Home » Archived » Visual Editor (VE) » How to import Swing app to VE?
How to import Swing app to VE? [message #125353] Fri, 26 May 2006 12:35 Go to next message
Originally posted by: billl.gmail.com
Can Eclipse generate a Visual Editor when I import an outside SWING
application?
I am assuming not since I didnt see any easy way of doing this. Then what
is the default location for any saved VE when I create a visual class, so
that I can move it to another project?
Re: How to import Swing app to VE? [message #125366 is a reply to message #125353] Fri, 26 May 2006 13:26 Go to previous message
Originally posted by: jefmyers.us.ibm.com
Right click on your java file and Open With->Visual Editor. Depending on
how you wrote your original program, you'll have varying degrees of
success in importing existing source to use as a Visual Class.
Information about the source patterns VE recognizes is in the help
documentation and this (pretty outdated) article:
http://www-128.ibm.com/developerworks/websphere/library/tech articles/0303_winchester/winchester.html
Hope this helps,
- Jeff
Re: How to import Swing app to VE? [message #612974 is a reply to message #125353] Fri, 26 May 2006 13:26 Go to previous message
Hope this helps,
- Jeff
Previous Topic:How to import Swing app to VE?
Next Topic:V.E not writing the code returned by property editor --urgent :please help its
Current Time: Sat Jul 19 17:17:42 EDT 2025
Powered by FUDForum. Page generated in 0.06345 seconds
