Different scopes in formfield definition for SWT, RAP and Swing [message #1252686] |
Fri, 21 February 2014 08:36  |
I have found a difference between IFormFieldExtension (and in formfields.esxd respectivelly) in Swing, RAP and SWT. Both in SWT a RAP there are defined three scopes default, global, local.
In Swing there are only two scopes default and global. I'm using Rayo extension and want to change TimeChooser to provide time with interval of 15 minutes instead of default 30 min. Because there are only two scopes, I defined in plugin.xml my formfield in scope global. Because there is already defined such field in com.bsiag.scout.rt.ui.swing.rayo, scout prints out the following message and my field is not registered.
The bundles 'com.bsiag.scout.rt.ui.swing.rayo' and 'com.scoveco.maleda.ui.swing' are both providing an form field extension to 'org.eclipse.scout.rt.client.ui.form.fields.datefield.IDateField' with the same scope.
Is this intended, that swing has defined only two scopes? If so, is there a possibility to tell the TimeChooser time interval?
Zdenek
FUDForum. Page generated in 0.04726 seconds
