Home » Modeling » TMF (Xtext) » Editor related issues in xtext(Editor related issues in xtext)
icon5.gif  Editor related issues in xtext [message #1256255] Tue, 25 February 2014 03:46 Go to next message
Hi all,
I have some content in my editor something like:
Entity entity1 {
entityName Name1
Entity entity2 {
entityName Name2
For me some of the entities are used and some are unused.
MY FLOW OF EXECUTION: In the beginning I will have an empty xtext editor. On right click on the editor I have provided an option to import entities from some file which will look as mentioned above.
Now, on right click on editor I have provided one more option which will segregate used and unused entities which will look something like:
Segr seg1 {
used [...]
unused [...]
Segr seg2 {
used [...]
unused [...]
These used and unused parts are referencing to Entities.
Now two use cases:
1. I already have entities in my editor then I right click and select to import segregators.
For this case references are added properly and everything works fine for me.
2. Suppose my editor is empty i.e my resource doesn't have anything. I right click and select import segregators. So before segregators are imported, I must have some entities, so in the background I am adding some entities and then calling segregator functionality for these entities. I am making sure that I am adding entities to the resource and then for this resource I am calling segregator functionality. Even If my resource has entities (BUT STILL ENTITIES ARE NOT PRESENT IN EDITOR ), I AM UNABLE TO ADD REFERENCES.
ONLY I AM ABLE TO ADD REFERENCES IF DATA IS PRESENT IN THE EDITOR.
AM I MISSING OUT SOMETHING OR ITS THE PROPERTY OF THE EDITORS/RESOURCES ?
Thanks for your help Smile
[Updated on: Tue, 25 February 2014 03:47] by Moderator
Re: Editor related issues in xtext [message #1256287 is a reply to message #1256255] Tue, 25 February 2014 04:22 Go to previous messageGo to next message
the interesting question is: what are you actually doing in your code. (Command/Handler)
depending on how/what you are doing everything should be possible.
Re: Editor related issues in xtext [message #1256288 is a reply to message #1256287] Tue, 25 February 2014 04:24 Go to previous messageGo to next message
Hi Christian,
I am using a Handler.
Arshad
Re: Editor related issues in xtext [message #1256339 is a reply to message #1256288] Tue, 25 February 2014 05:22 Go to previous messageGo to next message
and what are you doing there. your problem must be in your code ...
icon14.gif  Re: Editor related issues in xtext [message #1256401 is a reply to message #1256339] Tue, 25 February 2014 06:44 Go to previous messageGo to next message
Hi Christian,
I solved it. Yes there was some problem in my code.
But one more thing.
Can I change the order of serialization of a resource?
Consider this example only.
Entities should be serialized first before segregators.
But for me segregators are getting serialized first which throws me NoEobjectDescription found exception !
Thanks in advance Smile
Re: Editor related issues in xtext [message #1256442 is a reply to message #1256401] Tue, 25 February 2014 07:36 Go to previous message
this depends on the grammar and how you fill the model i think
Previous Topic:Strange left recursive rules
Next Topic:Need help getting started on a grammar
Current Time: Sat Jul 19 18:06:56 EDT 2025
Powered by FUDForum. Page generated in 0.04225 seconds
