Home » Modeling » EMF » Storing a FeaturePath(Serializing to file?)
Storing a FeaturePath [message #1252476] Fri, 21 February 2014 03:57 Go to next message
I'm in need to save a FeaturePath to a file (to be able to load it again, with the same model - no need to check for this!)
how can i do this as the FeaturePath and its underlying objects do not implement Serializable interface.
i already 'googled' but did not find any solutions (if i missed it and you know a link, let me know)
thanks in advance
Ludwig
Re: Storing a FeaturePath [message #1252487 is a reply to message #1252476] Fri, 21 February 2014 04:07 Go to previous messageGo to next message
Ludwig,
It's basically a list of EStructuralFeatures, which are EObjects and so
you could use EcoreUtil.getURI to represent a reference to them, and use
ResourceSet.getEObject to resolve those.
On 21/02/2014 9:57 AM, Ludwig Moser wrote:
> Hello,
> thanks in advance
> Ludwig
Re: Storing a FeaturePath [message #1252637 is a reply to message #1252487] Fri, 21 February 2014 07:35 Go to previous messageGo to next message
thanks for the fast reply.
your help solved my problem!
so now i set the featurePath to transient,
before saving i call my method prepareSaving so the featurepath is transformed to String[] of URI's
public void prepareSaving() {
		EStructuralFeature[] features = featurePath.getFeaturePath();
		featureURIs = new String[features.length];
		for (int i = 0; i < features.length; i++) {
			featureURIs[i] = EcoreUtil.getURI(features[i]).toString();
when loading from file i first load, then call reinit()
	public void reinit() {
		ResourceSet resSet = new ResourceSetImpl();
		EStructuralFeature[] features = new EStructuralFeature[featureURIs.length];
		for (int i = 0; i < featureURIs.length; i++) {
			features[i] = (EStructuralFeature) resSet.getEObject(URI.createURI(featureURIs[i]), false);
		featurePath = FeaturePath.fromList(features);
i post this here so if someone finds my question he also finds an answer (in code)
Re: Storing a FeaturePath [message #1252682 is a reply to message #1252637] Fri, 21 February 2014 08:31 Go to previous messageGo to next message
I think Ed meant to let EMF handle the details of serialization, for
example by using dynamic EMF. You just create an EPackage with a single
EClass that has a reference many of type EStructuralFeature. Then:
EObject root = EcoreUtil.create(myFeaturePathClass);
root.eGet(path).addAll(allFeaturesInTheFeaturePath);
Resource res = ResourceSetImpl().getResource("toto.featurePath", false);
res.getContents().add(root);
res.save(System.out, Collections.EMPTY_MAP);
Maybe you want to register EcoreResourceFactory against the file extension.
Felix
Re: Storing a FeaturePath [message #1252838 is a reply to message #1252682] Fri, 21 February 2014 11:55 Go to previous messageGo to next message
Felix,
Indeed, ideally the thing would serialize in the same resource, and yes,
ideally you'd model it as a multi-valued reference to
EStructuralFeatures. A derived transient volatile attribute could be
used to provide a "convenience" get/setter than provided/accepted the
FeatureMap data structure. Then all would serialize as normal...
> single EClass that has a reference many of type EStructuralFeature. Then:
> extension.
> Felix
Re: Storing a FeaturePath [message #1255176 is a reply to message #1252838] Mon, 24 February 2014 01:52 Go to previous messageGo to next message
i'm writing way more to my config than only the featurepath. but no more details come from EMF. its just the path to access the attribute. (i do not need any properties of an EClass saved or similar (this will be used later on import/export, but at that time i will use Resource for sure) )
So, Ed, is it incorrect to do it the way i do it?
[Updated on: Mon, 24 February 2014 01:52] by Moderator
Re: Storing a FeaturePath [message #1255177 is a reply to message #1252838] Mon, 24 February 2014 01:52 Go to previous message
if i need to serialize feature paths I simply remember the Eclass the
path starts with and the feature names this is enough if you know the
EClass you start from.
Tom
On 21.02.14 17:55, Ed Merks wrote:
> Felix,
>> extension.
>> Felix
Previous Topic:XSD Importer and FeatureMap
Next Topic:How to import UML?
Current Time: Sun Jul 20 09:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.05105 seconds
