XSD Importer and FeatureMap [message #1253655] |
Sat, 22 February 2014 09:20  |
I am importing an XSD from a 3rd party and it is generating FeatureMap
groups where I believe there shouldn't be any.
I have been able to identify such a case, where I can't understand the
use of the map.
The following creates a FeatureMap;
<xs:complexType name="entitiesType">
<xs:sequence maxOccurs="unbounded">
<xs:element name="entity" type="entityType"/>
</xs:sequence>
</xs:complexType>
And this revised version doesn't:
<xs:sequence>
<xs:element name="entity" type="entityType" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
My research on specifying min/max occurs on the sequence vs the element
is that it should normally be on the element but I can't understand
where that impacts FeatureMaps.
Alain
Re: XSD Importer and FeatureMap [message #1253766 is a reply to message #1253685] |
Sat, 22 February 2014 12:17   |
Thanks Christian for the quick reply.
Alain
On 2/22/2014 10:07 AM, Christian W. Damus wrote:
> Hi, Alain,
> A sequence can potentially declare any number of elements, not just
> one. So, repeating that sequence implies (potential) interleaving of
> different elements, which in EMF requires a FeatureMap for correct
> serialization. I think you just have a special case (single element in
> the sequence) of this more general scenario.
> HTH,
> Christian
>> use of the map.
>> </xs:sequence>
>> </xs:complexType>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:complexType>
>> element is that it should normally be on the element but I can't
>> understand where that impacts FeatureMaps.
>> Thanks
>> Alain
Re: XSD Importer and FeatureMap [message #1254399 is a reply to message #1253766] |
Sun, 23 February 2014 05:21  |
Alain,
Yes, it's exactly as Christian hypothesized. Repeating model groups do
in general lead to feature maps because of element interleaving. This
special case of a model group with only one particle I suppose could be
handled in a special way. Adding ecore:featureMap="" to the
xs:sequence would suppress it explicitly...
> Alain
>> Hi, Alain,
>> HTH,
>> Christian
>>> use of the map.
>>> </xs:sequence>
>>> </xs:complexType>
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:complexType>
>>> Thanks
>>> Alain
FUDForum. Page generated in 0.04014 seconds
