Home » Modeling » EMF » [ChangeRecoder] Unexpected behavior
[ChangeRecoder] Unexpected behavior [message #1254558] Sun, 23 February 2014 09:38 Go to next message
Hi (again),
I'm trying to evaluate the Change Recorder. I adapted the sample provided in the EMF reference book like this:
    @Test
    def void testChangeRecorder() {
        // Initialize the model
        ParticipantPackage.eINSTANCE.eClass()
        // Retrieve the default factory singleton
        val factory = ParticipantFactory.eINSTANCE
        // create the content of the model via this program
        val org = factory.createOrganization
        // Register the XMI resource factory for the .website extension
        val reg = Resource.Factory.Registry.INSTANCE
        val m = reg.getExtensionToFactoryMap()
        m.put("xmi", new XMIResourceFactoryImpl())
        // Obtain a new resource set
        val resSet = new ResourceSetImpl()
        // create a resource
        val resource = resSet.createResource(URI.createURI("resource.xmi"))
        // add the instance to the resource
        resource.contents += org
        // start recording
        val recorder = new ChangeRecorder(resource)
        org.name = "Axway"
        org.url = "axway://participant"
        // now save the content.
        try {
            resource.save(Collections.EMPTY_MAP);
        } catch (IOException e) {
            e.printStackTrace();
        // stop recording
        val description = recorder.endRecording()
        log.info("description = " + ReflectionToStringBuilder.toString(description, ToStringStyle.MULTI_LINE_STYLE))
I was expecting to see the changes to the "org" instance in the change description. However, here is the output of the program:
[main] INFO com.axway.mda.runtime.PrototypeTest - description = org.eclipse.emf.ecore.change.impl.ChangeDescriptionImpl@687191d6[
  objectChanges=[org.eclipse.emf.ecore.change.impl.EObjectToChangesMapEntryImpl@2525732f]
  objectsToDetach=<null>
  objectsToAttach=[]
  resourceChanges=[]
  oldContainmentInformation=<null>
  eFlags=1
  eAdapters=<null>
  eContainer=<null>
  eContainerFeatureID=0
  eProperties=<null>
It seems that the change set is empty whereas I expected to see 2 entries (1 for the name change and 1 for the url change).
Note that I'm running as a standalone application (not inside Eclipse).
Can anyone explain what I miss?
BQ.
Re: [ChangeRecoder] Unexpected behavior [message #1254588 is a reply to message #1254558] Sun, 23 February 2014 10:22 Go to previous messageGo to next message
Bertrand,
Comments below.
On 23/02/2014 3:38 PM, Bertrand Quenin wrote:
> Hi (again),
> @Test
> val resource =
> // start recording
> org.name = "Axway"
> try {
> // stop recording
> objectsToAttach=[]
> resourceChanges=[]
> eFlags=1
> eAdapters=<null>
> eContainer=<null>
> eProperties=<null>
There appears to be one entry in the object changes map.
My might try putting the change description itself into a resource and
saving that to see the full contents. Don't expect toString of an
implementation to show you the full tree of contained objects.
> Regards,
> BQ.
Re: [ChangeRecoder] Unexpected behavior [message #1254608 is a reply to message #1254588] Sun, 23 February 2014 10:51 Go to previous messageGo to next message
Hi Ed,
Thanks! Here is the result:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:change="http://www.eclipse.org/emf/2003/Change" xmlns:participant="participant">
  <participant:Organization name="Axway" url="axway://participant"/>
  <change:ChangeDescription>
    <objectChanges key="/0">
      <value featureName="name" set="false"/>
      <value featureName="url" set="false"/>
    </objectChanges>
  </change:ChangeDescription>
</xmi:XMI>
I can see the changes but I can't see the values though.
BQ.
Re: [ChangeRecoder] Unexpected behavior [message #1255149 is a reply to message #1254608] Mon, 24 February 2014 01:12 Go to previous messageGo to next message
Bertrand,
Comments below.
On 23/02/2014 4:51 PM, Bertrand Quenin wrote:
> Hi Ed,
> Quote:
>> and saving that to see the full contents. Don't expect toString of an
> </objectChanges>
> </xmi:XMI>
The change description describes the changes needed to get from the
current state of the model to the original state of the model at the
point when you started recording, i.e., its a reverse delta. Have a
look at
http://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/tests/org.eclipse.emf.test.core/src/org/eclipse/emf/test/core/change/ChangeDescriptionReverseTest.java
to see how to get it to produce a forward delta.
> Regards,
> BQ.
Re: [ChangeRecoder] Unexpected behavior [message #1255306 is a reply to message #1255149] Mon, 24 February 2014 04:56 Go to previous message
Thanks for the pointer, will check.
Previous Topic:[Dynamic EMF] adding features to generated EClass at runtime
Next Topic:EMF Model, Resource loading issue
Current Time: Sat Jul 19 11:54:18 EDT 2025
Powered by FUDForum. Page generated in 0.28768 seconds
