overriding property handling globally [message #126264] |
Thu, 15 June 2006 15:06  |
Is it possible to override property editing for all widgets?
What I want is to supply special handling for the "model" property of
all widgets. If I don't have any special handling available for the
particular widget, I want to delegate to the default handling.
Re: overriding property handling globally [message #126326 is a reply to message #126278] |
Fri, 16 June 2006 09:17  |
Jeff,
What I really want to do is to allow my users to assign the model
property of arbitrary widgets (if I have a connection that can be made).
So if they've dropped a JList, I want to discover that and allow them
to select from any data sources that I know about that are adaptable to
a ListModel. However, if the argument to setModel is not relevant to
me, then I would just let the default property editing take place.
What I have kind of working at the moment is a context menu item that
gets added to widgets. When the user invokes the context menu for a
JList object, I decide what sort of hookup (if any) is available.
I'm just trying to see if it's possible to get that same behavior in the
property sheet.
-Ernest
Jeff Myers wrote:
> Ernest,
> If your widgets have a common base class with the model property, you
> should be able to specify the property editor in an override on that
> class, then override the override on subclasses when necessary.
> Hope this helps,
> - Jeff
Re: overriding property handling globally [message #613353 is a reply to message #126264] |
Thu, 15 June 2006 16:38  |
Ernest,
Hope this helps,
- Jeff
Re: overriding property handling globally [message #613357 is a reply to message #126278] |
Jeff,
property sheet.
-Ernest
Jeff Myers wrote:
> Ernest,
> Hope this helps,
> - Jeff
FUDForum. Page generated in 0.05038 seconds
