Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ECP Views Extension(Need help with how to extend ECP Views)
ECP Views Extension [message #1261215] Sun, 02 March 2014 05:11 Go to next message
I have created the application skeleton so far with e3 and e4 compatibility layer to accomodate any e3 (in my case I need to integrate graphiti editor) or e4(for any application specific views).
I plan to use ECP with EMFStore as repository provider. (have setup environment already with release12)
I am able to work with EMFStore without ECP so far but I see ECP has components that I can reuse after extending to fit in my purpose. Need help with following;
- How can I extend ECP views (to be more precised, exact extension points better if someone can mention for E4 world)
a. Model Repository Explorer (with EMFStore) and its context menu
b. Model Explorer and its context menu
c. New Project Wizard (as I need to add pages to for creating directory structure specific to my project)
Thank you.
Re: ECP Views Extension [message #1262024 is a reply to message #1261215] Mon, 03 March 2014 02:25 Go to previous messageGo to next message
are you planing to create a e4 or an e4 application?
Jonas
Am 02.03.2014 11:11, schrieb Hammad A:
> Thank you.
Re: ECP Views Extension [message #1262036 is a reply to message #1262024] Mon, 03 March 2014 02:37 Go to previous messageGo to next message
hi Jonas,
Well preferably it would be e4 but as I said, I can accomodate e3 extentions as well.
[Updated on: Mon, 03 March 2014 02:50] by Moderator
Re: ECP Views Extension [message #1262080 is a reply to message #1262036] Mon, 03 March 2014 03:39 Go to previous message
OK, sorry for the confusion, I meant an e4 or an e3 application :-)
In this case, I would recommend to create your own custom application,
with your own Application model. This way, you can customize and modify
all context menus as you wish. The application ECP provides is meant as
a demo application. It is possible to based your own application on
this, but you gain more flexibility, if you have an own one and the
application itself is not much work, so the benefit of reusing it is not
big.
I therefore would recommend to have a look at the sources of the
existing demo application and create your own based on this template.
Best Regards
Jonas
Am 03.03.2014 08:37, schrieb Hammad A:
> hi Jonas,
> I am planning to create an e4 application.
> Regards
Previous Topic:[Solved]How to generate an ecore metamodel diagram from an .ecore file?
Next Topic:ECP API not available - HTTP Error 404
Current Time: Sat Jul 19 13:22:56 EDT 2025
Powered by FUDForum. Page generated in 0.05556 seconds
