Linking between two reqif files [message #1267708] |
Sun, 09 March 2014 08:31  |
Hi all,
in my current set-up I would like to have a high-level requirement specification describing my system behaviour. This specification is stored in an eclipse project that does not have any source code. The different software modules of my system are each stored in their own eclipse project. In these projects I would also like to create an ReqIF document that contains the lower level requirements for this software module.
My question: Is it possible to link from the lower level ReqIF files to the high level ReqIF file using ProR/RMF? I've tried it using "initiate linking" in the low level spec and "complete linking from selection" in the higher level spec. At first it looked good in the low level spec, as I could see high level requirement as source and the low level requirement as target. In the high level requirement specification I could see no links at all though. After saving, closing and re-opening the low level specification file, it was still visible that there are links, but the source suddenly was shown as "null" instead of the high level requirement.
I hope it's clear what I want to achieve. It would also be okay for me to create all specification documents in the same ReqIF file, if this feature is not (yet) supported.
Frank
FUDForum. Page generated in 0.04275 seconds
