Home » Newcomers » Newcomers » Failed to load JNI shared library(Failed to load JNI shared library)
Failed to load JNI shared library [message #1274959] Sat, 22 March 2014 04:23 Go to next message
I cannot get eclipse to start, I keep getting " Failed to load JNI shared library " error followed by the path of jvm.dll, which is where the error says it is. ?
Its a couple of days and I can't seem to get this thing off the ground.
Jim
Re: Failed to load JNI shared library [message #1275145 is a reply to message #1274959] Sat, 22 March 2014 11:36 Go to previous messageGo to next message
Do you have any more details about these messages? It's likely that you have an eclipse version that does not work in your environment or that your eclipse instance is corrupted. I would try downloading a new version and making sure that the version works on your environemnt (ie- architecture + os + windowing toolkit).
Re: Failed to load JNI shared library [message #1275187 is a reply to message #1274959] Sat, 22 March 2014 13:15 Go to previous message
> Jim
You give hardly any detail here, but I suspect that you need to follow
these instructions:
http://wiki.eclipse.org/Eclipse.ini
Previous Topic:Start up error
Next Topic:Parallel Runtime Perspective is missing in Eclipse Kepler
Current Time: Sat Jul 19 19:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.28655 seconds
