Home » Language IDEs » C / C++ IDE (CDT) » QT and CDT
QT and CDT [message #125820] Thu, 04 November 2004 05:43 Go to next message
Dear all, I'm using CDT 2.1RC0 to develop QT applications.
QT use this signals/slots mechanism, therefore you do find the macro
"slots" and "signals" in the classes declaration, for instance:
class Test : public QObject
public:
Test();
~Test();
private slots:
void mySlot();
signals:
void mySignal();
However the CDT parser failed to register the class whenever it finds
the word "signals" or "slots" in the class declaration. Is there anyway
to configure the parser to ignore them and still register this as a
class or I have to dig into the code?
Gael
Re: QT and CDT [message #125860 is a reply to message #125820] Thu, 04 November 2004 07:14 Go to previous messageGo to next message
> public:
> Test();
> ~Test();
> private slots:
> void mySlot();
> signals:
> void mySignal();
> Gael
In Project Peoperties -> C/C++ Include Paths & Symbols press Add
Preprocessor Symbol button and type in signals=/*signals*/. Repeat the
same with slots
Maybe this helps
Vaidas
Re: QT and CDT [message #125887 is a reply to message #125860] Thu, 04 November 2004 07:58 Go to previous messageGo to next message
> same with slots
Indeed, that works fine now, thanks ever so much.
Gael
Re: QT and CDT [message #125965 is a reply to message #125860] Thu, 04 November 2004 14:25 Go to previous messageGo to next message
>> public:
>> Test();
>> ~Test();
>> private slots:
>> void mySlot();
>> signals:
>> void mySignal();
>> Gael
> same with slots
> Maybe this helps
But are not those things define somewhere in a qt header, for all to use.
maybe the problem is that this file was not included i.e. #include
qt_macros.h
are something ?
Not a QT expert
> Vaidas
Re: QT and CDT [message #134667 is a reply to message #125965] Wed, 12 January 2005 16:55 Go to previous messageGo to next message
>>> public:
>>> Test();
>>> ~Test();
>>> private slots:
>>> void mySlot();
>>> signals:
>>> void mySignal();
>>> anyway to configure the parser to ignore them and still register this
>>> as a class or I have to dig into the code?
>>> Gael
>> same with slots
>> Maybe this helps
> qt_macros.h
> are something ?
Yes, however, they are defined as:
#define signal
#define slot
so perhaps they cannot be properly interpreted?
Re: QT and CDT [message #134877 is a reply to message #134667] Fri, 14 January 2005 10:28 Go to previous messageGo to next message
not knowing anything about QT : note that even if signals & slots are
#defined away, the below code would be preprocessed as:
private : //ok
void mySlot();
: //not ok
void mySignal();
with the given code, you would need to #define signals as one of public,
protected, private.
-Andrew
"Joshua Pollak" <pardsbane@offthehill.org> wrote in message
news:cs46cf$6hl$1@www.eclipse.org...
> alain wrote:
> > Vaidotas Rad
Re: QT and CDT [message #641509 is a reply to message #134667] Thu, 25 November 2010 13:05 Go to previous messageGo to next message
Hello guys,
Propably it is not anymore usefull for you, but what i do to get it work is the following:
first i add the path that vaias said before:
"In Project Peoperties -> C/C++ Include Paths & Symbols press Add
same with slots "
And then i add
#define signals
#define slots
as well as the declaration of the slot: (for example)
private slots:
void on_Ok_clicked();
on the ui_AddressBook.h
finally the code for the on_Ok_clicked() on the AddresBook.cpp.
I hope it is gonna help someone....
Re: QT and CDT [message #641568 is a reply to message #641509] Fri, 26 November 2010 02:03 Go to previous message
Daniel wrote on Thu, 25 November 2010 19:05
Hello guys,
same with slots "
And then i add
#define signals
#define slots
private slots:
It is not necessary to add the defines manually. You should add the include path for Qt in Project Peoperties -> C/C++ General->Include Paths & Symbols->Includes (C++). Eclipse will then find the correct headers and can resolve the symbols.
Previous Topic:Import a list of files
Next Topic:Debugging win32 C/C++ console application in Helios
Current Time: Sun Jul 20 12:20:20 EDT 2025
Powered by FUDForum. Page generated in 0.04155 seconds
