Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » The newbie struggle (But still made it).
The newbie struggle (But still made it). [message #127807] |
Fri, 01 August 2008 12:20  |
Dears,
My environment: Eclipse Ganymede, latest EMF.
RCP Application.
MacOSX Leopard
MySQL Database.
Please find some feedback from a "First User".
I am building an RCP application using an EMF generated model.
from .xsd. I decided to try JPOX over Hibernate first.
I followed the instruction on www.elver.org. Which I discovered
as some serious shortcomings in the tutorial for a newbie like me.
I would like to list here, my experience which can be used to update the
tutorial: I managed to get through and connect to the database but it
took 3 days.
1) JPOX libraries
It's not clear which JPOX libraries and versions are needed in the elver
install tutorial.
What should be clarified is the exact require libs and version.
- The JPOX core version
- The JPOX Enhancement version
- The JDO Version. (2.0 or 2.1?).
A newbie is fooled into getting the latest JPOX version which is not
compatible with the examples. (Version 1.1.9 seems to be the correct
one). The JPOX site doesn't link to the JDO site, nor does the elver
install tutorial.
Next, when visiting the JPOX site, I find out there is a JPOX eclipse
plugin. This is mentioned in the elver tutorial, but the tutorial should
also mention, how to configure this plugin or if it's needed at all?
(It doesn't seem to provide the JPOX libraries so what does it do in
relation to the emft/teneo plugin? I can see it contributes wizards for
schema tool.). This plugin when installed is: org.jpox.ide.eclipse.
2) OR mapping
When configuring JPOX, to do auto-enhancement, it turns out an
additional library is needed. BCEL or some other .class enhancer.
This should also be mentioned in the tutorial.
After this, I managed to enable the project for JPOX and generate the
..jdo file. All fine.
The class which are enhanced do generate some warnings, which seem to
be more related to other plugins.
One example:
Aug 1, 2008 5:39:48 PM org.jpox.util.JDK14Logger warn
WARNING: Extension Point "org.eclipse.core.contenttype.contentTypes" not
registered, but plugin "" defined in
jar:file:/Applications/eclipse/plugins/org.eclipse.core.cont enttype_3.3.0.v20080604-1400.jar!/plugin.xml
refers to it.
At the end I still get this:
"JPOX Enhancer completed with success for 6 classes. Consult the log for
full details"
Ok, next I create a database, and add the log.properties and I create
the static class. Unfortunatly the tutorial doesn't tell you how to call
this class from the RCP app. I chose to create a new run-configuration
calling this static class.
I run the class: Get the following (Which all seems good).
Aug 1, 2008 6:04:12 PM org.eclipse.emf.teneo.jpox.JpoxHelper <clinit>
INFO: Registering a jpox resource factory for all uri's with jpox as the
protocol/extension
Aug 1, 2008 6:04:13 PM org.eclipse.emf.teneo.jpox.JpoxHelper <clinit>
INFO: Registering a jpox resource factory for all uri's with ejdo as the
protocol/extension
INFO: Registering a jpox resource dao factory for all uri's with jpoxdao
as the protocol/extension
....and it goes on, finally connecting to the database! Eureka.
Cheers / Christophe
Re: The newbie struggle (But still made it). [message #127847 is a reply to message #127807] |
Sat, 02 August 2008 02:04   |
Hi Christophe,
Thanks for the detailed feedback. See comments inline.
gr. Martin
Christophe Bouhier wrote:
> Dears,
> RCP Application.
> MacOSX Leopard
> MySQL Database.
> took 3 days.
> 1) JPOX libraries
> install tutorial.
MT>> These are exact the same as defined on the jpox website:
http://www.jpox.org/docs/1_1/dependencies.html
See also here: http://www.elver.org/jpox/installation.html#JPOX+Libraries
The hyperlink I use there is not precise enough I will change that to the
one I mention above.
> install tutorial.
MT>> I understand, I will make more clear that Teneo depends on the 1.1.9 release.
(it is listed here: http://www.elver.org/jpox/, but it's a bit hidden)
MT>> My assumption here is that the documentation is provided by jpox.
Afaik jpox/datanucleus has excellent documentation.
MT>> It provides automatic enhancement of your class files when eclipse rebuilds.
> 2) OR mapping
MT>> See the jpox website and remarks above.
> One example:
> refers to it.
MT>> This is a jpox issue.
> full details"
MT>> Correct, it is not a rcp tutorial.
> protocol/extension
> protocol/extension
MT>> That's good, thanks again for the time/effort you took to write this up.
I will update the Teneo/elver.org website to be more precise were required.
> Cheers / Christophe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: The newbie struggle (But still made it). [message #127861 is a reply to message #127847] |
Sun, 03 August 2008 05:44   |
--------------010703040000010308010506
Hi Martin,
Thank you for pointing out the JPOX dependencies page.
I understand that you don't want to repeat instructions from
JPOX or eclipse. I feel though if like me, you come
from J2SE background, with no previous exposure to JPOX,
it's very overwhelming at first, and you and up jumping
between the sites (elver, jpox, jdo, eclipse emf) to put the puzzle
together. This is not in Teneo's favor.
I can imagine (Or I would wish for), that the EMF tutorials at some
point would actually also generate the persistence side, and
do it for you a-z. This would be a huge accomplishment, and push EMF
persistence forward by a big leap. For me it's been a frustrating
experience.
To continue to report my experience, as I moved along a bit.
I went on to try out to Library Editor tutorial, but unfortunately
ran into this class loading problem. (JPOX being in a separate plugin
looking for classes).
The Buddy-Policy hint doesn't seem to help. (Actually also on the elver
tutorial, it's not precise enough how it should be set).
I also tried with Hibernate, the Hibernate tutorial went well. It seems
that hibernate is somehow smarter than jpox. It doesn't need a separate
plugin for enhancement/schema generation or .jdo or class enhancements?
(Or it all happens under the cover). Is it safe to say that hibernate is
a better choice from this perspective?
When running the hibernate library editor tutorial, I also ran into the
same classloading problem.
I tried this pointer: http://www.hibernate.org/311.html, without success.
So here I am, both JPOX and Hibernate connect
to the database with my model in a standalone fashion, but not in an RCP
setup with libraries in a separate eclipse plugin.
I post my manifest files here, perhaps this can shed some light?
(Note that I export the packages).
Thanks for the help!
Christophe
stack trace:
With hibernate:
Caused by: java.lang.NoClassDefFoundError: org/hibernate/SessionFactory
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:675)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374 )
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.emf.teneo.hibernate.HbHelper.<clinit>(HbHelper.java:56)
at
com.kualasoft.hatari.hatari.presentation.HatariEditorPlugin$ Implementation.connectHibernate(HatariEditorPlugin.java:151)
Martin Taal wrote:
> Hi Christophe,
> gr. Martin
>> Dears,
>> RCP Application.
>> MacOSX Leopard
>> MySQL Database.
>> the tutorial: I managed to get through and connect to the database but
>> it took 3 days.
>> 1) JPOX libraries
>> install tutorial.
>> install tutorial.
> 1.1.9 release.
>> for schema tool.). This plugin when installed is: org.jpox.ide.eclipse.
> rebuilds.
>> 2) OR mapping
>> One example:
>> not registered, but plugin "" defined in
>> refers to it.
>> for full details"
>> jpoxdao as the protocol/extension
> this up.
>> Cheers / Christophe
name="MANIFEST.MF"
Content-Disposition: inline;
filename="MANIFEST.MF"
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: JPOX 1.1.9 Plug-in
Eclipse-BuddyPolicy: registered
Bundle-SymbolicName: com.kualasoft.jpox_1.1.9
Bundle-Version: 1.0.0
Bundle-Vendor: KUALASOFT
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ClassPath: bcel-5.2.jar,
jdo2-api-2.0.jar,
jpox-1.1.9.jar,
jpox-enhancer-1.1.9.jar,
jpox-rdbms-1.2.2.jar,
mysql-connector-java-5.1.6-bin.jar,
Export-Package: com.mysql.jdbc,
com.mysql.jdbc.exceptions,
com.mysql.jdbc.exceptions.jdbc4,
com.mysql.jdbc.integration.c3p0,
com.mysql.jdbc.integration.jboss,
com.mysql.jdbc.interceptors,
com.mysql.jdbc.jdbc2.optional,
com.mysql.jdbc.log,
com.mysql.jdbc.profiler,
com.mysql.jdbc.util,
javax.jdo,
javax.jdo.datastore,
javax.jdo.identity,
javax.jdo.listener,
javax.jdo.spi,
org.apache.bcel,
org.apache.bcel.classfile,
org.apache.bcel.generic,
org.apache.bcel.util,
org.apache.bcel.verifier,
org.apache.bcel.verifier.exc,
org.apache.bcel.verifier.statics,
org.apache.bcel.verifier.structurals,
org.gjt.mm.mysql,
org.jpox,
org.jpox.api,
org.jpox.cache,
org.jpox.datasource,
org.jpox.enhancer,
org.jpox.enhancer.bcel,
org.jpox.enhancer.bcel.metadata,
org.jpox.enhancer.bcel.method,
org.jpox.enhancer.metadata,
org.jpox.enhancer.tools,
org.jpox.exceptions,
org.jpox.management,
org.jpox.metadata,
org.jpox.plugin,
org.jpox.resource,
org.jpox.sco,
org.jpox.sco.exceptions,
org.jpox.state,
org.jpox.state.jdo,
org.jpox.state.jpa,
org.jpox.store,
org.jpox.store.exceptions,
org.jpox.store.expression,
org.jpox.store.extent,
org.jpox.store.fieldmanager,
org.jpox.store.mapping,
org.jpox.store.poid,
org.jpox.store.query,
org.jpox.store.rdbms,
org.jpox.store.rdbms.adapter,
org.jpox.store.rdbms.columninfo,
org.jpox.store.rdbms.datasource,
org.jpox.store.rdbms.datatype,
org.jpox.store.rdbms.exceptions,
org.jpox.store.rdbms.expression,
org.jpox.store.rdbms.extent,
org.jpox.store.rdbms.fieldmanager,
org.jpox.store.rdbms.key,
org.jpox.store.rdbms.mapping,
org.jpox.store.rdbms.mapping.oracle,
org.jpox.store.rdbms.poid,
org.jpox.store.rdbms.query,
org.jpox.store.rdbms.request,
org.jpox.store.rdbms.schema,
org.jpox.store.rdbms.scostore,
org.jpox.store.rdbms.sqlidentifier,
org.jpox.store.rdbms.table,
org.jpox.store.rdbms.typeinfo,
org.jpox.store.scostore,
org.jpox.util
name="MANIFEST.MF"
Bundle-Name: Hb Plug-in
Bundle-SymbolicName: com.kualasoft.hb
com.mysql.jdbc.log,
org.gjt.mm.mysql,
org.hibernate,
org.hibernate.action,
org.hibernate.bytecode,
org.hibernate.bytecode.cglib,
org.hibernate.bytecode.javassist,
org.hibernate.bytecode.util,
org.hibernate.cache,
org.hibernate.cache.entry,
org.hibernate.cfg,
org.hibernate.classic,
org.hibernate.collection,
org.hibernate.connection,
org.hibernate.context,
org.hibernate.criterion,
org.hibernate.dialect,
org.hibernate.dialect.function,
org.hibernate.dialect.lock,
org.hibernate.engine,
org.hibernate.engine.loading,
org.hibernate.engine.query,
org.hibernate.engine.query.sql,
org.hibernate.engine.transaction,
org.hibernate.event,
org.hibernate.event.def,
org.hibernate.exception,
org.hibernate.hql,
org.hibernate.hql.antlr,
org.hibernate.hql.ast,
org.hibernate.hql.ast.exec,
org.hibernate.hql.ast.tree,
org.hibernate.hql.ast.util,
org.hibernate.hql.classic,
org.hibernate.id,
org.hibernate.id.enhanced,
org.hibernate.id.insert,
org.hibernate.impl,
org.hibernate.intercept,
org.hibernate.intercept.cglib,
org.hibernate.intercept.javassist,
org.hibernate.jdbc,
org.hibernate.jmx,
org.hibernate.loader,
org.hibernate.loader.collection,
org.hibernate.loader.criteria,
org.hibernate.loader.custom,
org.hibernate.loader.custom.sql,
org.hibernate.loader.entity,
org.hibernate.loader.hql,
org.hibernate.lob,
org.hibernate.mapping,
org.hibernate.metadata,
org.hibernate.param,
org.hibernate.persister,
org.hibernate.persister.collection,
org.hibernate.persister.entity,
org.hibernate.pretty,
org.hibernate.property,
org.hibernate.proxy,
org.hibernate.proxy.dom4j,
org.hibernate.proxy.map,
org.hibernate.proxy.pojo,
org.hibernate.proxy.pojo.cglib,
org.hibernate.proxy.pojo.javassist,
org.hibernate.secure,
org.hibernate.sql,
org.hibernate.stat,
org.hibernate.tool.hbm2ddl,
org.hibernate.tool.instrument,
org.hibernate.tool.instrument.cglib,
org.hibernate.tool.instrument.javassist,
org.hibernate.transaction,
org.hibernate.transform,
org.hibernate.tuple,
org.hibernate.tuple.component,
org.hibernate.tuple.entity,
org.hibernate.type,
org.hibernate.usertype,
org.hibernate.util
--------------010703040000010308010506--
Re: The newbie struggle (But still made it). [message #127874 is a reply to message #127861] |
Sun, 03 August 2008 06:57   |
You know sometimes, you write down what you have done and it actually
gives you the opportunity to think it through and have a nice summary.
Now, I my case I actually found that the Manifest files I posted just
this mornging, Are not the same for resp. JPOX and Hibernate. I added a
classpath entry to the Hibernate libraries in the same way as for the
JPOX manifest file, and promptly it worked. Sorry for the noise.
rgds / Christophe
> Hi Martin,
> experience.
> Christophe
> stack trace:
> With hibernate:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> Dears,
>>> RCP Application.
>>> MacOSX Leopard
>>> MySQL Database.
>>> but it took 3 days.
>>> 1) JPOX libraries
>>> install tutorial.
>>> install tutorial.
>> 1.1.9 release.
>> eclipse rebuilds.
>>> 2) OR mapping
>>> One example:
>>> refers to it.
>>> for full details"
>> this up.
>> required.
>>> Cheers / Christophe
Re: The newbie struggle (But still made it). [message #127888 is a reply to message #127861] |
Sun, 03 August 2008 07:02   |
Hi Christophe,
Yes Teneo assumes that you have some knowledge of Jpox or Hibernate. Teneo does not hide
jpox/hibernate. Teneo tries to work inside jpox/hibernate so therefore this assumption.
Regarding the eclipse-buddypolicy. It should be set to dependent, you have registered.
See here, the bold part of the page:
http://www.elver.org/jpox/installation.html#Using+the+runtim e+plugin+in+an+EMF+model+plugin
http://www.elver.org/hibernate/installation.html#Hibernate+L ibraries
Do you mean that from the tutorial I don't refer back to the download & install page? This would
probably/maybe help. Let me know then I can change this.
Correct, Hibernate does not require compile-time enhancement.Hibernate is more widely used by Teneo
users and features follows use. Because of lack of time I did not have time yet to upgrade to the
latest release of Jpox.
gr. Martin
> Hi Martin,
> experience.
> Christophe
> stack trace:
> With hibernate:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> Dears,
>>> RCP Application.
>>> MacOSX Leopard
>>> MySQL Database.
>>> but it took 3 days.
>>> 1) JPOX libraries
>>> install tutorial.
>>> install tutorial.
>> 1.1.9 release.
>> eclipse rebuilds.
>>> 2) OR mapping
>>> One example:
>>> refers to it.
>>> for full details"
>> this up.
>> required.
>>> Cheers / Christophe
The Netherlands
Re: The newbie struggle (But still made it). [message #127988 is a reply to message #127888] |
Tue, 05 August 2008 04:49   |
> have registered.
Yes, changed it but I also set below in the editor plugin. Is this needed?
Eclipse-RegisterBuddy: com.kualasoft.hb
> install page? This would probably/maybe help. Let me know then I can
> change this.
What I mean, is that the exact Hibernate libs are not listed in the
tutorial, when you download hibernate, you get all kind of stuff, which
is not needed for the tutorial.
Also made more progress, I have now loaded a complex .xsd with many
references, and I am able to connect to the database. I do have a
problem that the editor opens read-only. Also I think my setup is not
correct, as I have the following behaviour.
1. I create a new model. .mymodel
2. I write some "required" fields, to be able to save the model.
3. The model is reflected properly in the database. this is all fine.
4. The model is read-only, I can't add child/sible to it.
5. the file I chose when creating the model is not visible on the file
system. This kind of makes sense, as the resource is opened with the
HiberbateResourceFactory. But, how do I re-open my model using the
editor open/open-uri. I tried with the hibernate protocol
hibernate://dsname=something.mymodel, but get an error on this.
I guess, what I need to understand is how the filesystem resources and
hibernate resources can be used in parallel? Or how do I re-open my
hibernate resource in the editor?
any help is most welcome.
Thank you, Christophe.
Re: The newbie struggle (But still made it). [message #128163 is a reply to message #127988] |
Wed, 06 August 2008 07:41   |
Hi Christophe,
I am currently on holiday, I will answer your post tomorrow morning.
gr. Martin
>> have registered.
>> & install page? This would probably/maybe help. Let me know then I can
>> change this.
The Netherlands
Re: The newbie struggle (But still made it). [message #128228 is a reply to message #127988] |
Thu, 07 August 2008 06:14   |
Hi Christophe,
Does this help for the read-only issue:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg04688.html
The registerbuddy is not required in case of buddypolicy dependent.
Regarding your question about the resource. You have to study how EMF resources work and how Eclipse
editors are opened. I don't develop using Eclipse rcp so I can't give you that much information.
Here is an example of the gmf tutorial:
http://www.elver.org/hibernate/gmftutorial/tutorial3.html#Op en+editor+action
gr. Martin
>> have registered.
>> change this.
The Netherlands
Re: The newbie struggle (But still made it). [message #128454 is a reply to message #128228] |
Fri, 08 August 2008 17:59   |
Yes, the adaptorfactory enhancement did the trick.
I can open with Open URI, and a name ending with .mymodel
So all working well, except changes are not reflected. I am not
sure why the SQL databse is not update when reloading a changed .xsd. I
am re-generating the model and edit code and no change in the database.
Is this one of those parameters I need to pass?
Thanks for all your help. I am close to be fully in production with teneo.
Cheers / Christophe
Martin Taal wrote:
> Hi Christophe,
> resources work and how Eclipse editors are opened. I don't develop using
> Eclipse rcp so I can't give you that much information. Here is an
> gr. Martin
>> Hi,
>>> have registered.
>> needed?
>>> can change this.
>> which is not needed for the tutorial.
Re: The newbie struggle (But still made it). [message #128468 is a reply to message #128454] |
Sat, 09 August 2008 05:36   |
Hi Christophe,
Regarding updating the db schema, what value did you set for the hbm2ddl hibernate option?
gr. Martin
> Cheers / Christophe
> Martin Taal wrote:
>> Hi Christophe,
>> using Eclipse rcp so I can't give you that much information. Here is
>> gr. Martin
>>> Hi,
>>> needed?
>>>> download & install page? This would probably/maybe help. Let me know
>>> file system. This kind of makes sense, as the resource is opened with
>>> the HiberbateResourceFactory. But, how do I re-open my model using
>>> the editor open/open-uri. I tried with the hibernate protocol
>>> and hibernate resources can be used in parallel? Or how do I re-open
>>> my hibernate resource in the editor?
The Netherlands
Re: The newbie struggle (But still made it). [message #128482 is a reply to message #128468] |
Sat, 09 August 2008 08:35   |
Martin Taal wrote:
> Hi Christophe,
> hibernate option?
> gr. Martin
>> I am re-generating the model and edit code and no change in the database.
>> teneo.
>> Cheers / Christophe
>> Martin Taal wrote:
>>> Hi Christophe,
>>> gr. Martin
>>>> Hi,
>>>> needed?
>>>> not correct, as I have the following behaviour.
>>>> with the HiberbateResourceFactory. But, how do I re-open my model
>>>> using the editor open/open-uri. I tried with the hibernate protocol
Re: The newbie struggle (But still made it). [message #128494 is a reply to message #128468] |
It's not set at all.
Is 'update' the right value?
Martin Taal wrote:
> Hi Christophe,
> hibernate option?
> gr. Martin
>> teneo.
>> Cheers / Christophe
>> Martin Taal wrote:
>>> Hi Christophe,
>>> gr. Martin
>>>> Hi,
>>>> needed?
Re: The newbie struggle (But still made it). [message #128507 is a reply to message #128494] |
Sun, 10 August 2008 04:02   |
Yes, the hibernate manual also describes some other values which can be relevant in different
situations.
gr. Martin
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> database.
>>> teneo.
>>> Cheers / Christophe
>>> Martin Taal wrote:
>>>> Hi Christophe,
>>>> EMF resources work and how Eclipse editors are opened. I don't
>>>> gr. Martin
>>>>> Hi,
>>>>> needed?
>>>>> re-open my hibernate resource in the editor?
The Netherlands
Re: The newbie struggle (But still made it). [message #128534 is a reply to message #128507] |
Mon, 11 August 2008 02:40   |
Hi Martin,
I am sorry setting:
props.setProperty(Environment.HBM2DDL_AUTO, "update");
doesn't solve the issue.
When I drop the DB and recreate, the changes are applied.
Is there a formal way to migrate a DB to a new schema?
Here is the full code:
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.URL,
"jdbc:mysql://127.0.0.1:3306/icebreaker");
// props.setProperty(Environment.PASS, "root"); Remove to ommit the
password authentication.
props.setProperty(Environment.HBM2DDL_AUTO, "update"); // Use when
the dabase changed?
props.setProperty(Environment.DIALECT,"org.hibernate.dialect.MySQLInnoDBDialect ");
// Initialize create the HbDataStore
HbDataStore hbds = HbHelper.INSTANCE
.createRegisterDataStore("icebreaker");
hbds.setEPackages(new EPackage[] { IcebreakerPackage.eINSTANCE });
hbds.setProperties(props);
hbds.initialize();
rgds / Christophe
> relevant in different situations.
> gr. Martin
Re: The newbie struggle (But still made it). [message #128546 is a reply to message #128534] |
Mon, 11 August 2008 05:34   |
Hi Christophe,
The hbm2ddl update setting adds columns, table and foreign keys. It does not add indexes. So afaics
the setting update should work (it works for me). Can you put on logging and check the log in the
beginning?
See here for logging:
http://www.elver.org/hibernate/troubleshooting.html#runtime
gr. Martin
> Hi Martin,
> I am sorry setting:
> ommit the password authentication.
> Use when the dabase changed?
> hbds.initialize();
> rgds / Christophe
>> be relevant in different situations.
>> gr. Martin
The Netherlands
Re: The newbie struggle (But still made it). [message #128572 is a reply to message #128546] |
Mon, 11 August 2008 08:17  |
Ok, it seems the change I want to make is not reflected, but when
I add a table it indeed works and the new table is added.
The change I was making is a to alter a column to be nullable by adding
minOccurs="0 and this is not reflected.
I guess, I can conclude that alterations to the columns like Index or
null don't work. I presume this is more a Hibernate issue than a teneo
issue.
rgds, Christophe
Martin Taal wrote:
> Hi Christophe,
> not add indexes. So afaics the setting update should work (it works for
> me). Can you put on logging and check the log in the beginning?
> gr. Martin
>> Hi Martin,
>> I am sorry setting:
>> hbds.initialize();
>> rgds / Christophe
>>> gr. Martin
Re: The newbie struggle (But still made it). [message #620171 is a reply to message #127807] |
Hi Christophe,
gr. Martin
> Dears,
> RCP Application.
> MacOSX Leopard
> MySQL Database.
> took 3 days.
> 1) JPOX libraries
> install tutorial.
> install tutorial.
> 2) OR mapping
> One example:
> refers to it.
> full details"
> protocol/extension
> protocol/extension
> Cheers / Christophe
The Netherlands
Re: The newbie struggle (But still made it). [message #620172 is a reply to message #127847] |
Hi Martin,
experience.
Christophe
stack trace:
With hibernate:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Martin Taal wrote:
> Hi Christophe,
> gr. Martin
>> Dears,
>> RCP Application.
>> MacOSX Leopard
>> MySQL Database.
>> it took 3 days.
>> 1) JPOX libraries
>> install tutorial.
>> install tutorial.
> 1.1.9 release.
> rebuilds.
>> 2) OR mapping
>> One example:
>> refers to it.
>> for full details"
> this up.
>> Cheers / Christophe
name="MANIFEST.MF"
jdo2-api-2.0.jar,
jpox-1.1.9.jar,
com.mysql.jdbc.log,
javax.jdo,
javax.jdo.identity,
javax.jdo.listener,
javax.jdo.spi,
org.apache.bcel,
org.gjt.mm.mysql,
org.jpox,
org.jpox.api,
org.jpox.cache,
org.jpox.enhancer,
org.jpox.metadata,
org.jpox.plugin,
org.jpox.resource,
org.jpox.sco,
org.jpox.state,
org.jpox.state.jdo,
org.jpox.state.jpa,
org.jpox.store,
org.jpox.util
name="MANIFEST.MF"
com.mysql.jdbc.log,
org.gjt.mm.mysql,
org.hibernate,
org.hibernate.cfg,
org.hibernate.hql,
org.hibernate.id,
org.hibernate.impl,
org.hibernate.jdbc,
org.hibernate.jmx,
org.hibernate.lob,
org.hibernate.sql,
org.hibernate.stat,
org.hibernate.type,
org.hibernate.util
Re: The newbie struggle (But still made it). [message #620173 is a reply to message #127861] |
rgds / Christophe
> Hi Martin,
> experience.
> Christophe
> stack trace:
> With hibernate:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> Dears,
>>> RCP Application.
>>> MacOSX Leopard
>>> MySQL Database.
>>> but it took 3 days.
>>> 1) JPOX libraries
>>> install tutorial.
>>> install tutorial.
>> 1.1.9 release.
>> eclipse rebuilds.
>>> 2) OR mapping
>>> One example:
>>> refers to it.
>>> for full details"
>> this up.
>> required.
>>> Cheers / Christophe
Re: The newbie struggle (But still made it). [message #620174 is a reply to message #127861] |
Hi Christophe,
gr. Martin
> Hi Martin,
> experience.
> Christophe
> stack trace:
> With hibernate:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> Dears,
>>> RCP Application.
>>> MacOSX Leopard
>>> MySQL Database.
>>> but it took 3 days.
>>> 1) JPOX libraries
>>> install tutorial.
>>> install tutorial.
>> 1.1.9 release.
>> eclipse rebuilds.
>>> 2) OR mapping
>>> One example:
>>> refers to it.
>>> for full details"
>> this up.
>> required.
>>> Cheers / Christophe
The Netherlands
Re: The newbie struggle (But still made it). [message #620181 is a reply to message #127888] |
> have registered.
> change this.
Re: The newbie struggle (But still made it). [message #620195 is a reply to message #127988] |
Hi Christophe,
gr. Martin
>> have registered.
>> change this.
The Netherlands
Re: The newbie struggle (But still made it). [message #620200 is a reply to message #127988] |
Hi Christophe,
gr. Martin
>> have registered.
>> change this.
The Netherlands
Re: The newbie struggle (But still made it). [message #620217 is a reply to message #128228] |
Cheers / Christophe
Martin Taal wrote:
> Hi Christophe,
> gr. Martin
>> Hi,
>>> have registered.
>> needed?
>>> can change this.
Re: The newbie struggle (But still made it). [message #620218 is a reply to message #128454] |
Hi Christophe,
gr. Martin
> Cheers / Christophe
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> Hi,
>>> needed?
The Netherlands
Re: The newbie struggle (But still made it). [message #620219 is a reply to message #128468] |
Martin Taal wrote:
> Hi Christophe,
> hibernate option?
> gr. Martin
>> teneo.
>> Cheers / Christophe
>> Martin Taal wrote:
>>> Hi Christophe,
>>> gr. Martin
>>>> Hi,
>>>> needed?
Re: The newbie struggle (But still made it). [message #620220 is a reply to message #128468] |
Martin Taal wrote:
> Hi Christophe,
> hibernate option?
> gr. Martin
>> teneo.
>> Cheers / Christophe
>> Martin Taal wrote:
>>> Hi Christophe,
>>> gr. Martin
>>>> Hi,
>>>> needed?
Re: The newbie struggle (But still made it). [message #620221 is a reply to message #128494] |
situations.
gr. Martin
> Martin Taal wrote:
>> Hi Christophe,
>> gr. Martin
>>> database.
>>> teneo.
>>> Cheers / Christophe
>>> Martin Taal wrote:
>>>> Hi Christophe,
>>>> gr. Martin
>>>>> Hi,
>>>>> needed?
The Netherlands
Re: The newbie struggle (But still made it). [message #620223 is a reply to message #128507] |
Hi Martin,
I am sorry setting:
the dabase changed?
hbds.initialize();
rgds / Christophe
> gr. Martin
Re: The newbie struggle (But still made it). [message #620224 is a reply to message #128534] |
Hi Christophe,
beginning?
gr. Martin
> Hi Martin,
> I am sorry setting:
> hbds.initialize();
> rgds / Christophe
>> gr. Martin
The Netherlands
Re: The newbie struggle (But still made it). [message #620226 is a reply to message #128546] |
issue.
rgds, Christophe
Martin Taal wrote:
> Hi Christophe,
> gr. Martin
>> Hi Martin,
>> I am sorry setting:
>> hbds.initialize();
>> rgds / Christophe
>>> gr. Martin
Current Time: Sat Jul 19 11:29:10 EDT 2025
Powered by FUDForum. Page generated in 0.09202 seconds
