Re: [Texo] parent/child relations are not persisted [message #1257819 is a reply to message #1257254] |
Wed, 26 February 2014 15:40   |
Hi Peter,
I didn't see annotations in the java code, so I guess you use a separate orm.xml. Can you post the relevant part of the
orm.xml?
gr. Martin
On 02/26/2014 09:11 AM, peter meyer wrote:
> Hi Martin,
> and thank you for your prompt reply.
> I checked the child and parent ereferences. I think they are ok, but to be safe i send you the orm.annotationmodel.
> Here is the code for ProcessStep:
> package de.processtool.processes;
> import java.util.ArrayList;
> import java.util.List;
> * A representation of the model object '<em><b>ProcessStep</b></em>'. <!--
> * begin-user-doc --> <!-- end-user-doc -->
> * * @generated
> public class ProcessStep extends Numerator {
> * <!-- begin-user-doc --> <!-- end-user-doc -->
> * * @generated
> private WorkingsStep firstWorkingStep = null;
> * * @generated
> private List<ProcessStep> childList = new ArrayList<ProcessStep>();
> * * @generated
> private List<ProcessStep> parentList = new ArrayList<ProcessStep>();
> * * @generated
> private List<WorkingsStep> workingStepList = new ArrayList<WorkingsStep>();
> * Returns the value of '<em><b>firstWorkingStep</b></em>' feature.
> * * <!-- begin-user-doc --> <!-- end-user-doc -->
> * * @return the value of '<em><b>firstWorkingStep</b></em>' feature
> * @generated
> public WorkingsStep getFirstWorkingStep() {
> return firstWorkingStep;
> * Sets the '{@link ProcessStep#getFirstWorkingStep()
> * <em>firstWorkingStep</em>}' feature.
> * * @param newFirstWorkingStep
> * the new value of the '
> * {@link ProcessStep#getFirstWorkingStep() firstWorkingStep}'
> * feature.
> * @generated
> public void setFirstWorkingStep(WorkingsStep newFirstWorkingStep) {
> firstWorkingStep = newFirstWorkingStep;
> * Returns the value of '<em><b>childList</b></em>' feature.
> * * @return the value of '<em><b>childList</b></em>' feature
> * @generated
> public List<ProcessStep> getChildList() {
> return childList;
> * Adds to the <em>childList</em> feature.
> * * @param childListValue
> * the value to add
> * @return true if the value is added to the collection (it was not yet
> * present in the collection), false otherwise
> * @generated
> public boolean addToChildList(ProcessStep childListValue) {
> if (!childList.contains(childListValue)) {
> boolean result = childList.add(childListValue);
> return result;
> return false;
> * Removes from the <em>childList</em> feature.
> * the value to remove
> * @return true if the value is removed from the collection (it existed in
> * the collection before removing), false otherwise
> * * @generated
> public boolean removeFromChildList(ProcessStep childListValue) {
> if (childList.contains(childListValue)) {
> boolean result = childList.remove(childListValue);
> return result;
> return false;
> * Clears the <em>childList</em> feature.
> * * @generated
> public void clearChildList() {
> while (!childList.isEmpty()) {
> removeFromChildList(childList.iterator().next());
> * Sets the '{@link ProcessStep#getChildList() <em>childList</em>}' feature.
> * * @param newChildList
> * the new value of the '{@link ProcessStep#getChildList()
> * childList}' feature.
> * @generated
> public void setChildList(List<ProcessStep> newChildList) {
> childList = newChildList;
> * Returns the value of '<em><b>parentList</b></em>' feature.
> * * @return the value of '<em><b>parentList</b></em>' feature
> * @generated
> public List<ProcessStep> getParentList() {
> return parentList;
> * Adds to the <em>parentList</em> feature.
> * * @param parentListValue
> * the value to add
> * @generated
> public boolean addToParentList(ProcessStep parentListValue) {
> if (!parentList.contains(parentListValue)) {
> boolean result = parentList.add(parentListValue);
> return result;
> return false;
> * Removes from the <em>parentList</em> feature.
> * * @generated
> public boolean removeFromParentList(ProcessStep parentListValue) {
> if (parentList.contains(parentListValue)) {
> boolean result = parentList.remove(parentListValue);
> return result;
> return false;
> * Clears the <em>parentList</em> feature.
> * * @generated
> public void clearParentList() {
> while (!parentList.isEmpty()) {
> removeFromParentList(parentList.iterator().next());
> * Sets the '{@link ProcessStep#getParentList() <em>parentList</em>}'
> * feature.
> * * @param newParentList
> * the new value of the '{@link ProcessStep#getParentList()
> * parentList}' feature.
> * @generated
> public void setParentList(List<ProcessStep> newParentList) {
> parentList = newParentList;
> * Returns the value of '<em><b>workingStepList</b></em>' feature.
> * * @return the value of '<em><b>workingStepList</b></em>' feature
> * @generated
> public List<WorkingsStep> getWorkingStepList() {
> return workingStepList;
> * Adds to the <em>WorkingStepList</em> feature.
> * * @param workingStepListValue
> * the value to add
> * @generated
> public boolean addToWorkingStepList(WorkingsStep workingStepListValue) {
> if (!workingStepList.contains(workingStepListValue)) {
> boolean result = workingStepList.add(workingStepListValue);
> return result;
> return false;
> * Removes from the <em>WorkingStepList</em> feature.
> * * @generated
> public boolean removeFromWorkingStepList(WorkingsStep workingStepListValue) {
> if (workingStepList.contains(workingStepListValue)) {
> boolean result = workingStepList.remove(workingStepListValue);
> return result;
> return false;
> * Clears the <em>WorkingStepList</em> feature.
> * * @generated
> public void clearWorkingStepList() {
> while (!workingStepList.isEmpty()) {
> removeFromWorkingStepList(workingStepList.iterator().next());
> * Sets the '{@link ProcessStep#getWorkingStepList()
> * <em>workingStepList</em>}' feature.
> * * @param newWorkingStepList
> * the new value of the '{@link ProcessStep#getWorkingStepList()
> * workingStepList}' feature.
> * @generated
> public void setWorkingStepList(List<WorkingsStep> newWorkingStepList) {
> workingStepList = newWorkingStepList;
> * A toString method which prints the values of all EAttributes of this
> * instance. <!-- begin-user-doc --> <!-- end-user-doc -->
> * * @generated
> @Override
> public String toString() {
> return "ProcessStep ";
> orm.annotationmodel:
> <annotationsmodel:AnnotatedModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:annotationsmodel="http://www.eclipse.org/emf/texo/annotations/model"
> xmlns:ormannotations="http://www.eclipse.org/emf/texo/orm/ormannotations">
> <annotatedEPackages>
> <ePackage href="platform:/resource/de.processtool/model/processes.ecore#/"/>
> <ePackageAnnotations xsi:type="ormannotations:EPackageORMAnnotation" generateFullDbSchemaNames="false"
> maximumSqlNameLength="255" lowerCasedNames="false" upperCasedNames="false" enforceUniqueNames="false"
> useJoinTablesForContainment="false" useJoinTablesForNonContainment="true" generateJavaAnnotations="false"
> addOrderColumnToListMappings="false" renameSQLReservedNames="false" uniqueEntityNames="true"
> setDelimitedIdentifierTagInORM="true">
> <inheritance strategy="TABLE_PER_CLASS"/>
> </ePackageAnnotations>
> <annotatedEClassifiers xsi:type="annotationsmodel:AnnotatedEClass">
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//Station"/>
> <eClassAnnotations xsi:type="ormannotations:EClassORMAnnotation">
> <entity class="de.kisters.praesto.texo.processes.Station" name="processes_Station">
> <table name="processes_Station"/>
> </entity>
> </eClassAnnotations>
> </annotatedEClassifiers>
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//Numerator"/>
> <entity class="de.kisters.praesto.texo.processes.Numerator" name="processes_Numerator"/>
> <mappedSuperclass access="FIELD" class="de.kisters.praesto.texo.processes.Numerator"/>
> <annotatedEStructuralFeatures xsi:type="annotationsmodel:AnnotatedEAttribute">
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//Numerator/number"/>
> <eAttributeAnnotations xsi:type="ormannotations:EAttributeORMAnnotation">
> <basic name="number" optional="false"/>
> </eAttributeAnnotations>
> </annotatedEStructuralFeatures>
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//Numerator/name"/>
> <basic name="name" optional="false"/>
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//Process"/>
> <entity class="de.kisters.praesto.texo.processes.Process" name="processes_Process">
> <table name="processes_Process"/>
> </entity>
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//Process/childTransition"/>
> <basic enumerated="STRING" name="childTransition"/>
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//Process/parentTransition"/>
> <basic enumerated="STRING" name="parentTransition"/>
> <annotatedEStructuralFeatures xsi:type="annotationsmodel:AnnotatedEReference">
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//Process/station"/>
> <eReferenceAnnotations xsi:type="ormannotations:EReferenceORMAnnotation">
> <manyToOne name="station" optional="true">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> </eReferenceAnnotations>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//Process/childList"/>
> <manyToMany name="childList">
> <joinTable name="processes_Process_Child"/>
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//Process/parentList"/>
> <manyToMany name="parentList">
> <joinTable name="processes_Process_Parent"/>
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//Process/firstProcessStep"/>
> <manyToOne name="firstProcessStep">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//Process/processStepList"/>
> <manyToMany name="processStepList">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToMany>
> <annotatedEClassifiers xsi:type="annotationsmodel:AnnotatedEEnum">
> <eEnum href="platform:/resource/de.processtool/model/processes.ecore#//Transition"/>
> <eEnumAnnotations xsi:type="ormannotations:EEnumORMAnnotation"/>
> <annotatedEEnumLiterals>
> <eEnumLiteral href="platform:/resource/de.processtool/model/processes.ecore#//Transition/MANUALLY"/>
> </annotatedEEnumLiterals>
> <eEnumLiteral href="platform:/resource/de.processtool/model/processes.ecore#//Transition/MECHANICALLY"/>
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//ProcessStep"/>
> <entity class="de.kisters.praesto.texo.processes.ProcessStep" name="processes_ProcessStep">
> <table name="processes_ProcessStep"/>
> </entity>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessStep/firstWorkingStep"/>
> <manyToOne name="firstWorkingStep" optional="true">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessStep/workingStepList"/>
> <oneToMany name="workingStepList">
> <cascade>
> <cascadeAll/>
> </cascade>
> </oneToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessStep/childList"/>
> <joinTable name="processes_ProcessStep_Child"/>
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessStep/parentList"/>
> <joinTable name="processes_ProcessStep_Parent"/>
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToMany>
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//WorkingsStep"/>
> <entity class="de.kisters.praesto.texo.processes.WorkingsStep" name="processes_WorkingsStep">
> <table name="processes_WorkingStep"/>
> </entity>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//WorkingsStep/childWorkingStep"/>
> <manyToOne name="childWorkingStep" optional="true">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//WorkingsStep/parentWorkingStep"/>
> <manyToOne name="parentWorkingStep" optional="true">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eClass href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel"/>
> <entity class="de.kisters.praesto.texo.processes.ProcessModel" name="processes_ProcessModel"/>
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/description"/>
> <basic name="description"/>
> <eAttribute href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/name"/>
> <basic name="name"/>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/processList"/>
> <oneToMany name="processList">
> <joinTable catalog="" name="processmodel_to_processes" schema=""/>
> <cascade>
> <cascadeAll/>
> </cascade>
> </oneToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/stationList"/>
> <oneToMany name="stationList">
> <joinTable name="processmodel_to_stations"/>
> <cascade>
> <cascadeAll/>
> </cascade>
> </oneToMany>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/startProcess"/>
> <manyToOne name="startProcess">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/endProcess"/>
> <manyToOne name="endProcess">
> <cascade>
> <cascadePersist/>
> <cascadeMerge/>
> <cascadeRefresh/>
> </cascade>
> </manyToOne>
> <eReference href="platform:/resource/de.processtool/model/processes.ecore#//ProcessModel/processSteps"/>
> <oneToMany name="processSteps">
> <cascade>
> <cascadeAll/>
> </cascade>
> </oneToMany>
> </annotatedEPackages>
> </annotationsmodel:AnnotatedModel>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] parent/child relations are not persisted [message #1258262 is a reply to message #1257819] |
Thu, 27 February 2014 03:06  |
Hi Martin,
yes i use an orm.xml.
Here is the mapping part for ProcessStep:
<orm:entity class="de.kisters.praesto.texo.processes.ProcessStep" name="processes_ProcessStep">
<orm:table name="processes_ProcessStep"/>
<orm:attributes>
<orm:many-to-one name="firstWorkingStep" optional="true">
<orm:cascade>
<orm:cascade-persist/>
<orm:cascade-merge/>
<orm:cascade-refresh/>
</orm:cascade>
</orm:many-to-one>
<orm:one-to-many name="workingStepList">
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:one-to-many>
<orm:many-to-many name="childList">
<orm:join-table name="processes_ProcessStep_Child"/>
<orm:cascade>
</orm:cascade>
</orm:many-to-many>
<orm:many-to-many name="parentList">
<orm:join-table name="processes_ProcessStep_Parent"/>
<orm:cascade>
</orm:cascade>
</orm:many-to-many>
</orm:attributes>
</orm:entity>
king regards
Peter
FUDForum. Page generated in 0.04110 seconds
