Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Ordered bidirecional relationship, join colums and mapped by
[Texo] Ordered bidirecional relationship, join colums and mapped by [message #1257260] |
Wed, 26 February 2014 03:17  |
Greetings all,
We have been using for a while teneo and now would like to move to texo, first tests case are positive, but we have a small issue with ordered bidirectional relationships.
As documentation says
--- CUT
When bi-directional ereferences are ordered (which is the default), i.e. when a java.util.List is used in the generated java code, then the ereferences will be mapped separately with join-columns on both sides of the assocation. So bi-directional ordered associations are not mapped using mapped-by and will use 2 foreign key associations.
--- CUT
Is this behaviour overridable in some way? We want ordered relationship (ie we want use list) but we want to use mappedby and don't want two join colums on the relationship.
So far we are removing the @joinColum annotation on the unwanted end with an ant script, but this is far from being ideal.
thank you.
[Updated on: Wed, 26 February 2014 03:26] by Moderator
Re: Ordered bidirecional relationship, join colums and mapped by [message #1257820 is a reply to message #1257260] |
Wed, 26 February 2014 15:42   |
Hi Cristian,
The reason behind this is that to maintain the order on both sides, then on both sides an index column is needed. So if
you want to use mapped by then you would loose the ordering in one direction as then there would not be a separate index
column for the non-mappped side.
Have you tried the mapped by annotation in the annotations model?
gr. Martin
On 02/26/2014 09:17 AM, Cristian Prevedello wrote:
> Greetings all,
> --- CUT
> --- CUT
> thank you.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Ordered bidirecional relationship, join colums and mapped by [message #1258902 is a reply to message #1258793] |
Thu, 27 February 2014 16:56   |
Hi Cristian,
So if I understand it correctly, if you set mappedby in the annotations model Texo still generates the joincolumn
annotations?
If that's the case then I can change this in Texo.
Another thing you can try is to set the same join column names for both sides of the association (so both sides use the
same join column). Using the annotationsmodel.
gr. Martin
On 02/27/2014 08:19 PM, Cristian Prevedello wrote:
> Thank you for your prompt reply, as usual :)
> Yes we tried to put a mappedby annotation, but jpa complains a mappedby can't exist with a @JoinColoumn annotation (
> Caused by: org.hibernate.AnnotationException: Associations marked as mappedBy must not define database mappings like
> @JoinTable or @JoinColumn)
> This is part of the model:
> http://postimg.org/image/q92lpati1/
> The User class has the following member
> @OneToMany(cascade = { CascadeType.ALL })
> @JoinColumns({ @JoinColumn(name = "User_UserGroups") })
> private List<UserGroup> userGroups = new ArrayList<UserGroup>();
> The Group class has the following member
> @JoinColumns({ @JoinColumn(name = "Group_UserGroups") })
> and finally the UserGroup class has the following member
> @ManyToOne(cascade = { CascadeType.MERGE, CascadeType.PERSIST, CascadeType.REFRESH })
> @JoinColumns({ @JoinColumn(name = "UserGroup_User") })
> private User user = null;
> @JoinColumns({ @JoinColumn(name = "UserGroup_Group") })
> private Group group = null;
> The resulting usergroup table has four foreign keys
> http://postimg.org/image/nvyg3ij89/
> if i remove the @Joincolum on the user class and on the group class and set the mappedBy, the usergroup table has just
> two foreign key as expected.
> Of course if i don't use list but Set the usergroup table has just two foreign keys as well.
> am i doing wrong or this is the expected behaviour?
> thank you!
The Netherlands
Current Time: Sun Jul 20 15:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.04848 seconds
