Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Save resource with validation
Save resource with validation [message #125573] Mon, 09 June 2008 20:55 Go to next message
I have an eCore model that has massive validation implemented with it.
When I create a new object and add it to a resource, when I save the
resource the validation is fired and the object is checked.
However, if I continue to change the same object and set invalid values
in the attributes, the next time I save the same resource, the
validation is not fired.
What do I need to do to make sure the validation is fire every time I
save the resource?
Yigal
Re: Save resource with validation [message #125588 is a reply to message #125573] Tue, 10 June 2008 02:56 Go to previous message
Hi Yigal,
When doing resource.save the system should end up in the StoreResource.validateContents methods. Can
you check that this indeed happens? There the list of newOrChangedObjects is created. Your changed
object should be in there.
Maybe you have to do: resource.setTrackingModification(true) beforehand (guessing a bit here)?
gr. Martin
> save the resource?
> Thanks
> Yigal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Save resource with validation [message #619226 is a reply to message #125573] Tue, 10 June 2008 02:56 Go to previous message
Hi Yigal,
gr. Martin
> save the resource?
> Thanks
> Yigal
The Netherlands
Previous Topic:Save resource with validation
Next Topic:[Teneo] JMX MBean and class loading issues
Current Time: Sat Jul 19 11:53:47 EDT 2025
Powered by FUDForum. Page generated in 0.03134 seconds
