Home » Modeling » EMF » open model with validating xml editor
open model with validating xml editor [message #1250562] Wed, 19 February 2014 05:56 Go to next message
I need to examine and, possibly, hand-modify an EMF model saved in XMI.
I generated the corresponding XSD files (I have two models sharing a common part, so I have two .xml and three .xsd).
How should I modify them to be able to open the Schema Definition locally?
I am using "XML Copy Editor" (using Eclipse for the task should be avoided, unfortunately) and it rightly complains (Error at line 2, column 121: no declaration found for element 'hyconmde:MDE').
As You can see the various .x?? files point to a web location (where no .xsd is to be found, at least to date).
What am I doing wrong?
How should I define things to have locally defined Schema Descriptions?
In case this is not possible: how should I upload Schemas to web server?
I tried googling around but found no answer; any pointer to "best practices" welcome.
Mauro Condarelli
================== hyconmdeXMI.xsd ================================
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:base="http://www.soft-in.com/base/1.0" xmlns:hyconmde="http://www.soft-in.com/hyconmde/1.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.soft-in.com/hyconmde/1.0">
<xsd:import namespace="http://www.omg.org/XMI" schemaLocation="platform:/plugin/org.eclipse.emf.ecore/model/XMI.xsd"/>
<xsd:import namespace="http://www.soft-in.com/base/1.0" schemaLocation="baseXMI.xsd"/>
<xsd:simpleType name="ArchivingInterval">
<xsd:restriction base="xsd:NCName">
================== baseXMI.xsd ================================
<xsd:schema xmlns:base="http://www.soft-in.com/base/1.0" xmlns:hyconmde="http://www.soft-in.com/hyconmde/1.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.soft-in.com/base/1.0">
<xsd:import namespace="http://www.soft-in.com/hyconmde/1.0" schemaLocation="hyconmdeXMI.xsd"/>
<xsd:simpleType name="Language">
<xsd:element name="Identifiable" type="base:Identifiable"/>
</xsd:schema>
================== ?xml version="1.0" encoding="ASCII"?>
<hyconmde:MDE xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:hyconmde="http://www.soft-in.com/hyconmde/1.0">
<archiveBaseCycles id="1" eId="ArchiveBaseCycle(001)" name="MIN" i18n="StringI18n(070)"/>
Re: open model with validating xml editor [message #1250636 is a reply to message #1250562] Wed, 19 February 2014 07:35 Go to previous messageGo to next message
Mauro,
Comments below.
On 19/02/2014 11:56 AM, Mauro Condarelli wrote:
A schema for an XMI serialization is effectively useless in my opinion.
You used the Export Model... for this?
> locally?
You're wanting to modify these schemas? For what purpose?
I would expect a global element declaration corresponding to each
non-abstract EClass in your model.
No, where do I see that?
> to date).
I can warn you up front that you will get no use validation from an XMI
schema.
What do you mean by locally defined?
> practices" welcome.
I think it's better to explain what you're hoping to achieve so I can
tell you whether that's sensible or not. Keep in mind some constraints
of XML Schema. It only supports single inheritance and has essentially
no support for typed cross references. Ecore/EMOF supports multiple
inheritance and real models make heavy use of cross references. It's a
very bad mismatch. Compound that with the fact that XMI has a very
loose syntax, i.e., a feature can be serialized as an element or an
attribute, and you end up with something that's simply not generally
describable with an XML Schema. So at best these XMI schemas are a
highly verbose way of turning off validation so if your goal is to
achieve some kind of useful validation, I can warn you up front that
this is not achievable...
> Regards
> Mauro Condarelli
> </xsd:schema>
Re: open model with validating xml editor [message #1251450 is a reply to message #1250636] Thu, 20 February 2014 03:22 Go to previous messageGo to next message
Thanks Ed,
a few words to describe my current predicament.
I am writing an application heavily relying on a non-trivial (65+ EClasses) EMF model.
Unfortunately some parts of this mode are to be considered "read only" and filled from a custom Database I have no access to.
Customer will have to write on his own database interface, but, since that is not yet available, while I need to test my part, Customer wants to manually enter in XML the "missing parts".
On the other hand I would like to constrain whoever enters data manually, as much as possible,to enter valid data.
Add to this Customer "does not want to be tied to Eclipse" (I'm using EMF in Standalone mode)...
This is the reason to the present request.
Other comments below.
On 19/02/2014 13:35, Ed Merks wrote:
> Mauro,
> Comments below.
>> Hi,
> A schema for an XMI serialization is effectively useless in my opinion. You used the Export Model... for this?
Yes.
I do not want to modify the schemas, I want to use them in a sensible XML/XMI editor to "hand-edit" the model *contents*, possibly with checking, completion, etc.
> I would expect a global element declaration corresponding to each non-abstract EClass in your model.
They are there, I copied just the headers of the various files, If You want I can attache the whole thing (their're not small!).
That's my company URL followed by "base" model and a version number
> I can warn you up front that you will get no use validation from an XMI schema.
I begin to understand, what alternatives?
I don't exactly know ;)
I was expecting something like:
xsd:schema xmlns:base="../baseXMI.xsd"
> I think it's better to explain what you're hoping to achieve so I can tell you whether that's sensible or not. Keep in mind some constraints of XML Schema. It only supports single inheritance and has essentially no support for typed cross references. Ecore/EMOF supports multiple inheritance and real models make heavy use of cross references. It's a very bad mismatch. Compound that with the fact that XMI has a very loose syntax, i.e., a feature can be serialized as an element or an attribute, and you end up with something that's simply not generally describable with an XML Schema. So at best these XMI schemas are a highly verbose way of turning off validation so if your goal is to achieve some kind of useful validation, I can warn you up front that this is not achievable...
What are the alternatives?
Mauro Condarelli
>> Regards
>> Mauro Condarelli
>> </xsd:schema>
Re: open model with validating xml editor [message #1251551 is a reply to message #1251450] Thu, 20 February 2014 05:36 Go to previous messageGo to next message
Mauro,
Comments below.
On 20/02/2014 9:22 AM, Mauro Condarelli wrote:
> Thanks Ed,
Maybe it's better that be in a separate resource? In any case, an XMI
Schema is really not useful for this purpose. Because any object can
have an xmi:type that specifies a subclass that's allowed, and because
that information is completely useless from an XML Schema point of view,
nested elements always end up allowing arbitrary content according to
the XMI Schema. That's why I call it a verbose way of turning of
validation.
Yes, I can see why you'd want that...
Perhaps it's better you provide a stand alone validator tool that
effectively tries to load the resource using EMF and reports all the
problems it encounters.
It seems infeasible with XMI, unfortunately.
>> Mauro,
>> Comments below.
>>> Hi,
> Yes.
>>> locally?
>>> least to date).
>> XMI schema.
>>> server?
>>> practices" welcome.
> Regards
> Mauro Condarelli
>>> Regards
>>> Mauro Condarelli
>>> </xsd:schema>
Re: open model with validating xml editor [message #1251586 is a reply to message #1251551] Thu, 20 February 2014 06:29 Go to previous messageGo to next message
Ed,
see inline comments.
On 20/02/2014 11:36, Ed Merks wrote:
> Mauro,
> Comments below.
>> Thanks Ed,
> Maybe it's better that be in a separate resource? In any case, an XMI Schema is really not useful for this purpose. Because any object can have an xmi:type that specifies a subclass that's allowed, and because that information is completely useless from an XML Schema point of view, nested elements always end up allowing arbitrary content according to the XMI Schema. That's why I call it a verbose way of turning of validation.
> Perhaps it's better you provide a stand alone validator tool that effectively tries to load the resource using EMF and reports all the problems it encounters.
A standalone validator is feasible and easy.
After all my application does a validation pass right after loading resource from XMI.
Problem is providing, if at all possible, a "guided way" to edit the model, possibly without implementing a complete editor, which would NOT be something fast.
This is what I feared.
I tried generating the default editor, hoping to be able to transform it in an RCP "standalone" application.
Problem is I get errors when spawning the eclipse application because it lacks JavaFX support.
Note: I added a few JavaFX Dialogs to edit/modify EClasses directly as model EOperation (I know it's not "clean", but reasons are too long to explain here).
My Application is a native Java8/JavaFX application and I am using Tom's e(fx)clipse with Java8-ea SDK, but starting the EMF-generated editor as "eclipse application" produces the following errors:
!SESSION 2014-02-20 12:11:40.969 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.8.0-ea
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data D:\Work\Voith\00 Soft-in\workspaces\step2/../runtime-EclipseApplication -dev file:D:/Work/Voith/00 Soft-in/workspaces/step2/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2014-02-20 12:12:01.069
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-02-20 12:12:01.069
!MESSAGE Bundle reference:file:/D:/opt/eclipse-SDK-4.3.1-win32-x86_64-efx-0.9.0-SNAPSHOT/eclipse/plugins/org.eclipse.fx.ide.java6_0.9.0.201312110809/ was not resolved.
!SUBENTRY 2 org.eclipse.fx.ide.java6 2 0 2014-02-20 12:12:01.069
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(&(osgi.ee=JavaSE)(version>=1.3)(!(version>=1.7)))".
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.fx.ide.java6_0.9.0.201312110809 [222] was not resolved.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2014-02-20 12:13:11.400
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '345'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javafx/scene/Node
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
Any help welcome.
>>> Mauro,
>>> Comments below.
>>>> Hi,
>> Yes.
>> Regards
>> Mauro Condarelli
>>>> Regards
>>>> Mauro Condarelli
>>>> </xsd:schema>
Re: open model with validating xml editor [message #1251641 is a reply to message #1251586] Thu, 20 February 2014 07:44 Go to previous messageGo to next message
Mauro,
Comments below.
On 20/02/2014 12:29 PM, Mauro Condarelli wrote:
> Ed,
>> Mauro,
>> Comments below.
>>> Thanks Ed,
> resource from XMI.
Indeed.
Aren't they just going to copy and paste XML?
Not so easy. You need all kinds of scaffolding for an RCP application.
> explain here).
> java.vendor=Oracle Corporation
> D:\Work\Voith\00
> !MESSAGE Bundle
> was not resolved.
> not resolved.
> bundle '345'
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any help welcome.
In the case that we wanted an RCP editor for our Oomph model, I copied
the *.genmodel, and change the copy to specify i wanted to generated an
RCP editor and changed the bundle where that editor is generated. Then
I can generate a normal editor and an RCP editor (and hopefully not end
up with too many hand-written changes I need to maintain across the two
copies).
>>>> Mauro,
>>>> Comments below.
>>>>> Hi,
>>>>> XMI.
>>> Yes.
>>>>> locally?
>>>>> least to date).
>>>> XMI schema.
>>>>> Descriptions?
>>>>> server?
>>>>> practices" welcome.
>>>> achievable...
>>> Regards
>>> Mauro Condarelli
>>>>> Regards
>>>>> Mauro Condarelli
>>>>> </xsd:schema>
Re: open model with validating xml editor [message #1252073 is a reply to message #1251641] Thu, 20 February 2014 17:48 Go to previous messageGo to next message
Thanks Ed,
comments inline.
On 20/02/2014 13:44, Ed Merks wrote:
> Mauro,
> Comments below.
What I really need is to have the EMF-generated editor to open as a normal editor, without the whole eclipse IDE.
Nothing else is necessary.
Would that be possible, somehow?
>> Any help welcome.
> In the case that we wanted an RCP editor for our Oomph model, I copied the *.genmodel, and change the copy to
> specify i wanted to generated an RCP editor and changed the bundle where that editor is generated. Then I can
> generate a normal editor and an RCP editor (and hopefully not end up with too many hand-written changes I need
> to maintain across the two copies).
Sorry, I fail to understand You.
Why copying?
Note I'm using ONLY the model code, no edit, no editor.
I would generate edit/editor JUST for this purpose.
It should be possible to "Export as Eclipse Product", shouldn't it?
I will retry specifying RCP Editor.
First problem, however, is to convince the target eclipse invocation to use the "right" JVM (JDK8-ea).
Please elaborate.
Mauro
Re: open model with validating xml editor [message #1252333 is a reply to message #1252073] Fri, 21 February 2014 00:26 Go to previous message
Mauro,
Comments below.
On 20/02/2014 11:48 PM, Mauro Condarelli wrote:
> Thanks Ed,
> comments inline.
>> Mauro,
>> Comments below.
That's what the RCP editor is supposed to be.
>>> Any help welcome.
> Why copying?
Because there are settings in the *.genmodel for generating RCP and that
produces something quite different from the normal editor. If you want
both, you'll want two different *.editor projects and one *.genmodel
can't do that.
Well of course the editor requires the later, but if you don't need two
editors you can use just one *.genmodel to produce your RCP editor.
I see, then you don't need a copy.
We don't generate a product definition, but yes, if you wrote such a
thing, you can use that to produce your "product".
That's defined in the launcher choosing the JRE you've registered via
the Java preferences for that.
> Please elaborate.
> Regards
> Mauro
Previous Topic:EMF modifying files?
Next Topic:EMF Validation,
Current Time: Sun Jul 20 04:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.05645 seconds
