Home » Eclipse Projects » Remote Application Platform (RAP) » Branding doesn't work in Tomcat
Branding doesn't work in Tomcat [message #126171] Wed, 25 March 2009 03:51 Go to next message
Gentlemen,
<extension
point="org.eclipse.rap.ui.branding">
<branding
body="src/branding/body.htm"
defaultEntrypointId="myEntryPointId"
id="myBranding"
servletName="rap"
title="App title">
</branding>
</extension>
Branding works inside Eclipse, but not in Tomcat. Tomcat gave me this
stacktrace. I'm using rap-1.1-sr1.
!ENTRY org.eclipse.osgi 4 0 2009-03-25 12:32:26.272
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
at
org.eclipse.ui.internal.branding.BrandingExtension.readBody( BrandingExtension.java:217)
at
org.eclipse.ui.internal.branding.BrandingExtension.readBrand ing(BrandingExtension.java:97)
at
org.eclipse.ui.internal.branding.BrandingExtension.read(Bran dingExtension.java:74)
at
org.eclipse.ui.internal.WorkbenchPlugin$3.addingService(Work benchPlugin.java:1037)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042)
at
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967)
at
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:91)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1248)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1563)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1538)
at
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.register(ServiceRegistrationImpl.java:122)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:666)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:617)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:685)
at
org.eclipse.equinox.http.registry.internal.HttpServiceTracke r.open(HttpServiceTracker.java:43)
at
org.eclipse.equinox.http.registry.internal.Activator.addingS ervice(Activator.java:59)
at
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at
org.eclipse.equinox.http.registry.internal.Activator.start(A ctivator.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.re sumeBundles(PackageAdminImpl.java:272)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.pr ocessDelta(PackageAdminImpl.java:506)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.do ResolveBundles(PackageAdminImpl.java:224)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1. run(PackageAdminImpl.java:162)
at java.lang.Thread.run(Thread.java:595)
Re: Branding doesn't work in Tomcat [message #126183 is a reply to message #126171] Wed, 25 March 2009 04:22 Go to previous messageGo to next message
I think the "body.htm" could not be found. The "src" folder normally
doesn't exist after the plug-ins have been compiled by PDE build.
What you could do is put the html-file in a separate directory in the
root of your bundle (e.g. "resources") and add this directory to the
Binary Build in your build.properties.
Stefan.
Dmitry Pryadkin schrieb:
> Gentlemen,
> <extension
> <branding
> id="myBranding"
> servletName="rap"
> title="App title">
> </branding>
> </extension>
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Branding doesn't work in Tomcat [message #127111 is a reply to message #126183] Fri, 03 April 2009 10:42 Go to previous messageGo to next message
Hi folks,
sorry to bring this up again, but branding doesn't work for me either if
i deploy my rap branding to jboss AS. I followed your suggestions and
used the resources extension point and added the html body to a folder
on the root of the plugin. I also made sure the folder is exported on
the binary build page, but the html file is not loaded on startup. I
noticed that also do not see the typical rap "blue sky" background. It
works locally in eclipse, there I see the rap background as well as my
branding html body. Because we single source our application the
extensions reside in a fragment.
These are the extensions i used. I shortened the ids to improve reading.
What am I missing?
Tom
<extension
point="org.eclipse.rap.ui.entrypoint">
<entrypoint
class="com...rap.DefaultEntryPoint"
id="com...rap.defaultentrypoint"
parameter="startLisa">
</entrypoint>
</extension>
<extension
<branding
body="html/pleaseWait.html"
defaultEntrypointId="com...rap.defaultentrypoint"
favicon="icons/favicon_16.gif"
id="com...rap.branding"
servletName="rap"
title="someTitle">
</branding>
</extension>
<extension
point="org.eclipse.equinox.http.registry.resources">
<resource
alias="/splashimages"
base-name="/html">
</resource>
</extension>
Stefan Roeck schrieb:
> Regards,
> Stefan.
>> Gentlemen,
>> <extension
>> <branding
>> id="myBranding"
>> servletName="rap"
>> title="App title">
>> </branding>
>> </extension>
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Branding doesn't work in Tomcat [message #127123 is a reply to message #127111] Fri, 03 April 2009 10:45 Go to previous message
Solved, my fault. I noticed JBoss caches deployed war archives, clearing
the cache made it work. Sorry to bother you.
Cheers
Thomas Haskes schrieb:
> Hi folks,
> What am I missing?
> Tom
> <extension
> <entrypoint
> </entrypoint>
> </extension>
> <extension
> <branding
> servletName="rap"
> title="someTitle">
> </branding>
> </extension>
> <extension
> <resource
> base-name="/html">
> </resource>
> </extension>
>> Hi,
>> Regards,
>> Stefan.
>>> Gentlemen,
>>> <extension
>>> <branding
>>> id="myBranding"
>>> servletName="rap"
>>> title="App title">
>>> </branding>
>>> </extension>
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:DoubleClickListener on DateTime (Calendar) Widget
Next Topic:RAP Applications Render Using Quirks Mode and Support for IE8 Standards Mode
Current Time: Sat Jul 19 10:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.06375 seconds
