Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO/Hibernate] Multiple issues
[CDO/Hibernate] Multiple issues [message #126218] Tue, 24 June 2008 07:36 Go to next message
Hi Eike, hi Martin,
after a few weeks, I'm back from vacation and switched back to work mode
this week.
First, let me give my congratulations for the graduation.
That said, I have persisting problems using CDO/Hibernate, some of which
I have a workaround (which is ok but not satisfying), for some I don't.
Here we go: (I updated to Ganymede (well, RC4 for now to be exact), and
thus to CDO 1.0.0)
Issue 1:
Is it intentional that CDO does not run out of the box when downloaded
binary as part of Ganymede?
=> Workaround: I have to copy the libraries to
eclipse\plugins\org.eclipse.emf.cdo.server.hibernate.librari es_1.0.0.v200806111412\lib
Issue 2:
When starting up, I get a
at
org.eclipse.core.internal.runtime.Activator.getURLConverter( Activator.java:313)
at org.eclipse.core.runtime.FileLocator.resolve(FileLocator.jav a:186)
at
org.eclipse.net4j.internal.util.om.OSGiBundle.getBaseURL(OSG iBundle.java:47)
at
org.eclipse.net4j.internal.util.bundle.AbstractBundle.getInp utStream(AbstractBundle.java:222)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.initConfiguration(HibernatePackageHandler.java:391 )
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.doActivate(HibernatePackageHandler.java:364)
at
org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:53)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore .doActivate(HibernateStore.java:197)
at
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:69)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:59)
at
org.eclipse.emf.cdo.internal.server.Repository.activateRepos itory(Repository.java:262)
at
org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:250)
at
at
at
at
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:67)
at test.cdo.classpath.Activator.getSession(Activator.java:84)
at test.cdo.classpath.Activator.getTransaction(Activator.java:1 03)
at test.cdo.classpath.Activator.getResource(Activator.java:113)
at test.cdo.classpath.ClasspathTest.testClasspath(ClasspathTest .java:9)
because at
URL entry = getBundleContext().getBundle().getEntry(".");
//$NON-NLS-1$
getEntry(".") returns null ...
=> Workaround: Imprt the Plug-In as source into the workspace
Net4j util seems to not like CDO as JAR bundles...
Issue 3:
org.hibernate.MappingException: entity class not found:
org.eclipse.emf.cdo.internal.protocol.model.CDOModelElementI mpl
at
org.hibernate.mapping.PersistentClass.getMappedClass(Persist entClass.java:99)
at
org.hibernate.tuple.PropertyFactory.getGetter(PropertyFactor y.java:168)
at
org.hibernate.tuple.PropertyFactory.buildIdentifierProperty( PropertyFactory.java:44)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:124)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:434)
at
org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:91)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:58)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:226)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1300)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.getSessionFactory(HibernatePackageHandler.java:334 )
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.readPackageInfos(HibernatePackageHandler.java:292)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernatePacka geHandler.getCDOPackageInfos(HibernatePackageHandler.java:21 4)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Reader.readPackageInfos(HibernateStoreReader.java:79)
at
org.eclipse.emf.cdo.internal.server.PackageManager.doActivat e(PackageManager.java:72)
at
at
at
at
org.eclipse.emf.cdo.internal.server.Repository.activateRepos itory(Repository.java:263)
at
at
at
at
at
Refactoring problem?
meta.hbm.xml reads
<hibernate-mapping package="org.eclipse.emf.cdo.internal.protocol.model">
but should be
<hibernate-mapping package="org.eclipse.emf.cdo.internal.common.model">
now?
=> Workaround: edit meta.hbm.xml (as described) -
org.eclipse.emf.cdo.server.hibernate has been copied into workspace
alreday (see issue 2)
Issue 4:
org.eclipse.emf.cdo.internal.common.model.CDOClassProxy
This class seems not to exist any more ...
=> no workaround! => STOPPER
Eike, Martin - can you please provide a working meta.hbm.xml file, so I
can continue with 1.0?
--- for now I'm comtinuing with my issues I have with 0.8.0 (as of end
of June) and which I suspect to be in 1.0.0 still:
Issue 5:
When calling getOrCreateResource() in a plugin activator's start()
method, I run into a deadlock.
=> Workaround: always do resource initialization lazyly
Issue 6:
EPackages only containing interfaces are not being taken by the package
manager -> ClassRefs can not be resolved (see Bugzilla – Bug 230387)
=> Workaround: introduce Dummy class in the package in question and
store one Dummy instance in the Database
Issue 7:
With all of these workarounds, I get to store and read my models in one
session alright.
However, when I close my application and reopen it, initialization fails
consistently when trying to get the contents of a resource:
getResource("/test").getContents() seems to not initialize the thread
context variables on the server:
24.06.2008 13:32:40 org.hibernate.tool.hbm2ddl.SchemaUpdate execute
INFO: schema update complete
Thread-4 [debug] Setting session in threadlocal
Thread-4 [debug.revision] Setting version for
CDOResource@HBM-CDOResource-1v0: v1
Thread-4 [debug] Stored hb list in threadlocal: CDOResource.contents
Thread-4 [debug.session] Registering resource: HBM-CDOResource-1 <-->
/my/test/resource
Thread-4 [debug.protocol] Writing ID: HBM-CDOResource-1
Thread-4 [debug.model] Writing CDOID of type 1 (OBJECT)
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 03 01 00 00 00 01 00
00 00 00 00 00 00 01 01 00 0b 43 44 4f 52 65 73 6f 75 72 63 65 00
Thread-4 [debug] Releasing hibernate session
main [debug.model] Reading CDOID of type 1 (OBJECT)
Thread-4 [debug] Clearing session in threadlocal
Thread-4 [debug] Removing hibernate session
Thread-4 [debug] Closing hibernate session
main [debug.protocol] Read ID: HBM-CDOResource-1
[INFO] Legacy system not available
main [debug.object] Setting ID: HBM-CDOResource-1
main [debug.object] Setting view: CDOTransaction(1)
main [debug.object] Setting state PROXY for CDOResource@HBM-CDOResource-1
main [debug.object] PREPARE: CDOResource@HBM-CDOResource-1 -->
CDOTransaction(1)
main [debug.protocol] Writing path: /my/test/resource
main [debug] Multiplexing 00 00 00 00 00 00 00 05 00 04 01 00 11 2f 6d
79 2f 74 65 73 74 2f 72 65 73 6f 75 72 63 65 00
Thread-4 [debug] Created
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Reader for
repository repo1
repository repo1
Thread-4 [debug.protocol] Read path: /my/test/resource
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 04 01 00 00 00 01 00
main [debug.view] Registering CDOResource@HBM-CDOResource-1
main [debug.object] ATTACH: CDOResource@HBM-CDOResource-1 -->
CDOTransaction(1)
main [debug.object] size(CDOResource@HBM-CDOResource-1, CDOFeature(ID=2,
name=contents, type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)))
main [debug.object] READ: org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
main [debug.protocol] Writing referenceChunk: -1
main [debug.protocol] Writing 1 IDs
main [debug.protocol] Writing ID: HBM-CDOResource-1
main [debug.model] Writing CDOID of type 1 (OBJECT)
main [debug] Multiplexing 00 00 00 00 00 00 00 06 00 07 00 00 00 00 00
00 00 01 01 00 00 00 01 00 00 00 00 00 00 00 01 01 00 0b 43 44 4f 52 65
73 6f 75 72 63 65 00 00 00 00 00
main [debug.protocol] Reading 1 revisions
repository repo1
repository repo1
Thread-4 [debug.protocol] Read referenceChunk: -1
Thread-4 [debug.protocol] Reading 1 IDs
Thread-4 [debug.model] Reading CDOID of type 1 (OBJECT)
Thread-4 [debug.protocol] Read ID: HBM-CDOResource-1
Thread-4 [debug.protocol] Writing 1 revisions
[ERROR] CommitContext not set
java.lang.IllegalStateException: CommitContext not set
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateThrea dContext.getCommitContext(HibernateThreadContext.java:69)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateUtil. getCDORevision(HibernateUtil.java:117)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Reader.readRevision(HibernateStoreReader.java:155)
at
org.eclipse.emf.cdo.internal.server.RevisionManager.loadRevi sion(RevisionManager.java:210)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionRe solverImpl.getRevision(CDORevisionResolverImpl.java:282)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionRe solverImpl.getRevision(CDORevisionResolverImpl.java:144)
at
org.eclipse.emf.cdo.internal.server.protocol.LoadRevisionInd ication.getRevision(LoadRevisionIndication.java:171)
at
org.eclipse.emf.cdo.internal.server.protocol.LoadRevisionInd ication.responding(LoadRevisionIndication.java:147)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:54)
at
org.eclipse.emf.cdo.internal.server.protocol.CDOReadIndicati on.execute(CDOReadIndication.java:38)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn
Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
=> no workaround => STOPPER!
Should I open bugs for these issues?
Can you provide quick fixes to my two stoppers?
Stefan
Re: [CDO/Hibernate] Multiple issues [message #126233 is a reply to message #126218] Tue, 24 June 2008 08:34 Go to previous message
Hi Stefan,
Sorry to hear that you have all these issues.
Regarding issue 3 and 4, I checked this in cvs on the 15th of june. So this should be solved in the
next build, or can you cvs?
I also solved another issue related to cdopackage persistence. So maybe this is related to one of
your other issues....
btw, I cross-posted to the emf newsgroup because cdo is graduating/has graduated.
gr. Martin
Stefan Winkler wrote:
> Hi Eike, hi Martin,
> this week.
> thus to CDO 1.0.0)
> Issue 1:
> Issue 2:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> because at
> //$NON-NLS-1$
> Issue 3:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> meta.hbm.xml reads
> but should be
> now?
> Issue 4:
> Issue 5:
> Issue 6:
> Issue 7:
> session alright.
> /my/test/resource
> CDOTransaction(1)
> repository repo1
> repository repo1
> CDOTransaction(1)
> repository repo1
> repository repo1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> Cheers,
> Stefan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO/Hibernate] Multiple issues [message #619297 is a reply to message #126218] Tue, 24 June 2008 08:34 Go to previous message
Hi Stefan,
gr. Martin
> Hi Eike, hi Martin,
> this week.
> thus to CDO 1.0.0)
> Issue 1:
> Issue 2:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> because at
> //$NON-NLS-1$
> Issue 3:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> meta.hbm.xml reads
> but should be
> now?
> Issue 4:
> Issue 5:
> Issue 6:
> Issue 7:
> session alright.
> /my/test/resource
> CDOTransaction(1)
> repository repo1
> repository repo1
> CDOTransaction(1)
> repository repo1
> repository repo1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> Cheers,
> Stefan
The Netherlands
Previous Topic:[CDO/Hibernate] Multiple issues
Next Topic:Hibernate flush causes transactional domain error
Current Time: Sat Jul 19 13:28:30 EDT 2025
Powered by FUDForum. Page generated in 0.03289 seconds
