Home » Newcomers » Newcomers » Using XBootclasspath
Using XBootclasspath [message #125372] Wed, 21 December 2005 16:41 Go to next message
I want to install some class loading debug code,
which involves prepending a couple of classes to
the jvm's xbootclasspath property.
I can not find any information on accessing the
xbootclasspath property in eclipse's jvm. Where can
I find information on how to access the boot classpath
under eclipse?
Bill.
Re: Using XBootclasspath [message #125506 is a reply to message #125372] Thu, 22 December 2005 12:24 Go to previous messageGo to next message
Hey Bill,
Do you want to access these bootstrap classes within your IDE
environment, or within a class you're debugging with Eclipse? If it's
the latter case, bring up the launch configuration for your app -
(Run->Debug... then select the launch configuration) Switch to the
Classpath tab and there's a Bootstrap enteries item to which you can add
jars, projects, etc. Is this what you're looking for?
Hope this helps,
- Jeff
Re: Using XBootclasspath [message #126086 is a reply to message #125506] Mon, 26 December 2005 14:02 Go to previous message
Jeff Myers wrote:
> Hey Bill,
> Hope this helps,
> - Jeff
Thanks Jeff,
Apologies for the delayed response, I've been struck by the flu.
I'll try this ASAP,
Bill.
Previous Topic:Searching for UML modeling plug-in
Next Topic:Install/Update manager not found
Current Time: Sat Jul 19 10:54:10 EDT 2025
Powered by FUDForum. Page generated in 0.07361 seconds
