Home » Eclipse Projects » EGit / JGit » Execute Aliases From EGit UI
Execute Aliases From EGit UI [message #1277878] Wed, 26 March 2014 11:34 Go to next message
Is there a way to execute a created git alias command from the EGit UI? I have several aliases stored that I execute frequently that would be nice to be able to execute from within eclipse.
I use it mostly for git svn commands, but I could see how this might be helpful for plain git commands too, and would provide a sort of work around for those using git svn to get some desired functionality.
Re: Execute Aliases From EGit UI [message #1278020 is a reply to message #1277878] Wed, 26 March 2014 16:08 Go to previous messageGo to next message
Blake Longmore skrev 2014-03-26 17.51:
You can define "external tools" in Eclipse and they can of course invoke Git
and do whatever C Git does. Using variables like ${git_work_tree}
you can tell these commands which selected resource they should operate on.
-- robin
Re: Execute Aliases From EGit UI [message #1278595 is a reply to message #1278020] Thu, 27 March 2014 11:09 Go to previous messageGo to next message
Thank you for that suggestion. It works great. The only problem is when I try to run a git svn rebase --all, it prompts for my password with the username already populated. My username on my PC is different than my svn username and it appears to be populating the username with my PC username. This works fine if I run it from gitbash, since it prompted me for my username too. It seems a bit strange, since I was able to perform a svn dcommit and it remembered my username/password from my gitbash settings. Is there a way to get this working in the external tools? Thanks.
--EDIT--
I figured out the solution to this latest problem on my own. The answer is to create your external tool with the '--username=' flag set to the username you want to use. This works very nicely now. Thanks again for your help.
[Updated on: Thu, 27 March 2014 15:59] by Moderator
Re: Execute Aliases From EGit UI [message #1279288 is a reply to message #1278595] Fri, 28 March 2014 10:17 Go to previous messageGo to next message
I have a collection of these I made some time ago which you can grab from github:
git@github.com:reshapiro/DVCS.git
Just import the Eclipse projects and the external launchers become available.
Re: Execute Aliases From EGit UI [message #1279337 is a reply to message #1277878] Fri, 28 March 2014 11:48 Go to previous message
For svn bridging you might want to consider using my plugin, which uses the same EGit variables trick but makes the main operations more easily accessible via the Eclipse toolbar and supports other operations in a new Eclipse menu. Install from
http://home.comcast.net/~reshapiro/org.res.gitx/
You might need to turn off the "Group items by category" option. Some users have trouble with this, some don't,
The plugin source code is also available on github.
Previous Topic:Unable to remove .DS_Store from unstaged changes list
Next Topic:EGit with GitBlit
Current Time: Sat Jul 19 23:18:34 EDT 2025
Powered by FUDForum. Page generated in 0.07714 seconds
