting to the correct newsgroup.
I have updated eclipse after which I could not modify the visual classes I
had developed in a project through the visual editor.
Any ideas are appreciated.
Charlie
Re: VE problem after eclipse updates [message #128083 is a reply to message #128070] Sun, 09 July 2006 09:46 Go to previous messageGo to next message
Charlie,
The classes won't open in the VE, or they're not displayed correctly in
the VE? What version of Eclipse did you install, and did you install to
a clean directory? The recommended way to install is to install Eclipse
3.2 to a clean directory, then use the Update Manager to install VE
(from the Callisto Discovery site). If you're just having trouble
opening classes, right click on them and select Open With->Visual Editor.
Hope this helps,
- Jeff
Re: VE problem after eclipse updates [message #128108 is a reply to message #128083] Mon, 10 July 2006 02:02 Go to previous messageGo to next message
What I did was to use the Update Manager to find stuff and updated V
3.1...from this point onwards the visual editor component disappeared.
Charlie
"Jeff Myers" <jeff.myers@eclipse.org> wrote in message
news:e8r1cj$6st$1@utils.eclipse.org...
> Charlie,
> the VE? What version of Eclipse did you install, and did you install to a
> clean directory? The recommended way to install is to install Eclipse 3.2
> to a clean directory, then use the Update Manager to install VE (from the
> Callisto Discovery site). If you're just having trouble opening classes,
> Hope this helps,
> - Jeff
Re: VE problem after eclipse updates [message #128135 is a reply to message #128108] Mon, 10 July 2006 09:42 Go to previous message
Originally posted by: jefmyers.us.ibm.com
Charlie,
Check the .log file in your workspace's .metadata directory for errors.
Probably the best thing for you to do to resolve this issue would be to
install Eclipse 3.2 and use the update manager to install VE.
Hope this helps,
- Jeff
Re: VE problem after eclipse updates [message #613488 is a reply to message #128070] Sun, 09 July 2006 09:46 Go to previous message
Charlie,
Hope this helps,
- Jeff
Re: VE problem after eclipse updates [message #613490 is a reply to message #128083] Mon, 10 July 2006 02:02 Go to previous message
Charlie
> Charlie,
> Hope this helps,
> - Jeff
Re: VE problem after eclipse updates [message #613492 is a reply to message #128108] Mon, 10 July 2006 09:42 Go to previous message
Charlie,
Hope this helps,
- Jeff
Previous Topic:How to delete controls in ve programmatically?
Next Topic:NullPointerException when displaying a visual class
Current Time: Sat Jul 19 10:06:15 EDT 2025
Powered by FUDForum. Page generated in 0.27430 seconds
