Home » Archived » Visual Editor (VE) » No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX
No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #126350] Fri, 16 June 2006 11:56 Go to next message
Configuration:
Eclipse build eclipse-SDK-3.2RC6
VE 1.2RC2
EMF build 2.2.0RC6
GEF Build 3.2RC3
Plus the SWT_AWT Compatibility package from Apple.
The VE download page these are the builds that should work together.
Well....
If I open up a workspace of mine with an SWT applet project inside of
it. I can open up the code for it, and the editor tries to load ( still
takes a long time to load on OS X for some reason ). I can see the
palette displaying SWING and even AWT components, but NO SWT components.
Not to mention that I all I see on the design pane of the editor is a
single bean ( sometimes with some info popped up in a tooltip window,
sometimes not ).
Funny thing is if I ask Eclipse to just generate a simple shell of an
applet, VE can't even display THAT !
Am I missing something here ? I thought SWT support in VE was already up
and running under OS X.
Marcelo
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #126363 is a reply to message #126350] Fri, 16 June 2006 12:17 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Does your project have the SWT Library added to it? (not the swt jar,
the Library container). Bring up the properties of the project, switch
to the Java Build Path, Libraries tab. Hit Add Library... and select
the SWT Library.
You can also try creating a new project, then creating a new Visual
Class with the SWT Shell or Composite style. I'm doubtful that an SWT
applet project will be supported in the VE - what's the base class for
your visual class?
Hope this helps,
- Jeff
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #126393 is a reply to message #126363] Fri, 16 June 2006 21:53 Go to previous messageGo to next message
> the SWT Library.
> your visual class?
> Hope this helps,
> - Jeff
Jeff,
Yes it's got the Library container added to the project. The applet was
simply one that was created through the wizard it's your run of the
mill, Shell derived application. Apparently, the issue was that it
wanted more than just the library container. Still apparently I can now
get it to come up. It's a start.
Making menu's isn't possible. I can add a menu bar, but can't drag menu
items to it.
That, and VE must be using a WHOLE LOT of memory, because it ran out of
vm space awfully quick ( the workbench had to restart itself ).
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #126405 is a reply to message #126393] Sat, 17 June 2006 18:30 Go to previous message
You can't graphically edit menus, but you can drop menu items onto the
menu bar in the Java Beans view.
- Jeff
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #613360 is a reply to message #126350] Fri, 16 June 2006 12:17 Go to previous message
the SWT Library.
your visual class?
Hope this helps,
- Jeff
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #613362 is a reply to message #126363] Fri, 16 June 2006 21:53 Go to previous message
> the SWT Library.
> your visual class?
> Hope this helps,
> - Jeff
Jeff,
items to it.
Re: No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX [message #613363 is a reply to message #126393] Sat, 17 June 2006 18:30 Go to previous message
- Jeff
Previous Topic:No SWT Controls ( only bean icon shown ) using VE1.2RC2 on OSX
Next Topic:Nebula question....anyone used this grid ?
Current Time: Sat Jul 19 12:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.04672 seconds
