Dynamic templates = true causes error when generating model code [message #1272168] |
Mon, 17 March 2014 04:38  |
I use Luna M6. When I set use dynamic templates to true I get the following exception during model code generation:
java.lang.ClassNotFoundException: org.eclipse.emf.codegen.ecore.templates.model.PackageClass_
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper$3.loadClass(JETEmitter.java:835)
at org.eclipse.emf.codegen.jet.JETEmitter$EclipseHelper.initialize(JETEmitter.java:855)
at org.eclipse.emf.codegen.jet.JETEmitter.initialize(JETEmitter.java:391)
at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.java:453)
at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateJava(AbstractGeneratorAdapter.java:1818)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageGeneratorAdapter.generatePackageInterface(GenPackageGeneratorAdapter.java:462)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageGeneratorAdapter.generateModel(GenPackageGeneratorAdapter.java:213)
at org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGeneratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:215)
at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generate(AbstractGeneratorAdapter.java:316)
at org.eclipse.emf.codegen.ecore.generator.Generator.generate(Generator.java:703)
at org.eclipse.emf.codegen.ecore.genmodel.presentation.GeneratorUIUtil$GeneratorOperation.execute(GeneratorUIUtil.java:178)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2333)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
and
I did not put anything in the template directory so it cannot be caused by my templates. How can I find what is going wrong?
Ralph
FUDForum. Page generated in 0.03011 seconds
