Home » Modeling » TMF (Xtext) » DSLProposalProvider (access external data)
DSLProposalProvider (access external data) [message #1256768] Tue, 25 February 2014 14:42 Go to next message
Hi everyone,
After develop a grammar for my language and integrate it in my RCP, I stumbled upon costumizing my proposal provider.
I need to access to some information which is outside my language plugins, I don't see can I pass that information unless I put some static which must be assigned before editor being used..
I thought about google injection, but I don't know if it is possible put in there my own objects. I couldn't figure it out.
Someone can tell which is the right approach.
My fundamental problem is that I need information that is outside DSL plugins.
Thanks in advance.
Re: DSLProposalProvider (access external data) [message #1256788 is a reply to message #1256768] Tue, 25 February 2014 15:12 Go to previous messageGo to next message
Hi can you be a bit more specific on your usecase
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: DSLProposalProvider (access external data) [message #1256851 is a reply to message #1256788] Tue, 25 February 2014 16:48 Go to previous messageGo to next message
Hi. Thanks for replying.
Summing up... My custom proposals are based on some objects contained by some resources in the workspace and I am able to access these resources through another plugin.
I'm using embedded editor, and I don't want to polute the generated code with static access in the proposalprovider to make available in there the objects I need.
Do you know any way, for example using injection that allows me to pass my objects into proposalprovider, without doing unsafe/ugly code.
Rui
Re: DSLProposalProvider (access external data) [message #1257198 is a reply to message #1256851] Wed, 26 February 2014 01:55 Go to previous messageGo to next message
Hi this is still to unspecific to give advice. What about simply injecting your util to the proposal provider
Re: DSLProposalProvider (access external data) [message #1257359 is a reply to message #1257198] Wed, 26 February 2014 05:40 Go to previous messageGo to next message
Hi. Thanks again. That would be one of my questions.
I can put
@Inject
MyUtil myutil
in proposalprovider. How do I make a MyUtil object available to be injected, in the code where I create the embedded editor.
I explorer the Injector class, but couldn't figure out How to add a Binding with my object.
Re: DSLProposalProvider (access external data) [message #1257429 is a reply to message #1257359] Wed, 26 February 2014 07:15 Go to previous message
simply da a dependency from your ui bundle to your util bundle ?!?
have no idea what your util is and where it is...
Previous Topic:How to get rid of Tycho's downloading of p2.indexes on every build
Next Topic:Combining Grammars
Current Time: Sun Jul 20 06:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.03965 seconds
