Home » Modeling » Papyrus » Installing 10.0.0M5
Installing 10.0.0M5 [message #1256604] Tue, 25 February 2014 10:59 Go to next message
I can't get 10.0.0.M5 installed. Actually, I can't get installed any of Papyrus version. What am I missing?
I have installed all EMF related items from update site.
Thanks for your help!
Gin
Platform: Eclipse Standard 4.3.1
Error msg:
Your original request has been modified.
  "Papyrus UML (Incubation)" is already installed, so an update will be performed instead.
Cannot complete the install because one or more required items could not be found.
  Software being installed: Papyrus UML SDK (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.sdk.sources.feature.feature.group 1.0.0.v201401290914)
  Missing requirement: Papyrus Embedded Editors extensions point (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.extensionpoints.editors 1.0.0.v201401290914) requires 'bundle org.eclipse.emf.ecore 2.10.0' but it could not be found
  Cannot satisfy dependency:
    From: Papyrus GMF diagram (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.infra.gmfdiag.feature.feature.group 1.0.0.v201401290914)
    To: org.eclipse.papyrus.infra.gmfdiag.xtext.glue [1.0.0.v201401290914]
    From: XText GMF Glue (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.infra.gmfdiag.xtext.glue 1.0.0.v201401290914)
    To: bundle org.eclipse.papyrus.extensionpoints.editors 1.0.0
    From: Papyrus UML (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.sdk.feature.feature.group 1.0.0.v201401290914)
    To: org.eclipse.papyrus.infra.gmfdiag.feature.feature.group [1.0.0.v201401290914]
    From: Papyrus UML SDK (Incubation) 1.0.0.v201401290914 (org.eclipse.papyrus.sdk.sources.feature.feature.group 1.0.0.v201401290914)
    To: org.eclipse.papyrus.sdk.feature.feature.group [1.0.0.v201401290914]
[Updated on: Tue, 25 February 2014 10:59] by Moderator
Re: Installing 10.0.0M5 [message #1256628 is a reply to message #1256604] Tue, 25 February 2014 11:24 Go to previous messageGo to next message
Did you install Papyrus M5 on an Eclipse Luna M5 platform?
Currently, Papyrus doesn't guarantee any backward compatibility with the previous Eclipse version (e.g. 4.3/Kepler). Each Papyrus version targets exactly one Eclipse version. For 1.0.0 M5, you need Eclipse 4.4 M5 (And other Luna M5 components, including UML2 5.0.0 M5)
Camille
Re: Installing 10.0.0M5 [message #1256632 is a reply to message #1256604] Tue, 25 February 2014 11:29 Go to previous message
You haven't installed all the EMF-related items.
is in EMF 2.10.0M5.
Ed Willink
On 25/02/2014 15:59, Gintautas Sulskus wrote:
> Hello,
> Gin
> Error msg:
> performed instead.
> not be found.
> 1.0.0.v201401290914
Previous Topic:0.10.2 release notes et al...
Next Topic:CSS Tooling menu item not present in Papyrus 0.10.2
Current Time: Sun Jul 20 09:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.03346 seconds
