Home » Archived » Visual Editor (VE) » FormPage in Visual Editor problem
FormPage in Visual Editor problem [message #125576] Sun, 04 June 2006 18:09 Go to next message
Originally posted by: andrey.batyuk.net
Greetings,
I've tried to edit FormPage subclass in Visual Editor:
public class PersonSummaryPage extends FormPage {
private FormToolkit formToolkit; // @jve:decl-index=0:visual-constraint=""
public PersonSummaryPage(String id, String title) {
super(id, title);
// TODO Auto-generated constructor stub
public PersonSummaryPage(FormEditor editor, String id, String title) {
super(editor, id, title);
protected void createFormContent(IManagedForm managedForm) {
FormToolkit toolkit = managedForm.getToolkit();
ScrolledForm form = managedForm.getForm();
form.setText("Empty FormPage");
Composite body = form.getBody();
toolkit.paintBordersFor(body);
On attempt to open this class in visual editor i get the following error
message in status bar:
java.lang.NoSuchMethodException(org.eclipse.ui.forms.editor. FormPage. <init>())
And the following error in .log:
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2506)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2437)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1927)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1831)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1766)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1574)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:876)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:854)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:626)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1089)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1126)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:902)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
What could be the cause of this?
Re: FormPage in Visual Editor problem [message #125616 is a reply to message #125576] Mon, 05 June 2006 11:09 Go to previous messageGo to next message
What version of VE, GEF, EMF, and Eclipse are you using?
Rich
Re: FormPage in Visual Editor problem [message #125628 is a reply to message #125616] Mon, 05 June 2006 11:19 Go to previous messageGo to next message
I took a closer look. It is a current restriction. FormPage can't be
subclassed because it doesn't have a default constructor (one that takes
no arguments). You can open an enhancement against VE to be able to
handle this.
> Rich
Rich Kulp
Re: FormPage in Visual Editor problem [message #125641 is a reply to message #125628] Mon, 05 June 2006 11:52 Go to previous messageGo to next message
Will do.
But what if i make a subclass of FormPage with default constructor, and
then subclass it? Will it work? (Sorry for newbie question, i'm not yet
familiar with VE)
Re: FormPage in Visual Editor problem [message #125667 is a reply to message #125641] Mon, 05 June 2006 16:21 Go to previous messageGo to next message
No, i tried that. That won't work either because FormPage expects a
FormEditor to be set on it. The problem is there is no FormEditor set on
it and so it thows NullPointerExceptions whenever you try to anything
with the FormPage.
Andrey Batyuk wrote:
> Will do.
> familiar with VE)
Rich Kulp
Re: FormPage in Visual Editor problem [message #125690 is a reply to message #125667] Mon, 05 June 2006 16:25 Go to previous messageGo to next message
> with the FormPage.
Ok, but how do i design form pages in designer then? Create a form, design
it and copy source to form page?
Or any other workaround?
Re: FormPage in Visual Editor problem [message #125703 is a reply to message #125690] Mon, 05 June 2006 18:46 Go to previous messageGo to next message
I don't know. I've never created a FormPage. I don't know what is
expected. There isn't any examples in the base Eclipse on what a
FormPage implementation looks like.
>> on it and so it thows NullPointerExceptions whenever you try to
>> anything with the FormPage.
> design it and copy source to form page?
Rich Kulp
Re: FormPage in Visual Editor problem [message #125716 is a reply to message #125690] Tue, 06 June 2006 00:30 Go to previous messageGo to next message
Check this:
http://www.instantiations.com/windowbuilderpro/docs/introduc tion/new_and_noteworthy_300.html
In theory you can just design Composite and place it manually on
FormPage.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: FormPage in Visual Editor problem [message #125729 is a reply to message #125716] Tue, 06 June 2006 05:01 Go to previous message
Konstantin Scheglov wrote:
> Check this:
Not sure if i can afford it.
> FormPage.
Thanks. I've tried it already - works fine. Thanks a lot!
Re: FormPage in Visual Editor problem [message #613014 is a reply to message #125576] Mon, 05 June 2006 11:09 Go to previous message
Rich
Re: FormPage in Visual Editor problem [message #613016 is a reply to message #125616] Mon, 05 June 2006 11:19 Go to previous message
handle this.
> Rich
Rich Kulp
Re: FormPage in Visual Editor problem [message #613017 is a reply to message #125628] Mon, 05 June 2006 11:52 Go to previous message
Will do.
familiar with VE)
Re: FormPage in Visual Editor problem [message #613020 is a reply to message #125641] Mon, 05 June 2006 16:21 Go to previous message
with the FormPage.
> Will do.
> familiar with VE)
Rich Kulp
Re: FormPage in Visual Editor problem [message #613022 is a reply to message #125667] Mon, 05 June 2006 16:25 Go to previous message
> with the FormPage.
Re: FormPage in Visual Editor problem [message #613024 is a reply to message #125690] Mon, 05 June 2006 18:46 Go to previous message
Rich Kulp
Re: FormPage in Visual Editor problem [message #613025 is a reply to message #125690] Tue, 06 June 2006 00:30 Go to previous message
Check this:
FormPage.
SY, Konstantin.
Re: FormPage in Visual Editor problem [message #613028 is a reply to message #125716] Tue, 06 June 2006 05:01 Go to previous message
> Check this:
> FormPage.
Previous Topic:FormPage in Visual Editor problem
Next Topic:How to putt image file using VE?
Current Time: Sat Jul 19 06:50:44 EDT 2025
Powered by FUDForum. Page generated in 0.06088 seconds
