Home » Eclipse Projects » Eclipse Scout » In table editing questions
In table editing questions [message #1274275] Fri, 21 March 2014 04:17 Go to next message
I have a TableField where all columns have the editable property set to true.
I have five IntegerColumns and one BooleanColumn in my table. When I click into the first IntegerColumn cell I can then move from cell to cell using TAB until I reach the last IntegerColumn. When I then press TAB the focus moves back to the first IntegerColumn of the row, skipping the BooleanColumn containing the checkbox. The only way I can change the value of the BooleanColumn is using the mouse.
Is this intended behaviour or am I missing something?
Another question is the following: In Bug 398283 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=398283) the possibility to have validateOnAnyKey on all fields was added and in Bug 418582 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=418582) the possibility to navigate to the next FormField was added.
Will the validateOnAnyKey also work on Column cells? And is there a possibility to programmatically move the focus to a specific column/cell of a row/table?
Re: In table editing questions [message #1277308 is a reply to message #1274275] Tue, 25 March 2014 16:40 Go to previous messageGo to next message
Urs Beeli wrote on Fri, 21 March 2014 09:17
I am not sure if the Boolean Column can be edited (with a field like the other columns). This kind of limitation goes in the same direction like the error marker in boolean column mentioned here.
With bug 398283, validateOnAnyKey was added to Number and Decimal fields. There is also a getConfiguredValidateOnAnyKey on the number column. Isn't it?
You should try it. I am not sure how it was implemented. I am not sure how
* Control#traverse(SWT.TRAVERSE_TAB_NEXT)
* Control#traverse(SWT.TRAVERSE_TAB_PREVIOUS)
will react in a table...
Re: In table editing questions [message #1277715 is a reply to message #1277308] Wed, 26 March 2014 07:09 Go to previous messageGo to next message
Jeremie Bresson wrote on Tue, 25 March 2014 21:40
Thanks. In that case we'll probably have to use a CodeType<Boolean> and use a SmartColumn instead of the checkbox.
You are right of course. I had looked but must have missed it. Looking again I saw the property.
I'll try it out when I next find a little time. I'll get back to you on this when I've tried it out.
[Updated on: Wed, 26 March 2014 07:10] by Moderator
Re: In table editing questions [message #1278301 is a reply to message #1277715] Thu, 27 March 2014 02:26 Go to previous messageGo to next message
After discussion with Andy Hoegger I created this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=431306
Re: In table editing questions [message #1278553 is a reply to message #1278301] Thu, 27 March 2014 09:46 Go to previous messageGo to next message
Hi Urs,
FYI, I created a bug for the boolean column problem: 431356
Thanks for pointing out the problem.
Matthias
Re: In table editing questions [message #1279023 is a reply to message #1278553] Fri, 28 March 2014 02:13 Go to previous message
Hi Matthias,
I didn't mention the boolean column problem in my last post because Andy has told me that he had already fixed it. I'm not sure about the timing (i.e. if you created your bug after he fixed the issue or if your bug was the reason for him fixing it). Thanks in any case!
Previous Topic:How to get data out of formdata by fieldName
Next Topic:Table drag & drop
Current Time: Sat Jul 19 23:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.26015 seconds
