Home » Modeling » TMF (Xtext) » Unwanted comments in generated Java Code
Unwanted comments in generated Java Code [message #1262302] Mon, 03 March 2014 08:32 Go to next message
I'm using a custom AbtractModelInferrer to generate Java code for my DSL. In a lot of places, I use the newTypeRef method from JvmTypesBuilder to create parameter types, fields types of return types of the classes/methods that I want to generate.
My problem is that half the time, the generated code for the type reference is commented and replaced by a generic Object type. Surprisingly, it only happens when the type reference is a generic type (List<X> or AnyClass<Y>).
As an example, half the time it generates...
public List<ChannelPort> getPort() {
... and the other half:
public /* List<ChannelPort> */Object getPort() {
What surprises me is that if I manually uncomment everything, the generated code compiles. I don't get why Xtext decides to comment this, since everything would work without these comments.
Thanks for your help,
Peter
Re: Unwanted comments in generated Java Code [message #1262400 is a reply to message #1262302] Mon, 03 March 2014 10:48 Go to previous messageGo to next message
how does your inferrer look like? maybe its not always sure if the inferred return type is correct.
have a look at jvmmodelgenerator
Re: Unwanted comments in generated Java Code [message #1263396 is a reply to message #1262400] Tue, 04 March 2014 07:49 Go to previous message
I wasn't aware of the JvmModelGenerator. I will debug that to see where my problem relies (seems like the hasErrors function on the generated objects returns true, which produces the commented output).
Previous Topic:Add UML-Profiles to Xtext-Models
Next Topic:xtext noobie doubt
Current Time: Sun Jul 20 10:18:49 EDT 2025
Powered by FUDForum. Page generated in 0.06165 seconds
