Not able to add swt library to the project [message #125282] |
Thu, 25 May 2006 10:42  |
Originally posted by: maffeir.vdavda.com
I've just downloaded Callisto RC3, starting from eclipseRC4 and then
updating the program using callisto update site.
I've selected only VE (and its dependencies)in the callisto list, so after
installing it, i try to create a swt application.
I create a new java project and then a new visual class.
In the wizard if I select SWT->Shell or composite and click on Finish, the
wizard does nothing and i need to click cancel to exit.
Then i try to add swt library to the project under Project Build Path, i
select SWT from the list, then IDE Platform and check Jface support, click
on finish but nothing appears on the build path (except for the installed
JRE).
So what i'm missing??
Thank you for your support!!
Re: [SOLVED]Not able to add swt library to the project [message #125456 is a reply to message #125429] |
Wed, 31 May 2006 11:54  |
I opened one yesterday when you brought this to my attention, thanks.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=144464
Ruggero Maffei wrote:
>> Try using the Eclipse SDK instead of just Eclipse platform. I think we
>> made an assumption that Eclipse SDK was installed. And we didn't test
>> for it not being installed.
> You're right..i download eclipse sdk RC4 and unzip it over the previous
> installation and now it works, i've created a swt project with a shell
> and everything goes well.
> Do you think that i need to open a Bugzilla entry?
Rich Kulp
Re: Not able to add swt library to the project [message #612968 is a reply to message #125296] |
Thu, 25 May 2006 12:44  |
Also exactly what versions of VE, EMF, GEF, and Eclipse do you have
downloaded?
Jeff Myers wrote:
> What OS are you running on? Are there any errors in the .log file in
> your workspace's .metadata directory?
> - Jeff
Rich Kulp
Re: Not able to add swt library to the project [message #612969 is a reply to message #125319] |
Fri, 26 May 2006 03:43  |
> downloaded?
Visual Editor
Version: 1.2.0.v20060518_RC1
Build id: 200605181544
Java EMF Model
Eclipse Graphical Editing Framework
Version: 3.1
Build id: 20060517-0757
Eclipse Modeling Framework (EMF)
Version: 2.2.0.v200605151820
Build id: 200605151820
Eclipse Platform
Version: 3.2.0.v20060512-0730-_OZ2g3C9A7hWY9A
Build id: I20060512-1600
I work on Windows Xp SP2 and below you can see the log file when i try to
add swt library to a java project. Hope it helps!
PS: If i create a new RCP application i'm able to see the SWT components
in the Visual Editor palette..so the problem is to create a single swt
application...
!SESSION 2006-05-26 09:18:14.109
eclipse.buildId=I20060512-1600
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: vmargs Xms228M Xmx392M
Command-line arguments: -os win32 -ws win32 -arch x86 vmargs Xms228M
Xmx392M
!ENTRY org.eclipse.ui 4 4 2006-05-26 09:40:45.171
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-05-26 09:40:45.171
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.ge tFragments(PackageAdminImpl.java:478)
at
org.eclipse.core.internal.runtime.InternalPlatform.getFragme nts(InternalPlatform.java:389)
at org.eclipse.core.runtime.Platform.getFragments(Platform.java :1346)
at
org.eclipse.ve.internal.swt.SWTConfigurationContributor.getS rcConfig(SWTConfigurationContributor.java:564)
at
org.eclipse.ve.internal.swt.SWTConfigurationContributor.getP latformSrcLocationFor(SWTConfigurationContributor.java:633)
at
org.eclipse.ve.internal.swt.SWTConfigurationContributor.getP latformPath(SWTConfigurationContributor.java:679)
at
org.eclipse.ve.internal.swt.SWTContainer.initPlatformPath(SW TContainer.java:438)
at
org.eclipse.ve.internal.swt.SWTContainer.computeEntries(SWTC ontainer.java:691)
at org.eclipse.ve.internal.swt.SWTContainer$3.run(SWTContainer. java:719)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
at org.eclipse.ve.internal.swt.SWTContainer.init(SWTContainer.j ava:717)
at
org.eclipse.ve.internal.swt.SWTContainer.getClasspathEntries (SWTContainer.java:757)
at
org.eclipse.jdt.internal.core.JavaModelManager.containerPutI fInitializingWithSameEntries(JavaModelManager.java:494)
at org.eclipse.jdt.core.JavaCore.setClasspathContainer(JavaCore .java:4106)
at
org.eclipse.ve.internal.swt.SWTContainerInitializer.initiali ze(SWTContainerInitializer.java:23)
at
org.eclipse.jdt.internal.core.JavaModelManager.initializeCon tainer(JavaModelManager.java:1900)
at
org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:1267)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore .java:1470)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.CPListElement . <init>(CPListElement.java:118)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.CPListElement . <init>(CPListElement.java:73)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.CPListElement . <init>(CPListElement.java:69)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.LibrariesWork bookPage.openContainerSelectionDialog(LibrariesWorkbookPage. java:815)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.LibrariesWork bookPage.libaryPageCustomButtonPressed(LibrariesWorkbookPage .java:243)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.LibrariesWork bookPage.access$0(LibrariesWorkbookPage.java:230)
at
org.eclipse.jdt.internal.ui.wizards.buildpaths.LibrariesWork bookPage$LibrariesAdapter.customButtonPressed(LibrariesWorkb ookPage.java:185)
at
org.eclipse.jdt.internal.ui.wizards.dialogfields.TreeListDia logField.buttonPressed(TreeListDialogField.java:167)
at
org.eclipse.jdt.internal.ui.wizards.dialogfields.TreeListDia logField.doButtonSelected(TreeListDialogField.java:385)
at
org.eclipse.jdt.internal.ui.wizards.dialogfields.TreeListDia logField.access$2(TreeListDialogField.java:381)
at
org.eclipse.jdt.internal.ui.wizards.dialogfields.TreeListDia logField$2.widgetSelected(TreeListDialogField.java:346)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:156)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: [SOLVED]Not able to add swt library to the project [message #612985 is a reply to message #125405] |
Wed, 31 May 2006 03:25  |
installation and now it works, i've created a swt project with a shell and
Re: [SOLVED]Not able to add swt library to the project [message #612989 is a reply to message #125429] |
Rich Kulp
FUDForum. Page generated in 0.06046 seconds
