[EMF Compare] How to deactivate [message #127564] |
Fri, 25 July 2008 15:06  |
Originally posted by: lwrage.sei.cmu.edu
I've installed eclipse-modeling-ganymede-incubation-win32.zip, which
includes EMF compare. How can I turn it off to compare a uml file with
the version on cvs using plain text comparison?
(The 600KB file seems to be too big for EMF compare, it takes more than
five minutes to open the compare editor.)
Lutz
Re: [EMF Compare] How to deactivate [message #127638 is a reply to message #127627] |
Mon, 28 July 2008 08:06   |
The problem is on ganymede:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242219
- Lutz
laurent Goubet wrote, on 7/28/2008 3:54 AM:
> Hi Lutz,
> I tested this in 3.3 and it still seems to work; was your behavior
> observed on ganymede?
> Either way, could you fill in a bugzilla entry so that we know we have
> to provide a way to force a textual comparison (we could probably do it
> by means of a preference or the such)?
> Thanks
> Laurent Goubet
> Obeo
> Lutz Wrage a écrit :
>> I tried it, but it does not work. Even after restarting eclipse, uml
>> files don't use text compare.
>> Preferences->Content Types->EMF Compare
>> *.ecore (locked)
>> *.emfdiff (locked)
>> *.uml (locked)
>> Preferences->Content Types->Text
>> *.uml
>> *.txt (locked)
>> I played a bit with the *.compare.ui plugin.xml and got rid of the
>> locked uml entry, but that didn't help either.
>> - Lutz
>> "Lutz Wrage" <lwrage@sei.cmu.edu> wrote in message
>> news:g6hns0$shl$1@build.eclipse.org...
>>> Thanks!
>>> - Lutz
>>> "laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
>>> news:g6g3mq$se0$2@build.eclipse.org...
>>>> Hi Lutz,
>>>> org.eclipse.compare doesn't provide a way to choose the comparison
>>>> engine to use among those registered. However you should still be able
>>>> to force text comparison :
>>>> http://wiki.eclipse.org/EMF_Compare_FAQ#How_to_force_text_co mparison.3F
>>>> Regards,
>>>> Laurent Goubet Obeo
>>>>> Hi,
>>>>> than
>>>>> Thanks,
>>>>> Lutz
Re: [EMF Compare] How to deactivate [message #127714 is a reply to message #127651] |
Wed, 30 July 2008 04:06  |
--------------050901050907010206000403
Thanks to Lutz input, the most important bottleneck has been eliminated
and UI performances should now be way better than they were. We're still
working on some flickering issues appearing on windows, but this should
be fixed soon.
Laurent Goubet
Obeo
laurent Goubet a
Re: [EMF Compare] How to deactivate [message #620154 is a reply to message #127614] |
Mon, 28 July 2008 03:54  |
--------------020607060608090901070805
Hi Lutz,
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620155 is a reply to message #127627] |
- Lutz
> Hi Lutz,
> Thanks
> Laurent Goubet
> Obeo
>> *.ecore (locked)
>> *.emfdiff (locked)
>> *.uml (locked)
>> *.uml
>> *.txt (locked)
>> - Lutz
>>> Thanks!
>>> - Lutz
>>>> Hi Lutz,
>>>> Regards,
>>>> Laurent Goubet Obeo
>>>>> Hi,
>>>>> than
>>>>> Thanks,
>>>>> Lutz
Re: [EMF Compare] How to deactivate [message #620156 is a reply to message #127638] |
Mon, 28 July 2008 11:07  |
--------------040102030000040900080004
Thanks Lutz.
As a side note, we're currently trying to pinpoint performances issues
we have on some configurations with the opening of the compare editor.
You told that it takes more than five minutes to "open the compare
editor". Could you be more precise as to what takes that much time? Is
it the comparison itself (with the progress monitor showing) or the
opening of the editor after the progress monitor closes up?
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620161 is a reply to message #127651] |
be fixed soon.
Laurent Goubet
Obeo
laurent Goubet a
FUDForum. Page generated in 0.05324 seconds
