Home » Eclipse Projects » WindowBuilder » getContentPane() doesn't resize(getContentPane() doesn't resize)
getContentPane() doesn't resize [message #1270850] Thu, 13 March 2014 12:43 Go to next message
I've created a JFrame sized at 1024x768, but when I go into design mode, I cannot view any components outside of the getContentPane() area called for the frame. The pane takes up only a 1/4 of the would be viewable area. When I run, the components show up, but it makes it real difficult to see where I'm placing things in design mode. I can select the contentpane, and when I move to the corner the cursor shows that it wants to resize, but it doesn't. I don't have any setResizable(false) methods called, and I tried manually changing minimum dimensions of the contentpane. Still nothing. Any ideas are appreciated.
Re: getContentPane() doesn't resize [message #1271312 is a reply to message #1270850] Fri, 14 March 2014 16:09 Go to previous message
A code example and a screen shot would be helpful here.
Previous Topic:Data Binding for JFace Table Viewer
Next Topic:Which kind of layout should I use?
Current Time: Sun Jul 20 14:29:12 EDT 2025
Powered by FUDForum. Page generated in 0.04286 seconds
