Home » Newcomers » Newcomers » Unable to detach views(option is missing from view tab context menus)
Unable to detach views [message #1270250] Wed, 12 March 2014 14:55 Go to next message
I'm having a problem with Eclipse + Java. I am unable to detach a view. I can move it around but it won't detach. A right click on a view tab gives me only three choices in the context menu. "Close", "Close Others" and "Close All". I searched through the settings and unable to find a way to add "Detach" to my context menus. Thanks.
Re: Unable to detach views [message #1271384 is a reply to message #1270250] Fri, 14 March 2014 21:34 Go to previous message
Are you talking about editor windows? Those don't detach. Go to Window
-> New Window. This creates a new workbench with most of the original
workbench's settings. Then you can drag the file you wanted "detached"
into the Edit view of the new workbench.
Warning: If you close the first workbench, your workspace will remember
the (usually inadequate) settings of the new workbench. Don't do that;
remember to kill the new workbench first.
I hope this helps.
Previous Topic:"Open Project" grayed out
Next Topic:Incorporeting database in Swing commponents
Current Time: Sun Jul 20 10:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.28468 seconds
